    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.1m Views 73 Watching
    • jeff hammondJ Offline
      ha Simon..
      i love the stuff you come up with using some of the scripts that pop up.
        kostas_designer
        Great plugin Chris!
        I was trying it while working on an industrial component, i kind of chain.
        Problem is that i cannot edit the single component because ita has a given dimension.
        So, arraying straight segments is not a problem as i can use the Copy Array Groups or Components plugin, but when it comes to follow a curve things get tough (at least for me! 😕 )
        I agree that having the control of sthe spacing would be best for many applications.
        See some screenshots for explanation:
        component and path to follow
        straight arraying
        Component stringer. Components don't match properly
        plugins comparison
        • plot-parisP Offline
          plot-paris
          @kostas_designer said:
          ...having the control of the spacing would be best for many applications.
          +1
          Simon, I love your stuff. keep it coming. these show off nicely, what the plugin can do...
          • simon le bonS Offline
            simon le bon
            Hi jeff and Jakob, Thanks for nice words.. So I can be restful: I am not that sort of bat vampirising the threads I sometime feel I am 😕 (my small paranoia I'm afraid.)
            http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/voldragon.gif
            Hi Kostas!
            I'm sorry, I don't understand your problem (I can't see the details of your pictures!).
            Mercy for us, get a real print screen and make close ups 😉
            For me the spacing in a chain is invariant so..
            May be you want to do something like that:
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Kostas.jpg
            If it is the case , you can apply this solution:
            Copy Array Along Path tool...have a look.
            Hi Chris,
            @chris fullmer said:
            You would like to be able to automatically select every 10th pillar in that image for example? Or every 5th pillar? Is that the idea?
            Yes You've got it!
            But I would like be able to do many other various things: may be in this exemple above > put 3 components in place of pillars every 10 pillars...
            This is the reason why I think what we need is mainly a special selecting tool with an incremental feature, (but also an array to select freely into it, and also may be a feature of aleatory choice)
            And very important to be able to do the reverse selection.
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/compteur.jpg
            this way we can -do a first pass, delete what we want to change,
            • Do another pass with the other component and delete everything but the previous holes
              and put the two passes together.
              This way we can do the number of passes we want.
              We can also mix variant and invariant (in direction) components....
            That could be built into my tool, but it would only work with components placed using my tool. But it would be do-able.
            But this special feature would be simply top cool 😉
            🤓 simon
              plot-paris
              actually, that may be a good idea for a different ruby request... a selection tool, that automatically recognizes component arrays (whether distributed on an even grid or along a path...) and then lets you do various selection scenarios. ideally a dialog would pop up that let you change your selections dynamically (or, at least have an update butten, that lets you change selections without closing the dialog)...
                Simon,
                I absolutely love the way you fully exploit these different (and of course, wonderful) tools and model things probably even the author didn't even dream about!
                Cheers and keep posting, please! 👍
                  simon le bon
                  As usual I am tiring everybody with my extensions. I promise that this is the last one. You know , when I begin something I go on surrounds until I can think I have finished. May be those studies will brought some help to someone in some future 😆
                  ../VARIATIONS on Helical matter..
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer015th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer016th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer017th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer018th.jpg
                  The main point to obtain a good result is to work firmly on the curve, in order to give it the real number of segments: individual in orientation and indentical in length
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer019th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer020th.jpg
                  Another variation: Triple use! of Component Stringer 😆
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer021th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer022th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer023th.jpg
                  The result isn't so beautiful 😎 Well, it is just for example
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer024th.jpg
                  simon
                    simon le bon
                    Dear Gaieus
                    http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/matrix-03.gif
                    Your so kind words 😳 me!! 😄
                    +1
                    EscapeArtist (Jeff) shows with his Dna
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EscapeArtist_dna.jpg
                    A very cool other use of what I have in mind with this possible selecting tool:
                    Using sequences of the same component colored differently. In the particular case of a dna, the possibility of selecting elements into an array of data would be probably the most useful..
                    http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/grenouilenenuphar.gif
                    simon
                      simon le bon
                      Hi Chris, Hi SketchY fellows,
                      I'm following Component Stringer Study.
                      Chains are now so easy to produce 👍 👍 😉
                      "Component rotation" = 90° ; Fredoscale by Center
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer010th.jpg
                      Helical study:
                      See Http for some explanation:
                      A PoorFlatEllipsoidIndian Bowl
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer011th.jpg
                      The joints are not welding perfectly, but if we need a good welding, we can use this one as a gauge..
