    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.2m Views 73 Watching
    • Bob JamesB Offline
      Bob James
      Simon, there's no other word for you but awesome 👍
      • CarrozzaC Offline
        Carrozza
        Men, this plugin with help of fantasy and skills (like Simon') are a killer combo!
        • Chris FullmerC Offline
          Hey, looks great Simon. I love the way you dig in and study the plugins. I think its helpful for users to see how they can be used, and its helpful for me to see how people are trying to use these scripts. Helps think of new workflow improvements.
          In fact, the next version of componet stringer lets you select more than 1 component. And it gives you the option of random placement of all selected, or ordered. So the reandom placement will help in the palisade example you just showed. It would make it quicker to place random boards.
          The next version will also support series of non-connected edges (I think I already hinted at that earlier) and also supports closed loop selections of lines. It also includes a great little tool to reverse the direction components are "strung". I'm trying to get it all put together for one big release soon.
          Also, I'm thining about the offset placement possibilities. I'm trying to figure out how that should be implemented. If anyone has any thoughts on how they want to see that work, I'd be interseted in hearing it.
          • simon le bonS Offline
            simon le bon
            Thank you Bob & Carrozza ! your encouragement warms my heart..
            The following is probably the last idea that I wanted to develop With Component Stringer.
            I dedicate it to our so nice fellow and great author, Chris.
            It is his:"TOTAL CHRIS FULLMER RANDOM PALISADE"
            (because made about totally with a set of his own tools 😉 )
            How to produce a palisade constituted with random singular boards!!
            My idea is to copy palisade's boards along a path constituted by a random segmented curve Using ComponentStringer/Stretch mode.
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_025th.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_026th.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_027th.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_028th.jpg
            Using ShapeBender this way: same length for the curve and for the grouped segmented line, the resulting ShapeBender Component keep closely the same lengths of segments inside the curve than those of the segmented line 😉 😉
            [Plugin] Shape Bender Beta v0.51
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_029th.jpg
            [Plugin] Select Lines by Length
            Jim_Selection Memory
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_030th.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_031th.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_032th.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_033th.jpg
            We delete 3/4 component for each segment( artistically if possible 🤣 )
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_034th.jpg
            Et voila votre jolie pallissade ☀
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_035th.jpg
            Dear Chris,dear all,
            with my very friendship..
            😄 simon.
              simon le bon
                Suggestion
                A rotation (s) of object on it own axis?
                A scale of object?
                • plot-parisP Offline
                  plot-paris
                  wow, Chris. thats sounds like a reason (or several for that matter) to be excited about the next release... 🎉
                  • H Offline
                    hsjzyangbin
                    Hi,Chris,I wish your 'Component Stringer'and TIG'S "GROW.RB" combine together
                    • mitcorbM Offline
                      mitcorb
                      Chris:
                      When using the uniform scale parameter, does the script start out with a set multiple? I am guessing say 1.5 x the scale of the component? and then the factor is applied to each subsequent component instance?
                      If this is so, would there be a user changeable scale factor parameter in the future?
                      By the way, this is a nice tool and I appreciate your sharing it.
                        Hmm, good idea. That is not the way it works, but it would be fairly easy to implement (I think). No guarantees how fast I'll get it done, but I'll try to put this feature in the mext release.
                        • JClementsJ Offline
                          JClements
                          In the attached I have component which I have attempted to string along a path in an orientation similar to that of the component. I've played with changing the component's axis but can't seem to get it right by only changing the component axis (rotating the component and then reseting its axis can work).
                          Chris, what is the secret? Your video mentions setting the blue axis but what of the red and green and at what corner of the component?
                          Signed, all strung out.
                          John
                          STRINGER - What are the rules to getting component oriented on path correctly.skp
                            Hi John, I set is up so that the blue axis in the component lines itseful up with the line spegment it is being placed on in the path. That is as much as I control directly in the script. The x and y axes are determined through what SU calls "an arbitrary axis rule." Digging into this, it appears that once I set the blue axis, SU forces the component's red axis to lie flat on the x,y plane. Then the component orients itself so that the green axis is pointing in a positive direction (always pointing slightly upard, or completely upward if the path being followed is flat on the ground).
