    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 277.6k Views 32 Watching
    • Chris FullmerC
      OK, it is all installed right, thanks you so much for uploading that.
      One last idea. Try this loader script. Just overwrite the existing clf_camera_recorder_loader.rb file with the attached one. Let me know if that works,
      PS - this file is not MAC friendly. I think it will break the script if anyone on a Mac downloads it.
      • PixeroP
        Pixero
        Chris, have you tried LightUp? Could you implement a flyaround mode with inertia like in LightUp?
        It would be so great to fly around smoothly and record scenes and then use that for both SU lines and LightUp.
        Pleeeeaaase? πŸ˜„
          rod1233
          hi Chris
          Thank you for your patience.
          But unfortunately the problem did not end
          I barely said Volkswagen .. Strangely in the topic I have done a test it for four days and then I got this problem
          I do not know why and Hoahal
          In any case sent you the file again
          Please try to help
            rod1233
            Emerged within the tool ( System preferencec )
            But the need to activate the
            I tried hard to no avail
            • Chris FullmerC
              Great, we're getting closer to solving it.
              After you try to initilize it, make sure to also go to View > Toolbars > Camera Recoder
              You must make sure the toolbar is turned on too.
              Plus all the tools are availabe in Plugins > Chris Fullmer Tools > Camera Recorder
              Check those things to see if that gets it working,
                rod1233
                Did not show the tool in the tool bar
                But emerged in the preferences
                • Chris FullmerC
                  ok, so the loader file is loading, and its trying to load the script, but its failing. I have a few ideas how to fix that. Your XP is having issues with the path's for some reason. BUt I think I know how to fix it. Let me see what I can do.
                    rod1233
                    I do not have Windows XP
                    I have a Windows Vista
                      rod1233
                      Soil you have the file on the Windows XP has been success with ease
                      But Windows Vista is still the problem
                      • Chris FullmerC
                        Very odd. I write these plugins on a Vista system, and use them at work on an XP system.
                        I'll keep digging. I might have a new file for you to try in a few hours.
                          rod1233
                          Waiting for the new my friend
                          All thanks to you and your efforts
                          • Chris FullmerC
                            Sorry Rod, I've been sick and have not been doing too much.
                            So I don't know what the problem is, but these scripts open the ruby concole while the scripts are loading, so we can see any load errors. So please overwrite the existing files with these. And copy any text that gets written to the ruby console when SketchUp is starting. Then paste that code back here.
                              rod1233
                              This was the result
                              • Chris FullmerC
                                OK Rod, I think I've found a solution. Please download and overwrite this file sindei the clf_camera_recorder folder. Please oh Please tell me this works.
                                  @@path.gsub!( /\//, "\\\\" ) if @@pc
                                  around line #53, seems a heavy handed [wrong] way to replace all of the PC's filepath's / separators with a \ the tr way might be safer/easier to see...
                                  @@path.tr("/","\\")if @@pc
                                    Jim
                                    What's wrong with gsub, and how is tr safer and easier?
                                      in that example you do save a few characters. And you avoid the overhead of rexex processing. if it is simple text or character replacement it is faster to do plain text replace than invoking regex.
                                      • Chris FullmerC
                                        I was not aware of the .tr method. I had only seen gsub, and I was able to get it to work. But I like the way .tr works. It looks much simpler. It took me hours and hours to wrap my head around how slashes work and escaping characters with lots of help. I'm sure I don't understand it all yet. But just having it work made me happy.
                                        So the problem in this script that I was fixing is that I was storing forward slashes into the Windows registry. It seems to work fine on most computers. But not Rod's. His Vista won't handle forward slashes at all. Anyone know what might be making his system work like that?
                                        PS I still don't know if these tweaks fixed it for Rod - I sure hope it did. Because I'm about out of ideas otherwise.....
                                          The .tr is somewhat different though. But can be used in this case.
                                          .gsub can also be used without using regex for pattern.
                                          • Chris FullmerC
                                            Oh yeah, I also meant to ask:
                                            What is regex?
                                            • 5 / 7
