    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 314.4k Views 135 Watching
    • plot-parisP Offline
      plot-paris
      another one. after importing a messy 3Ds model and cleaning it up with Thomthoms cleanup-script (thanks again, thom), I started entering every single one of the over 1500 groups/components, to smooth their surfaces.
      then I just discovered, that you can apply the smoothing to groups/components, without entering them. so you can select all the groups at once and only have to do the proces once! (doesn't work with nested groups though)
        I recently discovered that as well!
        In regards to CleanUp - it does have a function to smooth the geometry it cleans up. If you use CleanUp Entire Model you have a field "Smooth Edges by Angle".
          plot-paris
          yet another 'Doh'
          I can put my Homer button to quite some use today ๐Ÿ˜„
            @plot-paris said:
            oh, that is a really bad one, Gaieus! I am not sure if I should burst with laughter ๐Ÿคฃ , feel terribly sorry for you ๐Ÿ˜ž or just blush with embarassment, because that could just as well have happened to me ๐Ÿ˜ณ
            Well, eventually it turned out that the total HD was broken so no matter what I would've done, the repair/install wouldn't have been successful. Had to buy a new HD and reinstall everything again. ๐Ÿ˜ข
              plot-paris
              uh, thats bad!
              actually, I still try to deny that hard discs just die after several years of intenseive use. its not pleasant, when the truth catches up with you...
              • broomstickB Offline
                broomstick
                I just discovered that the erase function hides and smoothes edges if you use it in combination with atl ctrl an shift...
                DUH!!
                • E Offline
                  Ecuadorian
                  Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. ๐Ÿ˜ฒ
                  -Miguel Lescano
                    ๐Ÿ‘ Tricky and speedy ๐Ÿ˜Ž
                    • Chris FullmerC Offline
                      I just discovered that you can use more than one modifier key when setting up shortcut keys. example
                      ctrl + shift + alt + Q
                      or snything along those lines. I never reazlied that... ๐Ÿ˜ณ
                        plot-paris
                        just out of interest: what function did you assign to
                        Ctrl + Shift + Alt + Q???
                          When I press that, it triggers an automatic poking of you on Facebook.
                          ๐Ÿคฃ
                          (I dare not try if there is anything assigned to it by default because I am rendering an animation) ๐Ÿ˜•
                            It is my auto-assinate button in SU ๐Ÿ˜„
                            I don't really have it assigned to anything. It was just an example of how complex a "shortcut" could be. I thought I was stuck to simple single modifiers. Double modifiers could greatly expand my shortcut range though!
                            • mitcorbM Offline
                              mitcorb
                              Now, what would an "auto-assinate" button do, exactly?
                              Hee Hee!
                                I struggle...
                                  A list of shortcuts ๐Ÿ’š
                                    Triangulate a simple rectangle surface with the Sand box? ๐Ÿ˜ณ
                                    Just draw a diagonal first! ๐Ÿ˜ฎ
                                    Then apply the Sand box "Add dรฉtails" ๐Ÿ’š
                                      A cool one! ๐Ÿ˜ณ
                                      The Duhduh of the day! Never used! ๐Ÿ˜’
                                      Thx Jeff โ˜€
                                      http://forums.sketchucation.com/download/file.php?id=41868&mode=view
                                        KXI System
                                        ๐Ÿคฃ
                                        Thing was, the people who I looked up to as pro's...
                                        Are the ones that had the most "duh!"s
                                        ๐Ÿคฃ
                                        Getting the perfect sig is hard...
                                        Google it!
                                          That's because only those who thinkhave genuine doh moments... ๐Ÿ˜’
                                          • ely862meE Offline
                                            ely862me
                                            ๐Ÿ˜„
                                            Elisei (sketchupper)
                                            Come and See EliseiDesign
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
