    New API doc - typos and questions
    370 Posts 35 Posters 269.9k Views 35 Watching
      @dan rathbun said:
      Point3d.<
      http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#%3C
      Returns:
      true if the point2 is closer to the origin.
      Following the example, I get he opposite result.
      The Returns: should probably read,
      " *true* if the point2 is **farther** from the origin; *false* if the point2 is closer to the origin (than the receiver.)
      And the anchor link http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/point3d.html#%3C doesn't work for me under FF3.5. Might be due to the < character.
      • Dan RathbunD Offline
        Dan Rathbun
        I suggest the Google webmeister change the anchor to "#lessthan" instead of "#%3C".
        I would suspect that links to - and + methods may have problems with some browsers as well.
        I'm not here much anymore.
          The id for the anchor is invalid.
          The correct format is:
          http://www.w3.org/TR/html4/types.html#type-name
          ID and NAME tokens must begin with a letter ([A-Za-z]) and may be followed by any number of letters, digits ([0-9]), hyphens ("-"), underscores ("_"), colons (":"), and periods (".").
          There are a number of other HTML errors as well. They use a XHTML doctype, but empty elements is not closed with />. Looks like HTML is used - despite the doctype.
          The HTTP header claims characterset ISO-8859-1 while the META tag claims UTF-8
          Characters isn't escaped properly, such as the < character in the method list. (line 342)
          Run it through the validator and see 67 errors. http://validator.w3.org/check?uri=http%3A%2F%2Fcode.google.com%2Fintl%2Fnb%2Fapis%2Fsketchup%2Fdocs%2Fourdoc%2Fpoint3d.html&charset=%28detect+automatically%29&doctype=Inline&ss=1&group=0&user-agent=W3C_Validator%2F1.654#line-342
          No wonder things isn't always working when there's so much invalid markup.
          • scottliningerS Offline
            scottlininger
            Thanks for all the feedback, Dan! Keep 'em coming.
            • Scott Lininger
              SketchUp Software Engineer
              Have you visited the Ruby API Docs?
              How is your to-do list compared to Santa's list? πŸ˜†
                scottlininger
                Santa's got nothing on me. πŸ˜‰
                • Scott Lininger
                  Edge.reversed_in?
                  http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/edge.html#reversed_in?
                  Why is the example using a begin rescue structure? Does it on occasion cause errors?
                    Dan Rathbun
                    The class Sketchup::HLR is undocumented in the API.
                    It's an Entity subclass.
                    It inherits all the Entity baseclass methods, and adds 2 of it's own:
                    • .calculate* .num_faces
                    If you create a HLR object at the console, and call .parent (when it has no parent) a BUG SPLAT! results. See post: http://forums.sketchucation.com/viewtopic.php?f=11&t=24740#p212101
                    What is this class HLR used for? (.. as there is no .add_HLR method for the Entities collection object.)
                      Tool.getExtents
                      http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#getExtents
                      The example given isn't a good one. From my observations, clipping occurs only when you draw outside the model boundary. So returning model.bounds is pointless.
                        Dan Rathbun
                        Sketchup.send_action
                        http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#send_action
                        You can toggle the StatusBar on/off in Ruby (PC only?) via:
                        Sketchup.send_action(59393)
                        The following have no effect on my PC in SU ver 7.1.x:
                        Sketchup.send_action(21019) hide Status bar and VCB
                        Sketchup.send_action(21020) show Status bar and VCB
                        Sketchup.send_action(21022) hide Status bar and VCB?
                        ..whereas the above id 59393 does work for just the StatusBar.
                        [ NOTE: I've moved my VCB up to the 2nd line of the Top Toolbar Container in 2nd position after the Layers toolbar, so I'd not want the VCB turned off with the StatusBar anyhow. I see them as two different things. ]
                          Dan Rathbun
                          @dan rathbun said:
                          (An alternative... we might create tb_Name constantsunder the UI module that would be the same for both platforms.)
                          Here's an example, call it 'UI_tb_const.rb'
                          module UI
                          # Example ONLY
                          case Sketchup;;OS
                          when ;WIN
                            tb_CAM = 'Camera'.freeze
                            tb_CONS = 'Construction'.freeze
                            tb_DISP = 'DisplayMode'.freeze
                            tb_DRAW = 'Drawing'.freeze
                            tb_EDIT = 'Edit'.freeze
                            tb_GETS = 'GettingStarted'.freeze
                            tb_GOOG = 'Google'.freeze
                            tb_LTS = 'LargeToolSet'.freeze
                            tb_LAYR = 'Layers'.freeze
                            tb_STD = 'Standard'.freeze
                            tb_TABS = 'SceneTabs'.freeze
                            tb_PRIN = 'Principle'.freeze # spelling!
