    [Plugin] Quick Camera Rotate 90º (Roll)
    20 Posts 14 Posters 24.4k Views 14 Watching
      danbig
      @thomthom said:
      @jclements said:
      What a great, basic tool.
      Thanks, Jim.
      It would be kind of cool if you could hook it into the Protractor Tool to make it interactive.
      Yea - that's exactly what I had in mind. A click drag to define an angle displayed on sceeen as the protractor tool, and where you can use the VCB to input a specific angle.
      ... I'll add a third vote for this feature.
        supersketcher
        Thanks Jim.
        I like it: simple but effective!
        It indeed deserves a dedicated icon.
          JGA
          Thanks for this plugin, very useful!
          Regards,
          JGA
            langloisl
            Hello,
            your plug-in to roll the camera is great 👍 , but it does not meet my need 😞 . What I look for, is being able to rotate my camera precisely 90 degrees in the direction I want, either left, right, up, down.
            This is in order to be able to create a cube to six or rendered with Kerkythea or Twilight Render and then assemble them with GoCubic.
            Plug-In "cubicpanoout.rb" does not create six scenes, he does that exporting 6 cubic views. If you have the solution to my problem, it would be much appreciated!
            Greetings ! 😄
            Ludo
              dylanwoods
              very very helpful. thanks
                PaulfromtheNorth
                EXACTLY what i was looking for!
                  SamUK
                  Hi Jim
                  I realise this is an old thread but here's hoping...
                  Could you tell me if this plugin would work with 2013, it sounds really useful and I would love to be able to use it however, I have put it in the plugin folder to no avail....
                  It would be good to know if it would be compatible or not, so I can try harder or give up....
                  Sam
                    It works fine in SU2013. Perhaps you could describe what you are seeing or not seeing?
                      db11
                      I use this great little plug-in a lot, especially to orient from the standard Top view for plans.Now I have a house whose grid is at 45° and I'd like to be able to use this to align the view (as a Parallel Projection).
                      Is there a simple mod to make this work for 45°? I took a quick look at the script, and it wasn't obvious to me, which variable/value to change.Maybe someone who actually knows what they're doing could help me out?
                      Thanks.
                        Perhaps this does what you want?
                        http://sketchucation.com/pluginstore?pln=Rotateplanview
                          db11
                          Perfect! Exactly what I was looking for... I guess I just didn't scroll far enough down the page when I searched 'rotate camera' in the plugins forum.
                          Thanks TIG
