    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • fredo6F
      @fletch said:
      I'm just going around my building to select about 30 edges that need to be beveled... I get about 20 edges or more... and then need to rotate/pan to see the other ones... I can orbit/rotate the view just fine, but if I hit that CNTRL button + middle mouse button in order to pan the image... poof gone.
      I guess you mean you get a bugsplat.
      I am not able to reproduce this, even on complex models (I just fixed the small issue about the Shift (for pan) interfering with the modifier value for edge selection. This will go in a next upgrade.
      If you have a situation where you get the crash systematically, could you send it to me so that I have a closer look.
        DIEGO-RODRIGUEZ
        hi fredo.
        a query.
        it could add this feature?
        distinguish between concave and convex
        http://img710.imageshack.us/img710/4262/roundcornerso.jpg
        • fredo6F
          Diego,
          This is possible, but I need to build some UI around the functionality (RoundCorner actualy works with any symmetric profile).
          If you are in a hurry, edit the file RoundCorner_Algo.rb, line 71 and replace the 'C' by 'CR'.
             @profile_type = ['C', 6]
             @profile_type = ['CR', 6]
            DIEGO-RODRIGUEZ
            Thanks Fredo
              mras26
              I've just instlled the libfredo... and Roundcorner, got the files in Plugin folder( the same like above)
              When i run the sketchup program, i cant go into this new plugin.
              I'm from Poland and using the polisch version of sketchup, its doesnt matter if i'm using polish version?
              Thanks for answering
              • CarrozzaC
                Carrozza
                Help! In another thread someone pointed me to this plugin to round off the joint of two pipes. I'm getting weird results, tough...
                http://img706.imageshack.us/img706/7681/capture1.gif
                http://img706.imageshack.us/img706/8652/capture2.gif
                http://img706.imageshack.us/img706/3480/capture3.gif
                I guess I'm missing some basics, like using wrong number of sides or something else.
                Could someone help me, please?
                  Try and make the number of segments that touch in both tubes equal ...
                  • EscapeArtistE
                    EscapeArtist
                    I had the same problem as Carrozza, except I was using two tubes of the same diameter and segments. I found no solution and elected not to use the plugin.
                    Also, I connected a tube to a sphere. The tube was rounded perfectly, but it was no longer attached to the sphere. The edge where the tube/sphere intersect seems to pull away.
                    Don't get me wrong, this is a great plugin and it works well in every other instance I've used it. These are just a couple of instances where I've found it doesn't work.
                    • fredo6F
                      @mras26 said:
                      It probably comes from the installation, in particular how you unzipped the files. Make sure that you reconstruct the folder hierarchy as indicated in the documentation (current version of LibFredo6 is 34).
                      Otherwise, it does not matter that you use SU in Polish (you'll get the script in English by default).
                      • fredo6F
                        RoundCorner is not really adequate for this situation, because it would be very difficult to adjsut all edge terminations to get a perfect rounding.
                        I am not aware of any plugin doing these junctions, but if you do a lot of tubing work, you may want to have a look at the Pipes plugin from Skeng.
                        • CarrozzaC
                          Carrozza
                          Actually no, I don't do a lot of pipes work, but is a shape that cross my way sometimes and wakes up my interest because of the complicated geometry.
                          What bugs me is that the kind Blajnov did manage to accomplish the task with RoundCorner, but I am not able to replicate the success. πŸ˜’
                          TIG, thanks for your input, I'll try to count the segments, but at first thought it looks hard to match both sides because of different lenghts.
                            Steven Boldt
                            I keep getting this message after unzipping and opening sketchup
                            Error Loading File ZLoader__RoundCorner.rb
                            uninitialized constant Traductor::Plugin
                            • fredo6F
                              Did you install LibFredo6?
                                Steven Boldt
                                Yes, I did.
                                  Steven Boldt
                                  All is well. It's working on both systems-XP and Vista 64.
                                  Fredo, you're plugins are great.
                                  • L
                                    leffoot
                                    thanks a lot Great plugin!!
                                    • K
                                      krash88
                                      This plugin looks great, but I'm running into a problem here. I have a rather simple triangulated mesh and need to bevel the edges before running it through Subdivide and Smooth. However, the script seems to stop around 6%, yet still says computing.
                                      http://i109.photobucket.com/albums/n65/krash88/bevel.jpg
                                      Any ideas?
                                        Post your skp file πŸ˜‰
                                        • K
                                          krash88
                                          Hmm, I attached the file, but something messed up. Here it is.
                                          BL-141SOF-002.skp
                                          • fredo6F
                                            [attachment=1:uzwl37lk]<!-- ia1 -->BL-141SOF-002.skp<!-- ia1 -->[/attachment:uzwl37lk]
                                            I found the bug, which explains why the scripts stops. In your case, you can however exit the tool.
                                            Beyond that, you are in case where RoundCorner would not function very well, because of the triangulation. This is one of the limitations mentioned at the end of the documentation.
                                            I attach here the result which is not very good for some edges, so that you can judge.
                                            BL-141SOF-002 - beveled.skp
                                            • 11
                                            • 74
                                            • 75
                                            • 9 / 75