                            tb_SBAR = 'StatusBar'.freeze
                            tb_SECT = 'Section'.freeze
                            tb_SHAD = 'Shadows'.freeze
                            tb_VIEW = 'StandardViews'.freeze
                            tb_VCB = 'VCB'.freeze
                            tb_WALK = 'Walk'.freeze
                          when ;OSX
                          	#     what are the Mac Strings?
                          end # case
                          end # module UI extension
                            Dan Rathbun
                            UI.toolbar_names
                            http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#toolbar_names
                            The toolbar_names method is used to returns the name of all the available toolbars (this differs between PC and Mac).
                            (1) In the above sentence "returns" should be singular.
                            (2) I believe punctuation marks are supposed to go at the end of the words, ie: "Mac.)" not "Mac)." ...Language majors, confirm?
                            (3) It would nice if we are to do cross-platform scripts, that you list the names for PC and Mac in the API.
                            (4) UI.toolbar_names.sort on the PC, ver 7.1 returns:
                            ["Camera", "Construction", "DisplayMode", "Drawing", "Edit", "GettingStarted", "Google", "Principle", "Section", "Standard", "StandardViews", "VCB", "Walk"]
                            On the [Win32] Sketchup Menu: View > Toolbars(and toolbar captions):
                            • Principle is Principal* Edit is Modification* VCB is Measurements* StandardViews is Views* Section is Sections* DisplayMode is FaceStyle* Walk is Walkthrough
                              These are on the [Win32] Menu: View > Toolbars but, missing from the UI toolbar methods:
                            • LargeToolSet* Layers* SceneTabs (on View menu )* Shadows
                              Missing from View Menu and toolbar methods:
                            • StatusBar
                              (We can toggle it on/off [with send_action on PC], so might as well add it to the toolbar methods so we can test it's visiblilty, and use set_toolbar_visible for cross platform [if it can be toggled on MAC.])* If a user has the StatusBar off, a tool might want to instead display a messagebox if it must inform the user of some fact, so it needs to test whether it's on/off.
                            (5) This same Toolbar Name Identifier Set is used with the following methods, and have the same problems, missing Identifiers, etc.
                            • UI.set_toolbar_visible* UI.toolbar_visible?
                            So.. we don't mind variation in the toolbar names/symbols, so long as we know what that variation is.
                            (An alternative... we might create tb_Name constants under the UI module that would be the same for both platforms.)
                              Entities.add_curve
                              http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_curve
                              Returns:
                              curve a Curve object if successful
                              SU7.1M1 PC returns an array of edges. Other versions untested. I'm submitting this as a bug.
                                Curve.move_vertices
                                http://code.google.com/apis/sketchup/docs/ourdoc/curve.html#move_vertices
                                The vertices method retrieves a collection of all vertices in a curve.
                                Seem to have copied the text from Curve.vertices.
                                Description needs updating along with an example.
                                  @thomthom said:
                                  Entities.add_curve
                                  Returns:
                                  It's always returned an array of edges - the curve is then array[0].curve
                                    Dan Rathbun
                                    _
                                    Model.title
                                    The tile method retrieves the name of the model. If the model is saved on disk, returns the file name without extension. Otherwise returns an empty string.
                                    http://code.google.com/apis/sketchup/docs/ourdoc/model.html#title
                                    Change 'tile' to 'title' in method description.
                                    We could use Model.is_saved? and Model.is_unsaved? methods, as the Model.title method is the only way (that I can find) to determine if the model has yet been saved or not. We cannot rely upon the word 'Untitled' (in the caption bar) because that may actually be a valid filename.
                                    Workaround:
                                    class Sketchup;;Model
                                    def is_saved?
                                      return not title.empty?
                                    def is_unsaved?
                                      return title.empty?
                                    end # class
                                    _
                                      Camera.set
                                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#set
                                      The initialize method is deprecated. It essentially does the same thing as Camera.set.
                                      Seems that's the description for Camera.new http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#new
                                      ...and that Camera.new has the description for Camera.set
                                        View.pickray
                                        http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
                                        Returns:
                                        ray
                                        a ray
                                        "a ray"? Without testing this I#m guessing either a vector or line.
                                          Dan Rathbun
                                          @thomthom said:
                                          View.pickray
                                          Returns:
                                          ray a ray
                                          see this...
                                          Model.raytest
                                          A ray is a two element array containing a point and a vector [Geom::Point3d(), Geom::Vector3d()]. http://code.google.com/apis/sketchup/docs/ourdoc/model.html#raytest
                                          _
                                            Yea - I tested it later that day. It's what the Geom module describes as a line.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 18
                                            • 19
                                            • 13 / 19
