    Render this: NPR Lighthouse
    108 Posts 37 Posters 21.7k Views 37 Watching
      tomsdesk
      Another silkscreen...?:
      2.5D Trees & Shrubs!
        andre51
        Thanks Troy - easy Vue and simple paint program called Virtual Painter
        http://www.virtualpainter5.com/
          d12dozr
          This is fun! Thanks for the interesting subject, Pete!
          A classic red & white lighthouse this time...SU + Twilight + Photoshop filters + Picasa(soft focus) ...Here is how I did the post-processing for those of you who wish to know πŸ˜„
          SU + Twilight + Photoshop + Picasa
          http://goo.gl/f7ooYh
            dspace
            And one more for my bedroom wall. πŸ˜„
            • FrederikF Offline
              Frederik
              Although that I'm not a huge fan of Andy Warhol, that's really nice dspace... πŸ‘
              Cheers
              Kim Frederik
              • EarthMoverE Offline
                EarthMover
                Another.
                Content Creator at Skapeup
                  Now, Adam, I said to myself "what a f*** beautiful and cool render this is"
                  ...but then 2 things:
                  1. IF the lighthouse is of "THIS" size, the other side of the image MUST be out of scale
                  2. it is getting twilight - why is there no light in the lighthouse?
                  But man, I really need to find these faults deliberately - the image is SOOO nice (otherwise).
                  But you know - everyone is being picky here...
                  πŸ˜’
                    EarthMover
                    You're absolutely right Gai on both points. I didn't realize how out of scale it is until you said that. I just inserted the lighthouse model into a scene set up by someone on the Modo forums to show volumetric light, rendered it and changed the color balance to a more dramatic look. The lighthouse should be a hell of lot larger.
                      Depending πŸ˜‰
                      if the lighthouse is scale model of an ex voto on a table that can be possible πŸ’š
                        tomsdesk
                        Just part of a minature golf course?
                          Couldn't resist posting this as i was playing around with glass and plastic settings in Twilight
                          Know it not NPR but.....
                            EarthMover
                            Made some corrections..although it appears the dock may be tad too small now. Added a volumetric spotlight to the lighthouse as well.
                            Raw Render
                            B&W
                            Blue NPR
                            Red NPR
                              dspace
                              @Frederik, thanks...I'm indeed a Warhol fan! πŸ˜‰
                              @rclub24...cool, I was thinking of something like this, but with snow etc... πŸ˜„
                              @Earthmover, very nice fog test! πŸ˜„
                                πŸ‘
                                Nothing to add now, Adam!
                                πŸ˜‰
                                • H Offline
                                  hvanessen
                                  As a newbie i want to give it a try, end this is what i have achieved.
                                  Let me know if you like it or not.
                                    toxicvoxel
                                    I like the idea of trying to do these as little speed painting exercises of 20-30 minutes. With a little more confidence in the brushwork I can see these being done in 10-15 minutes. - No intermediate rendering engine involved - just a Sketchup base image + Painter X
                                    • michaliszissiouM Offline
                                      michaliszissiou
                                      Well this is an interesting thread, keep it like this. A big 'bravo' to all of you. πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                        d12dozr
                                        Nice! I like the geese πŸ‘
                                        • Al HartA Offline
                                          Al Hart
                                          This is a quick example using an NprTools feature called "Soft Edges". This saves an image of the edge lines, a separate image with no edge lines, applies a pattern mask to the edge lines and blends them back into the no-edge image with 50% transparency. (This can easily be done in PhotoShop - NprTools just does it all in a single step)
                                          A chipboard watermark was applied as a SketchUp style before creating and blending the images.
                                          (click mage to view without scollbars)
                                          Here is a blow up of the pattern mask and transparency effect at the top of the tower.
                                          Al Hart
                                          IRender nXt from Render Plus
                                          • massimoM Offline
                                            massimo Moderator
                                            A variation of the first entry: a render in a render in a render. πŸ’š
                                            • 5 / 6
