    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 277.6k Views 32 Watching
      rod1233
      Where are you?
      I hope you of what is new
      rod
        rod1233
        • Chris FullmerC
          Sorry I missed your post yesterday. Somehiw I did not see it, sorry Rod. I have the files now and I am looking at them (I deleted the .rar file from your post alre4ady, but I downloaded it first).
          • Chris FullmerC
            OK, it is all installed right, thanks you so much for uploading that.
            One last idea. Try this loader script. Just overwrite the existing clf_camera_recorder_loader.rb file with the attached one. Let me know if that works,
            PS - this file is not MAC friendly. I think it will break the script if anyone on a Mac downloads it.
            • PixeroP
              Pixero
              Chris, have you tried LightUp? Could you implement a flyaround mode with inertia like in LightUp?
              It would be so great to fly around smoothly and record scenes and then use that for both SU lines and LightUp.
              Pleeeeaaase? πŸ˜„
                rod1233
                hi Chris
                Thank you for your patience.
                But unfortunately the problem did not end
                I barely said Volkswagen .. Strangely in the topic I have done a test it for four days and then I got this problem
                I do not know why and Hoahal
                In any case sent you the file again
                Please try to help
                  rod1233
                  Emerged within the tool ( System preferencec )
                  But the need to activate the
                  I tried hard to no avail
                  • Chris FullmerC
                    Great, we're getting closer to solving it.
                    After you try to initilize it, make sure to also go to View > Toolbars > Camera Recoder
                    You must make sure the toolbar is turned on too.
                    Plus all the tools are availabe in Plugins > Chris Fullmer Tools > Camera Recorder
                    Check those things to see if that gets it working,
                      rod1233
                      Did not show the tool in the tool bar
                      But emerged in the preferences
                      • Chris FullmerC
                        ok, so the loader file is loading, and its trying to load the script, but its failing. I have a few ideas how to fix that. Your XP is having issues with the path's for some reason. BUt I think I know how to fix it. Let me see what I can do.
                          rod1233
                          I do not have Windows XP
                          I have a Windows Vista
                            rod1233
                            Soil you have the file on the Windows XP has been success with ease
                            But Windows Vista is still the problem
                            • Chris FullmerC
                              Very odd. I write these plugins on a Vista system, and use them at work on an XP system.
                              I'll keep digging. I might have a new file for you to try in a few hours.
                                rod1233
                                Waiting for the new my friend
                                All thanks to you and your efforts
                                • Chris FullmerC
                                  Sorry Rod, I've been sick and have not been doing too much.
                                  So I don't know what the problem is, but these scripts open the ruby concole while the scripts are loading, so we can see any load errors. So please overwrite the existing files with these. And copy any text that gets written to the ruby console when SketchUp is starting. Then paste that code back here.
                                    rod1233
                                    This was the result
                                    • Chris FullmerC
                                      OK Rod, I think I've found a solution. Please download and overwrite this file sindei the clf_camera_recorder folder. Please oh Please tell me this works.
                                        @@path.gsub!( /\//, "\\\\" ) if @@pc
                                        around line #53, seems a heavy handed [wrong] way to replace all of the PC's filepath's / separators with a \ the tr way might be safer/easier to see...
                                        @@path.tr("/","\\")if @@pc
                                          Jim
                                          What's wrong with gsub, and how is tr safer and easier?
                                            in that example you do save a few characters. And you avoid the overhead of rexex processing. if it is simple text or character replacement it is faster to do plain text replace than invoking regex.
                                            • 5 / 7