                      "Scaling Uniform"; "Component Rotation" 15°
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer012th.jpg
                      Double use of Component Stringer 😉 😆
                      (With a smart use of "Total Rotation" 15°
                      [flash=500,405:2xup4in2]http://www.youtube.com/v/CEPRPA1TqwY[/flash:2xup4in2]
                      +++Making a straight line as it was a curve in order to use it as the "path" to copy components on.
                      1. a reverse line is added to our line (or else, our line is right clic and divided by minimum two) in order to apply "Weld" because Weld need at least two elements to be applied..
                      2)This welded line is now (Bezier curves installed) right clic converted to segmented polyline.
                      3)Now apply "Component Stringer" on this "straight curve" 😆 "Scaling Stretch" ; "Component Rotation" 15° (in case -15° ❗ )
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer013th.jpg
                      Same action on a Bezier Curve
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer014th.jpg
                      *simon
                      • Bob JamesB Offline
                        Bob James
                        Simon, there's no other word for you but awesome 👍
                        • CarrozzaC Offline
                          Carrozza
                          Men, this plugin with help of fantasy and skills (like Simon') are a killer combo!
                          • Chris FullmerC Offline
                            Hey, looks great Simon. I love the way you dig in and study the plugins. I think its helpful for users to see how they can be used, and its helpful for me to see how people are trying to use these scripts. Helps think of new workflow improvements.
                            In fact, the next version of componet stringer lets you select more than 1 component. And it gives you the option of random placement of all selected, or ordered. So the reandom placement will help in the palisade example you just showed. It would make it quicker to place random boards.
                            The next version will also support series of non-connected edges (I think I already hinted at that earlier) and also supports closed loop selections of lines. It also includes a great little tool to reverse the direction components are "strung". I'm trying to get it all put together for one big release soon.
                            Also, I'm thining about the offset placement possibilities. I'm trying to figure out how that should be implemented. If anyone has any thoughts on how they want to see that work, I'd be interseted in hearing it.
                              simon le bon
                              Thank you Bob & Carrozza ! your encouragement warms my heart..
                              The following is probably the last idea that I wanted to develop With Component Stringer.
                              I dedicate it to our so nice fellow and great author, Chris.
                              It is his:"TOTAL CHRIS FULLMER RANDOM PALISADE"
                              (because made about totally with a set of his own tools 😉 )
                              How to produce a palisade constituted with random singular boards!!
                              My idea is to copy palisade's boards along a path constituted by a random segmented curve Using ComponentStringer/Stretch mode.
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_025th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_026th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_027th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_028th.jpg
                              Using ShapeBender this way: same length for the curve and for the grouped segmented line, the resulting ShapeBender Component keep closely the same lengths of segments inside the curve than those of the segmented line 😉 😉
                              [Plugin] Shape Bender Beta v0.51
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_029th.jpg
                              [Plugin] Select Lines by Length
                              Jim_Selection Memory
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_030th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_031th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_032th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_033th.jpg
                              We delete 3/4 component for each segment( artistically if possible 🤣 )
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_034th.jpg
                              Et voila votre jolie pallissade ☀
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_035th.jpg
                              Dear Chris,dear all,
                              with my very friendship..
                              😄 simon.
                                simon le bon
                                  Suggestion
                                  A rotation (s) of object on it own axis?
                                  A scale of object?
                                    plot-paris
                                    wow, Chris. thats sounds like a reason (or several for that matter) to be excited about the next release... 🎉
                                    • H Offline
                                      hsjzyangbin
                                      Hi,Chris,I wish your 'Component Stringer'and TIG'S "GROW.RB" combine together
                                      • mitcorbM Offline
                                        mitcorb
                                        Chris:
                                        When using the uniform scale parameter, does the script start out with a set multiple? I am guessing say 1.5 x the scale of the component? and then the factor is applied to each subsequent component instance?
                                        If this is so, would there be a user changeable scale factor parameter in the future?
                                        By the way, this is a nice tool and I appreciate your sharing it.
                                          Hmm, good idea. That is not the way it works, but it would be fairly easy to implement (I think). No guarantees how fast I'll get it done, but I'll try to put this feature in the mext release.
                                          • JClementsJ Offline
                                            JClements
                                            In the attached I have component which I have attempted to string along a path in an orientation similar to that of the component. I've played with changing the component's axis but can't seem to get it right by only changing the component axis (rotating the component and then reseting its axis can work).
                                            Chris, what is the secret? Your video mentions setting the blue axis but what of the red and green and at what corner of the component?
                                            Signed, all strung out.
                                            John
                                            STRINGER - What are the rules to getting component oriented on path correctly.skp
                                            • 4 / 9
