    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
    • plot-parisP
      plot-paris
      oh, that is a really bad one, Gaieus! I am not sure if I should burst with laughter ๐Ÿคฃ , feel terribly sorry for you ๐Ÿ˜ž or just blush with embarassment, because that could just as well have happened to me ๐Ÿ˜ณ
      • plot-parisP
        plot-paris
        another one. after importing a messy 3Ds model and cleaning it up with Thomthoms cleanup-script (thanks again, thom), I started entering every single one of the over 1500 groups/components, to smooth their surfaces.
        then I just discovered, that you can apply the smoothing to groups/components, without entering them. so you can select all the groups at once and only have to do the proces once! (doesn't work with nested groups though)
          I recently discovered that as well!
          In regards to CleanUp - it does have a function to smooth the geometry it cleans up. If you use CleanUp Entire Model you have a field "Smooth Edges by Angle".
          • plot-parisP
            plot-paris
            yet another 'Doh'
            I can put my Homer button to quite some use today ๐Ÿ˜„
            • GaieusG
              Well, eventually it turned out that the total HD was broken so no matter what I would've done, the repair/install wouldn't have been successful. Had to buy a new HD and reinstall everything again. ๐Ÿ˜ข
              • plot-parisP
                plot-paris
                uh, thats bad!
                actually, I still try to deny that hard discs just die after several years of intenseive use. its not pleasant, when the truth catches up with you...
                • broomstickB
                  broomstick
                  I just discovered that the erase function hides and smoothes edges if you use it in combination with atl ctrl an shift...
                  DUH!!
                  • E
                    Ecuadorian
                    Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. ๐Ÿ˜ฒ
                    -Miguel Lescano
                      ๐Ÿ‘ Tricky and speedy ๐Ÿ˜Ž
                      • Chris FullmerC
                        I just discovered that you can use more than one modifier key when setting up shortcut keys. example
                        ctrl + shift + alt + Q
                        or snything along those lines. I never reazlied that... ๐Ÿ˜ณ
                        • plot-parisP
                          plot-paris
                          just out of interest: what function did you assign to
                          Ctrl + Shift + Alt + Q???
                          • GaieusG
                            When I press that, it triggers an automatic poking of you on Facebook.
                            ๐Ÿคฃ
                            (I dare not try if there is anything assigned to it by default because I am rendering an animation) ๐Ÿ˜•
                            • Chris FullmerC
                              It is my auto-assinate button in SU ๐Ÿ˜„
                              I don't really have it assigned to anything. It was just an example of how complex a "shortcut" could be. I thought I was stuck to simple single modifiers. Double modifiers could greatly expand my shortcut range though!
                              • mitcorbM
                                mitcorb
                                Now, what would an "auto-assinate" button do, exactly?
                                Hee Hee!
                                • Chris FullmerC
                                  I struggle...
                                    A list of shortcuts ๐Ÿ’š
                                      Triangulate a simple rectangle surface with the Sand box? ๐Ÿ˜ณ
                                      Just draw a diagonal first! ๐Ÿ˜ฎ
                                      Then apply the Sand box "Add dรฉtails" ๐Ÿ’š
                                        A cool one! ๐Ÿ˜ณ
                                        The Duhduh of the day! Never used! ๐Ÿ˜’
                                        Thx Jeff โ˜€
                                        http://forums.sketchucation.com/download/file.php?id=41868&mode=view
                                        • K
                                          KXI System
                                          ๐Ÿคฃ
                                          Thing was, the people who I looked up to as pro's...
                                          Are the ones that had the most "duh!"s
                                          ๐Ÿคฃ
                                          Getting the perfect sig is hard...
                                          Google it!
                                          • GaieusG
                                            That's because only those who thinkhave genuine doh moments... ๐Ÿ˜’
                                            • 11
                                            • 34
                                            • 35
                                            • 9 / 35
