    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 390.4k Views 135 Watching
    • plot-parisP Offline
      plot-paris
      @thomthom said:
      In regards to CleanUp - it does have a function to smooth the geometry it cleans up. If you use CleanUp Entire Model you have a field "Smooth Edges by Angle".
      yet another 'Doh'
      I can put my Homer button to quite some use today ๐Ÿ˜„
        @plot-paris said:
        oh, that is a really bad one, Gaieus! I am not sure if I should burst with laughter ๐Ÿคฃ , feel terribly sorry for you ๐Ÿ˜ž or just blush with embarassment, because that could just as well have happened to me ๐Ÿ˜ณ
        Well, eventually it turned out that the total HD was broken so no matter what I would've done, the repair/install wouldn't have been successful. Had to buy a new HD and reinstall everything again. ๐Ÿ˜ข
          plot-paris
          uh, thats bad!
          actually, I still try to deny that hard discs just die after several years of intenseive use. its not pleasant, when the truth catches up with you...
          • broomstickB Offline
            broomstick
            I just discovered that the erase function hides and smoothes edges if you use it in combination with atl ctrl an shift...
            DUH!!
            • E Offline
              Ecuadorian
              Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. ๐Ÿ˜ฒ
              -Miguel Lescano
                ๐Ÿ‘ Tricky and speedy ๐Ÿ˜Ž
                • Chris FullmerC Offline
                  I just discovered that you can use more than one modifier key when setting up shortcut keys. example
                  ctrl + shift + alt + Q
                  or snything along those lines. I never reazlied that... ๐Ÿ˜ณ
                    plot-paris
                    just out of interest: what function did you assign to
                    Ctrl + Shift + Alt + Q???
                      When I press that, it triggers an automatic poking of you on Facebook.
                      ๐Ÿคฃ
                      (I dare not try if there is anything assigned to it by default because I am rendering an animation) ๐Ÿ˜•
                        It is my auto-assinate button in SU ๐Ÿ˜„
                        I don't really have it assigned to anything. It was just an example of how complex a "shortcut" could be. I thought I was stuck to simple single modifiers. Double modifiers could greatly expand my shortcut range though!
                        • mitcorbM Offline
                          mitcorb
                          Now, what would an "auto-assinate" button do, exactly?
                          Hee Hee!
                            I struggle...
                              A list of shortcuts ๐Ÿ’š
                                Triangulate a simple rectangle surface with the Sand box? ๐Ÿ˜ณ
                                Just draw a diagonal first! ๐Ÿ˜ฎ
                                Then apply the Sand box "Add dรฉtails" ๐Ÿ’š
                                  A cool one! ๐Ÿ˜ณ
                                  The Duhduh of the day! Never used! ๐Ÿ˜’
                                  Thx Jeff โ˜€
                                  http://forums.sketchucation.com/download/file.php?id=41868&mode=view
                                    KXI System
                                    ๐Ÿคฃ
                                    Thing was, the people who I looked up to as pro's...
                                    Are the ones that had the most "duh!"s
                                    ๐Ÿคฃ
                                    Getting the perfect sig is hard...
                                    Google it!
                                      That's because only those who thinkhave genuine doh moments... ๐Ÿ˜’
                                      • ely862meE Offline
                                        ely862me
                                        ๐Ÿ˜„
                                        Elisei (sketchupper)
                                        Come and See EliseiDesign
                                          KXI System
                                          OK, I'll share a duh moment.
                                          THE COMPONENT DIALOG BOX IS JUST A MINI 3-D WAREHOUSE WINDOW!
                                          I found out by trying to search for a component and ended up with the same search results as the first page in the 3-D warehouse.
                                          WARNING, THE FOLLOWING DUH MOMENT IS PROVEN TO DECREASE PRODUCTION BY 1000%!
                                          OK, first I found one of the antics figures off the warehouse (not through the component dialog window). Now all antic models have a link to the same youtube video, so I clicked on it and next thing you know I have youtube fully working inside sketchup! ๐Ÿ˜† I got nothing done that day...
                                          Google it!
                                            Jim
                                            Just learned the physical size of the SU window matters when trying to print to scale.
                                            No matter what I did I could not get my unscaled print on a single page, even though it would have easily fit on a single page. After making the SU window narrower than the height, SketchUp decided it would fit a a single sheet after all.
                                            • 11
                                            • 34
                                            • 35
                                            • 9 / 35
