    [Plugin] Selection Toys
    594 Posts 121 Posters 396.9k Views 121 Watching
      Outer Edges added to selection filters and Quad-Face Loop now accepts multiple start-edges in my internal build. Got a couple of other things to finish before I release it though.
      • bagateloB Offline
        bagatelo
        MODO from Luxology have good tools that make interesting selections. I remenber one very good. Is something like select polygon by yes/no/yes/no/yes/no, or by samples. Think about this, please.
          yes/no/yes/no/yes?
          • bagateloB Offline
            bagatelo
            @thomthom said:
            yes/no/yes/no/yes?
            Please see the imagem called "selection"...
            This is plugins tools to make selections in 3dsMax, and more...:
            http://www.polyboost.com/features_selection.htm
            http://www.orionflame.com/
            • JClementsJ Offline
              JClements
              Hi Thom:
              Selection Tools must be a labor of love! 😄
              Selecting Instances on same layer (both all and active) not working? See attached.
              Select Instance of Same Layer Not Working.skp
                I will look into that.
                (you edited you post? you mentioned about selecting from active vs all - well, I have been planning a complete new set of selection tools, where you interactively build your selection)
                  @jclements said:
                  Another Bug; Select Edge Loops?
                  If after an edge loop is selected, then using the Layers Toolbar dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
                  hm.. will have to look at that. I never use that toolbar. PC or OSX?
                  @jclements said:
                  Select Default Front and Default Back not working?
                  Might be a bug there. Thought I'd fixed it earlier, but maybe it slipped through... 😕
                    JClements
                    Yeh, I edited my post because part of it didn't make sense. 😲
                    If after an edge loop is selected, then using the Layers Toolbar (PC) dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
                    [Edit]
                      @jclements said:
                      Hi Thom:
                      Confirmed and fixed internally.
                      Thanks for reporting.
                        Can't reproduce.
                          @thomthom said:
                          Can't reproduce.
                          Saying that, as it works now, the edges also needs to have the same material for the Select Connected by Material to select the neighbouring face... Might have to revise this function. ...and I wonder why I haven't added one that doesn't select connected....
                            [attachment=0:137w7llf]<!-- ia0 -->Layers Toolbar, PC.png<!-- ia0 -->[/attachment:137w7llf]
                            This is very odd. But it seems to be a Sketchup bug. I can't see anything in my code that'd do this. And as you say, the Entitiy Info works. I'll try to forward this to Google.
                              rv1974
                              Hi!
                              What I really missinng is option to select all edges bitween "90 degrees faces" (the exact degree number should be ajustable)
                                Ah - took me a little while to understand this one, but being able to select edges where the angle between connected faces are larger than a given angle?
                                This would be something that filters an existing selection? Or make a new selection in the active space?
                                  rv1974
                                  ...being able to select edges where the angle between connected faces are larger than a given angle?..
                                  -yes
                                  ...filters an existing selection?
                                  -yes
                                  • juan974J Offline
                                    juan974
                                    good idea rv1974, kind of : "select string edges", useful for complicated shape
                                    juan974 (Réunion island)
                                    website : http://sketchucation.com/click.php?url=http://www.tarn.us
                                    • N3TON Offline
                                      N3TO
                                      Where can I download Seletcion Toys (2.1.0)???
                                      thanks
                                        thanks
                                        Bottom of the first post on the first page of this thread.
                                        • Dan RathbunD Offline
                                          Dan Rathbun
                                          Selection Modifier
                                          Selection Submenu - Currently there's two kinds of modifiers.
                                          The explanations are a bit confusing for me... I have alot of experience in Electronic Radio Frequency / Broadcast Engineering, where Filters are a very important device. So when I think of Filters I think of them in that respect. See if you think I'm correct here:
                                          One filters out the type of entity you want.
                                          This would be a 'Pass' filter?
                                          http://en.wikipedia.org/wiki/Band-pass_filter
                                          The other deselects the entity you specify.
                                          This is a 'Reject' Filter? (also sometimes called a 'Trap' or 'Notch' Filter from the way the signal looks on a Spectrum Analyser.)
                                          http://en.wikipedia.org/wiki/Notch_filter
                                          I'm not here much anymore.
                                            I think so ... from what I understood of that definition of filters... unfamiliar territory to me.
                                            • 29
                                            • 30
                                            • 8 / 30