                            So, if your path is flat, then the blue will follow the segment it is to stetch over. And the green will point upwards in the model's blue direction.
                            But once your path gets off the flat x,y plane, the it gets a little trickier to guess how the pices will orient themselves.
                            Sorry thats not much help,
                              JClements
                              Thanks, Chris. Helps make things a bit more predictable.
                                Purita
                                @cadfather said:
                                Thanks Chris
                                it's funny how many different angles you land on sketchup from..
                                • utilerU Offline
                                  utiler
                                  Suggestion
                                  A scale of object?
                                  What I wished for a while now.... http://forums.sketchucation.com/viewtopic.php?f=180&t=19204&hilit=+copy+rotate+scale
                                  I wish I could explain!!!
                                  Just Curious...
                                    KXI System
                                    Chris, I love your tools but just one thing...
                                    This plugin I can't get to work for some reason, I even reinstalled it. Nothing happens when I even activate it, here is what I get in the Ruby console:
                                    Error: #<NoMethodError: undefined methoddefinition' for nil:NilClass>
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:103:in main' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190 C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call'
                                    See Chris? a little help here?`
                                    Getting the perfect sig is hard...
                                    Google it!
                                      Thank you for reporting the error with the error codes from the console, helps spped things up a bit!
                                      It looks like you do not have a component selected when you start the script. So make sure that you select a component first, then start the script.
                                      If that does not fix it, please upload a test model that you are having problems with and I'll test it.
                                        KXI System
                                        Chris,
                                        After a few moments of struggle I found out that the script works after a few failures...
                                        But what I have found is that sometimes the selected component changes during action, see attachments:
                                        Bug1.skp
                                        Ruby Console:
                                        No reversing needed Error: #<NoMethodError: undefined methodposition' for nil:NilClass>
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:137:in main' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in each_with_index'
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in each' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in each_with_index'
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in main' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190 C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call'.`
                                        Note: 1 try only
                                        Bug2.skp
                                        Ruby Console:
                                        Error: #<NoMethodError: undefined methodedges' for nil:NilClass>
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:59:in curve_ordering' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:56:in times'
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:56:in curve_ordering' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:105:in main'
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call' Error: #<NoMethodError: undefined method edges' for nil:NilClass>
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call' Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:79:in add_text'
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:79:in curve_labeler' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:70:in curve_ordering'
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:105:in main' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190 C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call'
                                        Error: #<NoMethodError: undefined method definition' for nil:NilClass> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:103:in main'
                                        Note 10+ tries, no result
                                        Bug3.skp
                                        Ruby Console:
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in main' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190 C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call'`
                                        Note 1 try, "big" problem
                                        Google it!
                                          simon le bon
                                          Hello Chris, Hello everybody,
                                          I'm back for a little addition in using Component Stringer.
                                          I have had the idea to use a progressive segmented curve in conjunction with Component Stringer for various interesting effects.
                                          It exists a Fredo's tool :Fredo_BZ__Animation which can do the goal. But it is build for animation matters and I had found it not enough flexible for my purpose.
                                          So I have made a small tut to make our Own BZ_animation Curve
                                          I have made some exemples, not very subtle I guess but I think the idea is shown 😉
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/temple1300_02_th.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/temple1300_03_th.jpg
                                          *s
                                          • brookefoxB Offline
                                            brookefox
                                            Well, I'm happy to post this homely little picture: my first entry into the well-worn spiral stair saga. Contents: the usual suspects: one set of edges, one component (soon to be tuned and embellished with stringers, railings etc.). Why bother this thread? I just thought maybe a point or two needed clarification: In this case the length of each edge determines the displacement of the component, and the component cannot touch the edges or the routine will not work (for me).
                                            Thanks, Chris!!
                                            (For me, it would be nice if the settings were sticky across uses.)
                                            ~ Brooke
                                            • 5 / 9
