    [Plugin] Quick Camera Rotate 90º (Roll)
    20 Posts 14 Posters 24.6k Views 14 Watching
      Jim
      @jim said:
      Is there already a plug-in to rotate the camera? I just want a couple quick buttons to rotate the view around 90 degrees. If not, I'll make it up real quick. If anyone else is interested and wants to make icons, that would be great.
      Here it is. Makes an entry in the Camera menu. Just does one thing - rolls the camera 90 degrees around the current view direction.
      jf_rotcam90.rb
        In what direction in space?
        I just wrote a little snippet to roll the camera by a given degree, so it's not following the horizon. Maybe that's different from what you refer to?
          Jim
          About the same - just wanted to be able to export standard views only rotated. Yes, roll is the correct term.
          • mitcorbM Offline
            mitcorb
            Jim this sounds interesting.
            Could you illustrate, or elaborate?
            I think you mean the effect you get when orbiting and pressing the control button, and you have set it at specific angles, is that correct?
              Jim
              It just rolls the camera around the line-of-site by 90 degrees each time the button is pressed. Image 1 is a normal Front view. Image 2 is still a Front view, but with the Camera rotated about it's direction vector (and zoomed in.)
              • mitcorbM Offline
                mitcorb
                Well, now, this is excellent!
                  @jclements said:
                  What a great, basic tool.
                  Thanks, Jim.
                  It would be kind of cool if you could hook it into the Protractor Tool to make it interactive.
                  Yea - that's exactly what I had in mind. A click drag to define an angle displayed on sceeen as the protractor tool, and where you can use the VCB to input a specific angle.
                  • mitcorbM Offline
                    mitcorb
                    ThomThom:
                    I can see that your concept would have relevance for tight box selections in a busy model. I was trying to do this yesterday while selecting a series of end connected edges between other parallel edges in a mesh for scaling that one series. Being able to roll the camera will enable me to make a tall thin selection box with the select tool to isolate.
                    What would be nice is a selection tool that can use circular or polygonal selection areas, but I guess that would be for another thread, and I suppose this is not addressable in ruby.
                    • JClementsJ Offline
                      JClements
                      Thanks, Jim.
                      It would be kind of cool if you could have a similar script hook into the Protractor Tool to make it interactive.
                        danbig
                        @thomthom said:
                        Thanks, Jim.
                        ... I'll add a third vote for this feature.
                          supersketcher
                          Thanks Jim.
                          I like it: simple but effective!
                          It indeed deserves a dedicated icon.
                            JGA
                            Thanks for this plugin, very useful!
                            Regards,
                            JGA
                              langloisl
                              Hello,
                              your plug-in to roll the camera is great 👍 , but it does not meet my need 😞 . What I look for, is being able to rotate my camera precisely 90 degrees in the direction I want, either left, right, up, down.
                              This is in order to be able to create a cube to six or rendered with Kerkythea or Twilight Render and then assemble them with GoCubic.
                              Plug-In "cubicpanoout.rb" does not create six scenes, he does that exporting 6 cubic views. If you have the solution to my problem, it would be much appreciated!
                              Greetings ! 😄
                              Ludo
                                dylanwoods
                                very very helpful. thanks
                                  PaulfromtheNorth
                                  EXACTLY what i was looking for!
                                    SamUK
                                    Hi Jim
                                    I realise this is an old thread but here's hoping...
                                    Could you tell me if this plugin would work with 2013, it sounds really useful and I would love to be able to use it however, I have put it in the plugin folder to no avail....
                                    It would be good to know if it would be compatible or not, so I can try harder or give up....
                                    Sam
                                      It works fine in SU2013. Perhaps you could describe what you are seeing or not seeing?
                                        db11
                                        I use this great little plug-in a lot, especially to orient from the standard Top view for plans.Now I have a house whose grid is at 45° and I'd like to be able to use this to align the view (as a Parallel Projection).
                                        Is there a simple mod to make this work for 45°? I took a quick look at the script, and it wasn't obvious to me, which variable/value to change.Maybe someone who actually knows what they're doing could help me out?
                                        Thanks.
                                        • TIGT Online
                                          Perhaps this does what you want?
                                          http://sketchucation.com/pluginstore?pln=Rotateplanview
                                            db11
                                            Perfect! Exactly what I was looking for... I guess I just didn't scroll far enough down the page when I searched 'rotate camera' in the plugins forum.
                                            Thanks TIG
