    1.5k Posts 477 Posters 4.0m Views 477 Watching
    • CarrozzaC Offline
      Carrozza
      Actually no, I don't do a lot of pipes work, but is a shape that cross my way sometimes and wakes up my interest because of the complicated geometry.
      What bugs me is that the kind Blajnov did manage to accomplish the task with RoundCorner, but I am not able to replicate the success. πŸ˜’
      TIG, thanks for your input, I'll try to count the segments, but at first thought it looks hard to match both sides because of different lenghts.
        Steven Boldt
        I keep getting this message after unzipping and opening sketchup
        Error Loading File ZLoader__RoundCorner.rb
        uninitialized constant Traductor::Plugin
        • fredo6F Offline
          Did you install LibFredo6?
            Steven Boldt
            Yes, I did.
              Steven Boldt
              All is well. It's working on both systems-XP and Vista 64.
              Fredo, you're plugins are great.
                leffoot
                thanks a lot Great plugin!!
                  krash88
                  This plugin looks great, but I'm running into a problem here. I have a rather simple triangulated mesh and need to bevel the edges before running it through Subdivide and Smooth. However, the script seems to stop around 6%, yet still says computing.
                  http://i109.photobucket.com/albums/n65/krash88/bevel.jpg
                  Any ideas?
                    Post your skp file πŸ˜‰
                      krash88
                      Hmm, I attached the file, but something messed up. Here it is.
                      BL-141SOF-002.skp
                      • fredo6F Offline
                        [attachment=1:uzwl37lk]<!-- ia1 -->BL-141SOF-002.skp<!-- ia1 -->[/attachment:uzwl37lk]
                        I found the bug, which explains why the scripts stops. In your case, you can however exit the tool.
                        Beyond that, you are in case where RoundCorner would not function very well, because of the triangulation. This is one of the limitations mentioned at the end of the documentation.
                        I attach here the result which is not very good for some edges, so that you can judge.
                        BL-141SOF-002 - beveled.skp
                          krash88
                          Thanks for taking a look at this for me. While I may not be able to use your script on this particular model, I can see many uses elsewhere. I appreciate the hard work that you and others have put into these scripts and for your time in answering questions. Guys like you have really turned SketchUp into something great. Thanks again!
                            magpie
                            Fredo, I echo the sentiment of all the grateful users who benefit from your talent and selfless dedication. Many thanks for this!
                              mgfranz
                              Excellent plugin! My router is going to be jealous... 😍
                              "If you like what you do, it will never be work..."
                              In memory of Sam Maloof, 1916-2009
                                AR-51
                                Hi, I install RoundCorner, but I'm unable to access it in SketchUp. When I click on Tools>FredoScale noting happens.
                                I also get no response when I click on Set Preference Languages.
                                I'm using Vista
                                Thanks for the help.
                                http://i601.photobucket.com/albums/tt93/Bestworldphoto/Sketch.jpg
                                Plug in foulder
                                http://i601.photobucket.com/albums/tt93/Bestworldphoto/Plugin.jpg
                                • F Offline
                                  fine2444
                                  http://cfile234.uf.daum.net/original/155C3D1D4B6EA9867F0B3A
                                  I made two round corner model Yesterday, today.
                                  I want two same shape of rondcorner model but It is not working out.
                                  Working conditions were the same as the shape ..
                                  What's wrong?
                                  I dont want small triangle particles at all in very right model.
                                  You mean It happens becasue the edge is not aligned, I think I aligned it
                                  would like to tell me why and how?
                                    Hi Fine,
                                    Can you delete those edges without losing the faces?
                                    It's not necessarily there because you did not align your model but maybe because the newly created facets would not be co-planar otherwise.
                                    In any case, after smoothing those surfaces, it won't be seen (but I understand that you wish to have the least geometry and cleanest possible model)
                                    • fredo6F Offline
                                      What's wrong?
                                      Can you check if you use the same setting for the option "Strict Offset" (this is the button with the vertical green and red bars).
                                        archi-sketch
                                        i don't know what to say..or should i just say~THANK YOU VERY MUCH!!! ..you make my day!
                                          rd84
                                          Many thanks for this utility - my life using Sketchup is suddenly much easier !
                                          Cheers
                                          Paul
                                            aea
                                            2D round corner is ? plugin , something ?
                                            • 11
                                            • 74
                                            • 75
                                            • 9 / 75
