    Render this: NPR Lighthouse
    108 Posts 37 Posters 17.1k Views 37 Watching
    • FrederikF Offline
      Frederik
      Although that I'm not a huge fan of Andy Warhol, that's really nice dspace... πŸ‘
      Cheers
      Kim Frederik
      • EarthMoverE Offline
        EarthMover
        Another.
        Content Creator at Skapeup
          Now, Adam, I said to myself "what a f*** beautiful and cool render this is"
          ...but then 2 things:
          1. IF the lighthouse is of "THIS" size, the other side of the image MUST be out of scale
          2. it is getting twilight - why is there no light in the lighthouse?
          But man, I really need to find these faults deliberately - the image is SOOO nice (otherwise).
          But you know - everyone is being picky here...
          πŸ˜’
            EarthMover
            You're absolutely right Gai on both points. I didn't realize how out of scale it is until you said that. I just inserted the lighthouse model into a scene set up by someone on the Modo forums to show volumetric light, rendered it and changed the color balance to a more dramatic look. The lighthouse should be a hell of lot larger.
              Depending πŸ˜‰
              if the lighthouse is scale model of an ex voto on a table that can be possible πŸ’š
                tomsdesk
                Just part of a minature golf course?
                2.5D Trees & Shrubs!
                • Rich O BrienR Online
                  Couldn't resist posting this as i was playing around with glass and plastic settings in Twilight
                  Know it not NPR but.....
                    EarthMover
                    Made some corrections..although it appears the dock may be tad too small now. Added a volumetric spotlight to the lighthouse as well.
                    Raw Render
                    B&W
                    Blue NPR
                    Red NPR
                      dspace
                      @Frederik, thanks...I'm indeed a Warhol fan! πŸ˜‰
                      @rclub24...cool, I was thinking of something like this, but with snow etc... πŸ˜„
                      @Earthmover, very nice fog test! πŸ˜„
                        πŸ‘
                        Nothing to add now, Adam!
                        πŸ˜‰
                        • H Offline
                          hvanessen
                          As a newbie i want to give it a try, end this is what i have achieved.
                          Let me know if you like it or not.
                            toxicvoxel
                            I like the idea of trying to do these as little speed painting exercises of 20-30 minutes. With a little more confidence in the brushwork I can see these being done in 10-15 minutes. - No intermediate rendering engine involved - just a Sketchup base image + Painter X
                            • michaliszissiouM Offline
                              michaliszissiou
                              Well this is an interesting thread, keep it like this. A big 'bravo' to all of you. πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                d12dozr
                                Nice! I like the geese πŸ‘
                                http://goo.gl/f7ooYh
                                • Al HartA Offline
                                  Al Hart
                                  This is a quick example using an NprTools feature called "Soft Edges". This saves an image of the edge lines, a separate image with no edge lines, applies a pattern mask to the edge lines and blends them back into the no-edge image with 50% transparency. (This can easily be done in PhotoShop - NprTools just does it all in a single step)
                                  A chipboard watermark was applied as a SketchUp style before creating and blending the images.
                                  (click mage to view without scollbars)
                                  Here is a blow up of the pattern mask and transparency effect at the top of the tower.
                                  Al Hart
                                  IRender nXt from Render Plus
                                  • massimoM Offline
                                    massimo Moderator
                                    A variation of the first entry: a render in a render in a render. πŸ’š
                                      dylan
                                      That's fantastic massimo, that makes me smile πŸ˜„
                                      http://dmdarchitecture.co.uk/
                                      • massimoM Offline
                                        massimo Moderator
                                        Glad you like it Dylan. β˜€
                                          sepo
                                          I thought I would try as well.
                                          http://i965.photobucket.com/albums/ae136/sepo100/lighthouse30copy.jpg
                                          http://i965.photobucket.com/albums/ae136/sepo100/lighthouse20Acopy.jpg
                                          http://i965.photobucket.com/albums/ae136/sepo100/lighthouse50copy.jpg
                                            siehthree
                                            Here is my attempt to contribute!
                                            Thanks to all for your inspirations!
                                            Rendered with Podium...
                                            • 5 / 6
