    [Plugin] Loose Geometry to Groups (Updated August 28, 2009)
    36 Posts 10 Posters 46.8k Views 10 Watching
    • Chris FullmerC Offline
      Hmm, what does what I wrote do then? It seems to work. I was thinking that it would evaluate to a true or false depending if the typename was edge,face,component, or group (Edge or face = true, group or component = false). It seems to be working in the code, but I'm sure its just dumb luck and will probably fail in circumstances I have not tested. I'll re-write like your first example (because I don't follow what's happening in the 2nd example 😆 ). I need to look at what %w is. Thank you so much for taking the time to read through the script Jim,
        ok, I think I'm getting the problem with what I wrote. I want an IF statement to essentially boil to down "if true"
        but my code
        if entity.typename == ("Edge" or "Face")
        is evaluating down (over the 3 steps I've written out)
        "if entity.typename == (true)"
        if face == true
        if false
        So I should be getting a false no matter what the 2nd half of the evaluate is, since neither true nor false == face. Am I understanding the logic flow there correctly?
          Jim
          Sorry, I tried to be too clever in my last example...
          this:
          ("Edge" or "Face")
          always returns "Edge" so your comparison always boils down to
          if entity.typename == "Edge"
          which works just fine since all_connected will pick up any connected faces.
            Ohh! That makes so much sense now. I was wondering why it was working, but that explains it. But yes,it was not doing what I thought it was doing. Thanks for clearing that up Jim.
              mimnbazhq
                This script had a bug that I updated. I also added a counter to the status bar so that you can see the script in action. It counts the entities as it processes them so you know where it is in the process (though it is possible that the Sketchup user interface might freeze and quite showing the counter while processing large selections).
                version 1.2 2009-08-28
                • Fixed a major bug where the script was not working with selections.
                • Fixed some internal coding that might make it slightly faster.
                • Added an entity counter to the Status Bar so you can see the script working.
                • Changed the Undo title from "Make groups" to "Loose to Groups" (this is the title that you see in the Edit > Undo command).
                This is script is located on smustard.com at:
                (www.smustard.com)
                • bagateloB Offline
                  bagatelo
                  Hi Chris Fullmer
                  Great plugin, it is very usefull.
                  Would the plugin be possible to make components instead of groups??
                    Just edit it when the group is made and group.to_component ?
                      Yup, add that line:
                      group.to_component
                      in between lines 82 and 83 - so right after this line:
                      group = @entities.add_group(to_group)
                      Its near the bottom of the scipt. about 25 lines up from the bottom.
                      • bagateloB Offline
                        bagatelo
                        works very whell, thanks
                        Add in menu plugin this option
                          Chris, why are you splitting the geometry processing into chunks of 1000? Is it to speed up creation?
                          do you not risk splitting groups of loose geometry?
                            Thom, yes it was an attempt to speed things up. I do not think it helped at all. I can't look at the code right now, but I was thinking that I done something to make sure I did not split up geometry......but its also possible I did not think of that 😳
                              Maybe you did, I did not decipher the code that thoroughly. Was curious if you found some speed tricks.
                                guaucorreo
                                hi, i played with this plugin and all was god, but now
                                i have a bug that say in spanish "AJUSTA LA HORA", in english its something like "CHANGE THE CLOCK TIME"
                                ????????WHY
                                  ????????WHY
                                  Can you post a screenshot of your error message?
                                    guaucorreo
                                    i have the "loose geometry to components"
                                      The error isn't from this plugin. The plugin is all English, and there is nothing in its code that mess with the clock.
                                      If you post a screenshot of the error message we might be able to determine what it is.
                                        guaucorreo
                                        after three seconds of runing the plugin send me this message "ajusta la hora"
                                          guaucorreo
                                          i have to erase the plugin and then upload to go wright, but after two or three times going well, the pluging crash.
                                          i am working on the xfrog trees to make components of the leaves, and this plugin its perfect. then i work with yours similar objects, and all goes good except this bug.
                                          thanksss
                                            There's nothing in the source code of this plugin that has that text or any reference to any Time objects either.
                                            What that is, is the tooltip for the Shadow Toolbar your mouse is currently hovering over in that screenshot.
                                            You can see how it looks like in my English SU version:
