    1.5k Posts 477 Posters 4.0m Views 477 Watching
      Rob D
      Hi Fredo
      I couldn't be any happier with FredoScale and RoundCorner... anyone using SketchUp without those tools is NOT using the same program I am using as far as I'm concerned...
      I agree with Fletch!
      though I think I might be getting the same bug. While orbiting after selecting faces my screen went completely black and I had to alt+tab to get back to SketchUp. Is that similar to what you got too Fletch?
      • fredo6F Offline
        @fletch said:
        I'm just going around my building to select about 30 edges that need to be beveled... I get about 20 edges or more... and then need to rotate/pan to see the other ones... I can orbit/rotate the view just fine, but if I hit that CNTRL button + middle mouse button in order to pan the image... poof gone.
        I guess you mean you get a bugsplat.
        I am not able to reproduce this, even on complex models (I just fixed the small issue about the Shift (for pan) interfering with the modifier value for edge selection. This will go in a next upgrade.
        If you have a situation where you get the crash systematically, could you send it to me so that I have a closer look.
          DIEGO-RODRIGUEZ
          hi fredo.
          a query.
          it could add this feature?
          distinguish between concave and convex
          http://img710.imageshack.us/img710/4262/roundcornerso.jpg
          • fredo6F Offline
            Diego,
            This is possible, but I need to build some UI around the functionality (RoundCorner actualy works with any symmetric profile).
            If you are in a hurry, edit the file RoundCorner_Algo.rb, line 71 and replace the 'C' by 'CR'.
               @profile_type = ['C', 6]
               @profile_type = ['CR', 6]
              DIEGO-RODRIGUEZ
              Thanks Fredo
                mras26
                I've just instlled the libfredo... and Roundcorner, got the files in Plugin folder( the same like above)
                When i run the sketchup program, i cant go into this new plugin.
                I'm from Poland and using the polisch version of sketchup, its doesnt matter if i'm using polish version?
                Thanks for answering
                • CarrozzaC Offline
                  Carrozza
                  Help! In another thread someone pointed me to this plugin to round off the joint of two pipes. I'm getting weird results, tough...
                  http://img706.imageshack.us/img706/7681/capture1.gif
                  http://img706.imageshack.us/img706/8652/capture2.gif
                  http://img706.imageshack.us/img706/3480/capture3.gif
                  I guess I'm missing some basics, like using wrong number of sides or something else.
                  Could someone help me, please?
                    Try and make the number of segments that touch in both tubes equal ...
                    • EscapeArtistE Offline
                      EscapeArtist
                      I had the same problem as Carrozza, except I was using two tubes of the same diameter and segments. I found no solution and elected not to use the plugin.
                      Also, I connected a tube to a sphere. The tube was rounded perfectly, but it was no longer attached to the sphere. The edge where the tube/sphere intersect seems to pull away.
                      Don't get me wrong, this is a great plugin and it works well in every other instance I've used it. These are just a couple of instances where I've found it doesn't work.
                      • fredo6F Offline
                        @mras26 said:
                        It probably comes from the installation, in particular how you unzipped the files. Make sure that you reconstruct the folder hierarchy as indicated in the documentation (current version of LibFredo6 is 34).
                        Otherwise, it does not matter that you use SU in Polish (you'll get the script in English by default).
                        • fredo6F Offline
                          RoundCorner is not really adequate for this situation, because it would be very difficult to adjsut all edge terminations to get a perfect rounding.
                          I am not aware of any plugin doing these junctions, but if you do a lot of tubing work, you may want to have a look at the Pipes plugin from Skeng.
                          • CarrozzaC Offline
                            Carrozza
                            Actually no, I don't do a lot of pipes work, but is a shape that cross my way sometimes and wakes up my interest because of the complicated geometry.
                            What bugs me is that the kind Blajnov did manage to accomplish the task with RoundCorner, but I am not able to replicate the success. πŸ˜’
                            TIG, thanks for your input, I'll try to count the segments, but at first thought it looks hard to match both sides because of different lenghts.
                              Steven Boldt
                              I keep getting this message after unzipping and opening sketchup
                              Error Loading File ZLoader__RoundCorner.rb
                              uninitialized constant Traductor::Plugin
                              • fredo6F Offline
                                Did you install LibFredo6?
                                  Steven Boldt
                                  Yes, I did.
                                    Steven Boldt
                                    All is well. It's working on both systems-XP and Vista 64.
                                    Fredo, you're plugins are great.
                                      leffoot
                                      thanks a lot Great plugin!!
                                        krash88
                                        This plugin looks great, but I'm running into a problem here. I have a rather simple triangulated mesh and need to bevel the edges before running it through Subdivide and Smooth. However, the script seems to stop around 6%, yet still says computing.
                                        http://i109.photobucket.com/albums/n65/krash88/bevel.jpg
                                        Any ideas?
                                          Post your skp file πŸ˜‰
                                            krash88
                                            Hmm, I attached the file, but something messed up. Here it is.
                                            BL-141SOF-002.skp
                                            • 11
                                            • 74
                                            • 75
                                            • 9 / 75
