    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 267.5k Views 32 Watching
      rod1233
      Here's what you requested
      This folder contains the files
        rod1233
        Where are you?
        I hope you of what is new
        rod
          rod1233
          Where are you?
          rod
            rod1233
            • Chris FullmerC Offline
              Sorry I missed your post yesterday. Somehiw I did not see it, sorry Rod. I have the files now and I am looking at them (I deleted the .rar file from your post alre4ady, but I downloaded it first).
                OK, it is all installed right, thanks you so much for uploading that.
                One last idea. Try this loader script. Just overwrite the existing clf_camera_recorder_loader.rb file with the attached one. Let me know if that works,
                PS - this file is not MAC friendly. I think it will break the script if anyone on a Mac downloads it.
                • PixeroP Offline
                  Pixero
                  Chris, have you tried LightUp? Could you implement a flyaround mode with inertia like in LightUp?
                  It would be so great to fly around smoothly and record scenes and then use that for both SU lines and LightUp.
                  Pleeeeaaase? πŸ˜„
                    rod1233
                    hi Chris
                    Thank you for your patience.
                    But unfortunately the problem did not end
                    I barely said Volkswagen .. Strangely in the topic I have done a test it for four days and then I got this problem
                    I do not know why and Hoahal
                    In any case sent you the file again
                    Please try to help
                      rod1233
                      Emerged within the tool ( System preferencec )
                      But the need to activate the
                      I tried hard to no avail
                        Great, we're getting closer to solving it.
                        After you try to initilize it, make sure to also go to View > Toolbars > Camera Recoder
                        You must make sure the toolbar is turned on too.
                        Plus all the tools are availabe in Plugins > Chris Fullmer Tools > Camera Recorder
                        Check those things to see if that gets it working,
                          rod1233
                          Did not show the tool in the tool bar
                          But emerged in the preferences
                            ok, so the loader file is loading, and its trying to load the script, but its failing. I have a few ideas how to fix that. Your XP is having issues with the path's for some reason. BUt I think I know how to fix it. Let me see what I can do.
                              rod1233
                              I do not have Windows XP
                              I have a Windows Vista
                                rod1233
                                Soil you have the file on the Windows XP has been success with ease
                                But Windows Vista is still the problem
                                  Very odd. I write these plugins on a Vista system, and use them at work on an XP system.
                                  I'll keep digging. I might have a new file for you to try in a few hours.
                                    rod1233
                                    Waiting for the new my friend
                                    All thanks to you and your efforts
                                      Sorry Rod, I've been sick and have not been doing too much.
                                      So I don't know what the problem is, but these scripts open the ruby concole while the scripts are loading, so we can see any load errors. So please overwrite the existing files with these. And copy any text that gets written to the ruby console when SketchUp is starting. Then paste that code back here.
                                        rod1233
                                        This was the result
                                          OK Rod, I think I've found a solution. Please download and overwrite this file sindei the clf_camera_recorder folder. Please oh Please tell me this works.
                                            @@path.gsub!( /\//, "\\\\" ) if @@pc
                                            around line #53, seems a heavy handed [wrong] way to replace all of the PC's filepath's / separators with a \ the tr way might be safer/easier to see...
                                            @@path.tr("/","\\")if @@pc
                                            • 5 / 7
