    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 277.6k Views 32 Watching
    • Chris FullmerC
      Sorry Rod, I've been sick and have not been doing too much.
      So I don't know what the problem is, but these scripts open the ruby concole while the scripts are loading, so we can see any load errors. So please overwrite the existing files with these. And copy any text that gets written to the ruby console when SketchUp is starting. Then paste that code back here.
        rod1233
        This was the result
        • Chris FullmerC
          OK Rod, I think I've found a solution. Please download and overwrite this file sindei the clf_camera_recorder folder. Please oh Please tell me this works.
            @@path.gsub!( /\//, "\\\\" ) if @@pc
            around line #53, seems a heavy handed [wrong] way to replace all of the PC's filepath's / separators with a \ the tr way might be safer/easier to see...
            @@path.tr("/","\\")if @@pc
              Jim
              What's wrong with gsub, and how is tr safer and easier?
                in that example you do save a few characters. And you avoid the overhead of rexex processing. if it is simple text or character replacement it is faster to do plain text replace than invoking regex.
                • Chris FullmerC
                  I was not aware of the .tr method. I had only seen gsub, and I was able to get it to work. But I like the way .tr works. It looks much simpler. It took me hours and hours to wrap my head around how slashes work and escaping characters with lots of help. I'm sure I don't understand it all yet. But just having it work made me happy.
                  So the problem in this script that I was fixing is that I was storing forward slashes into the Windows registry. It seems to work fine on most computers. But not Rod's. His Vista won't handle forward slashes at all. Anyone know what might be making his system work like that?
                  PS I still don't know if these tweaks fixed it for Rod - I sure hope it did. Because I'm about out of ideas otherwise.....
                    The .tr is somewhat different though. But can be used in this case.
                    .gsub can also be used without using regex for pattern.
                    • Chris FullmerC
                      Oh yeah, I also meant to ask:
                      What is regex?
                        Something which turns my brain into liquid goo.
                          Generic Regex info: http://www.regular-expressions.info/index.html
                          Ruby related: http://www.regular-expressions.info/ruby.html
                            rod1233
                            This is the result :
                            Error Loading File clf_camera_recorder.rb
                            private method gsub 'called for nil: NilClassprivate method gsub!' called for nil: NilClassError Loading File clf_camera_recorder_loader.rb
                            private method `gsub! ' called for nil: NilClass
                            I am very sad because I did that I had that tool
                            Note: In this strange problem I succeeded for the first time and then I got this problem.
                            rod
                            • K
                              KXI System
                              Can you have anyway for this plugin to export as a movie file too?
                              If you can thanks! but I know its gonna be hard.
                              Getting the perfect sig is hard...
                              Google it!
                              • Chris FullmerC
                                @Rod - ok, I think I know a surefire way to fix your problem. I'll try to get a script out tonight or tomorrow. But I am going to disable the script's ability to remember a location to save the image files, since that is what seems to be causing the problems.
                                @KXI - I agree that would be cool. If I implement it will probably cost something.
                                Anyone out there know a free ruby library that compiles sequence images into a video? Would I be able to do it with the command line mplayer? Or doies imagemagik support anything beyond animated .gifs?
                                  rod1233
                                  I am waiting for what will be the solution
                                  And thank you
                                  rod
                                  • Chris FullmerC
                                    OK Rod, try this one now. overwrite the clf_camera_recorder.rb file that is inside the clf_camera_recoreder folder.
                                    Also, it should pop up a little message while loading. I would like to know what it says on your system. Thanks!
                                    • K
                                      KXI System
                                      ok, but Chris can you at least tell me a free program that acts like Quick time pro (the feature that this plugin uses)?
                                      Google it!
                                      • Chris FullmerC
                                        Yes, a few pages ( http://forums.sketchucation.com/viewtopic.php?f=323&t=23517&st=0&sk=t&sd=a&start=60#p208742 ) back Charly mentioned a free program. I meant to ad it to the first post, and never did. It is called Imagen:
                                        http://gromada.com/download.html
                                        Try that one!
                                          rod1233
                                          We have succeeded, my friend
                                          Thank you for all the efforts 😍 😍
                                          You are truly wonderful
                                          Thank you again
                                          rod
                                          • Chris FullmerC
                                            Great, now I need to clean up the scripts for you again so they stop popping up windows everytime you open SketchUp with messages to relay back to me.
                                            Also, what does the pop up window say in it?
                                            And check back here hopefully today for an update on the scripts for you
                                            • 5 / 7
