    New API doc - typos and questions
    370 Posts 35 Posters 264.0k Views 35 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      UI.toolbar_names
      http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#toolbar_names
      The toolbar_names method is used to returns the name of all the available toolbars (this differs between PC and Mac).
      (1) In the above sentence "returns" should be singular.
      (2) I believe punctuation marks are supposed to go at the end of the words, ie: "Mac.)" not "Mac)." ...Language majors, confirm?
      (3) It would nice if we are to do cross-platform scripts, that you list the names for PC and Mac in the API.
      (4) UI.toolbar_names.sort on the PC, ver 7.1 returns:
      ["Camera", "Construction", "DisplayMode", "Drawing", "Edit", "GettingStarted", "Google", "Principle", "Section", "Standard", "StandardViews", "VCB", "Walk"]
      On the [Win32] Sketchup Menu: View > Toolbars(and toolbar captions):
      • Principle is Principal* Edit is Modification* VCB is Measurements* StandardViews is Views* Section is Sections* DisplayMode is FaceStyle* Walk is Walkthrough
        These are on the [Win32] Menu: View > Toolbars but, missing from the UI toolbar methods:
      • LargeToolSet* Layers* SceneTabs (on View menu )* Shadows
        Missing from View Menu and toolbar methods:
      • StatusBar
        (We can toggle it on/off [with send_action on PC], so might as well add it to the toolbar methods so we can test it's visiblilty, and use set_toolbar_visible for cross platform [if it can be toggled on MAC.])* If a user has the StatusBar off, a tool might want to instead display a messagebox if it must inform the user of some fact, so it needs to test whether it's on/off.
      (5) This same Toolbar Name Identifier Set is used with the following methods, and have the same problems, missing Identifiers, etc.
      • UI.set_toolbar_visible* UI.toolbar_visible?
      So.. we don't mind variation in the toolbar names/symbols, so long as we know what that variation is.
      (An alternative... we might create tb_Name constants under the UI module that would be the same for both platforms.)
      I'm not here much anymore.
        Entities.add_curve
        http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_curve
        Returns:
        curve a Curve object if successful
        SU7.1M1 PC returns an array of edges. Other versions untested. I'm submitting this as a bug.
          Curve.move_vertices
          http://code.google.com/apis/sketchup/docs/ourdoc/curve.html#move_vertices
          The vertices method retrieves a collection of all vertices in a curve.
          Seem to have copied the text from Curve.vertices.
          Description needs updating along with an example.
            @thomthom said:
            Entities.add_curve
            Returns:
            It's always returned an array of edges - the curve is then array[0].curve
              Dan Rathbun
              _
              Model.title
              The tile method retrieves the name of the model. If the model is saved on disk, returns the file name without extension. Otherwise returns an empty string.
              http://code.google.com/apis/sketchup/docs/ourdoc/model.html#title
              Change 'tile' to 'title' in method description.
              We could use Model.is_saved? and Model.is_unsaved? methods, as the Model.title method is the only way (that I can find) to determine if the model has yet been saved or not. We cannot rely upon the word 'Untitled' (in the caption bar) because that may actually be a valid filename.
              Workaround:
              class Sketchup;;Model
              def is_saved?
                return not title.empty?
              def is_unsaved?
                return title.empty?
              end # class
              _
                Camera.set
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#set
                The initialize method is deprecated. It essentially does the same thing as Camera.set.
                Seems that's the description for Camera.new http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#new
                ...and that Camera.new has the description for Camera.set
                  View.pickray
                  http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
                  Returns:
                  ray
                  a ray
                  "a ray"? Without testing this I#m guessing either a vector or line.
                    Dan Rathbun
                    @thomthom said:
                    View.pickray
                    Returns:
                    ray a ray
                    see this...
                    Model.raytest
                    A ray is a two element array containing a point and a vector [Geom::Point3d(), Geom::Vector3d()]. http://code.google.com/apis/sketchup/docs/ourdoc/model.html#raytest
                    _
                      Yea - I tested it later that day. It's what the Geom module describes as a line.
                        Dan Rathbun
                        Shouldn't the API have a definition for Line and/or Ray as a class (under the Geom module) ?
                        something like:
                        class Geom;;Ray < Array
                          def new(*args)
                            Array[Geom;;Point3d().new, Geom;;Vector3d().new]
                            super()
                          Line and Plane? hm... maybe... thought of that myself. but never really felt the need for it to make a request. works fine as it is.
                          Dealing with them as Arrays works ok. They are simple structures.
                            Dan Rathbun
                            Model.add_note
                            The note is not displayed unless there are entities in the model. If you add a note first thing in a new model, it is invisible but .visible? on the note object still returns true.
                            As soon as you draw something, the note appears.
                              Jim
                              Thanks Dan - yet more never-seen-before docs coming to light.
                                I have the mental image of Scott drowning in printouts from this thread... πŸ˜’ πŸ˜†
                                  Jim
                                  Oh, I think there is a completely undocumented UTM class in there somewhere under Geom.
                                    hm.. all I can find out about that one is:
                                    Geom::UTM.instance_methods.sort.join("\n") (eval):894: warning: instance_methods: parameter will default to 'true' as of 1.8.1 to_a to_latlong to_s x y zone_letter zone_number
                                      Jim
                                      View.show_frame
                                      Documentation for this method contains some poorly-parsed html tags.
                                        Dan Rathbun
                                        Geom::UTM.instance_methods.sort.join("\n")... snip ...
                                        from Wikipedia search on "UTM":
                                        Universal Transverse Mercator coordinate system, a grid-based method of mapping locations on the surface of the Earth.
                                        http://en.wikipedia.org/wiki/Universal_Transverse_Mercator_coordinate_system
                                        _
                                          Dan Rathbun
                                          Model.get_product_family
                                          http://code.google.com/apis/sketchup/docs/ourdoc/model.html#get_product_family
                                          Returns a constant number which indicates the product family of the installed SketchUp application.
                                          This is an Application related attribute, why is it part of the Model class?
                                          This should be a method of the Sketchup module as in: Sketchup.get_product_family
                                          _
                                            Dan Rathbun
                                            Model.export
                                            http://code.google.com/apis/sketchup/docs/ourdoc/model.html#export
                                            options_hash______ A hash containing the COLLADA (.dae) export options.
                                            The options listed in the hash example is missing the option for hidden geometry.
                                            The Registry Attribute Name is "ExportHiddenGeometry", but what is the options hash key?
                                            • hiddengeometry ?* hidden_geometry ?
                                              _
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 15 / 19
