    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
      Select the edges and and activate offset...
      • EscapeArtistE
        EscapeArtist
        @plot-paris said:
        wow, cool. didn't know about that eihter. but what I would even more like to see is a push/pull like this:
        [attachment=0:37plearv]<!-- ia0 -->strange_pushpull.jpg<!-- ia0 -->[/attachment:37plearv]
        It exists! Here: http://forums.sketchucation.com/viewtopic.php?f=180&t=23341
        • E
          Ecuadorian
          I was working in a "mysterious" file that did not allow me to pushpull anything, and I was about to post the mysterious file here. After checking, "Snap to length" was set to a very high value. Duh!
          -Miguel Lescano
          • Chris FullmerC
            I just found one for me tonight. I change the model axis pretty often when I work. But I never noticed that you can activate the axis tool (or change axis inside of a component tool) and click twice somewhere and it will move the axis to that point without changing its orientation. Normally I would have clicked once, then lined up the the axes and click and line up and click. So a double click (not too fast though!) is much faster for moving the axis.
              Select an element (lines, surface)
              Open Entity Info yes ๐Ÿ˜‰
              Then when you select with Shift , Shift + Ctrl or Ctrl
              all surfaces or length lines are added , subbstracted, modified, visible and updated in the Entity info! ๐Ÿ˜„ ๐Ÿ˜’
              • GaieusG
                OK, this is a very painful duh:
                My system seemed to crash and I could not even start windows in safe mode (Mac users, don't sneer, please) so I decided to at least try to repair my system. It didn't allow me as whatever imaginable I entered, it didn't accept it as the password of the system admin.
                So I reinstalled (I have a recent backup of my documents at least). Then I realised that I didn1t even have a password and should have just hit Enter without entering any password.
                ๐Ÿ˜ณ
                So basically this is what I wasted my Sunday for. I have a deadline tomorrow. ๐Ÿ˜•
                • plot-parisP
                  plot-paris
                  oh, that is a really bad one, Gaieus! I am not sure if I should burst with laughter ๐Ÿคฃ , feel terribly sorry for you ๐Ÿ˜ž or just blush with embarassment, because that could just as well have happened to me ๐Ÿ˜ณ
                  • plot-parisP
                    plot-paris
                    another one. after importing a messy 3Ds model and cleaning it up with Thomthoms cleanup-script (thanks again, thom), I started entering every single one of the over 1500 groups/components, to smooth their surfaces.
                    then I just discovered, that you can apply the smoothing to groups/components, without entering them. so you can select all the groups at once and only have to do the proces once! (doesn't work with nested groups though)
                      I recently discovered that as well!
                      In regards to CleanUp - it does have a function to smooth the geometry it cleans up. If you use CleanUp Entire Model you have a field "Smooth Edges by Angle".
                      • plot-parisP
                        plot-paris
                        yet another 'Doh'
                        I can put my Homer button to quite some use today ๐Ÿ˜„
                        • GaieusG
                          Well, eventually it turned out that the total HD was broken so no matter what I would've done, the repair/install wouldn't have been successful. Had to buy a new HD and reinstall everything again. ๐Ÿ˜ข
                          • plot-parisP
                            plot-paris
                            uh, thats bad!
                            actually, I still try to deny that hard discs just die after several years of intenseive use. its not pleasant, when the truth catches up with you...
                            • broomstickB
                              broomstick
                              I just discovered that the erase function hides and smoothes edges if you use it in combination with atl ctrl an shift...
                              DUH!!
                              • E
                                Ecuadorian
                                Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. ๐Ÿ˜ฒ
                                -Miguel Lescano
                                  ๐Ÿ‘ Tricky and speedy ๐Ÿ˜Ž
                                  • Chris FullmerC
                                    I just discovered that you can use more than one modifier key when setting up shortcut keys. example
                                    ctrl + shift + alt + Q
                                    or snything along those lines. I never reazlied that... ๐Ÿ˜ณ
                                    • plot-parisP
                                      plot-paris
                                      just out of interest: what function did you assign to
                                      Ctrl + Shift + Alt + Q???
                                      • GaieusG
                                        When I press that, it triggers an automatic poking of you on Facebook.
                                        ๐Ÿคฃ
                                        (I dare not try if there is anything assigned to it by default because I am rendering an animation) ๐Ÿ˜•
                                        • Chris FullmerC
                                          It is my auto-assinate button in SU ๐Ÿ˜„
                                          I don't really have it assigned to anything. It was just an example of how complex a "shortcut" could be. I thought I was stuck to simple single modifiers. Double modifiers could greatly expand my shortcut range though!
                                          • mitcorbM
                                            mitcorb
                                            Now, what would an "auto-assinate" button do, exactly?
                                            Hee Hee!
                                            • 34
                                            • 35
                                            • 8 / 35
