    Render this: NPR Lighthouse
    108 Posts 37 Posters 23.7k Views 37 Watching
    • EarthMoverE
      EarthMover
      You're absolutely right Gai on both points. I didn't realize how out of scale it is until you said that. I just inserted the lighthouse model into a scene set up by someone on the Modo forums to show volumetric light, rendered it and changed the color balance to a more dramatic look. The lighthouse should be a hell of lot larger.
      Content Creator at Skapeup
        IF the lighthouse is of "THIS" size, the other side of the image MUST be out of scale
        Depending πŸ˜‰
        if the lighthouse is scale model of an ex voto on a table that can be possible πŸ’š
        • T
          tomsdesk
          Just part of a minature golf course?
          2.5D Trees & Shrubs!
            Couldn't resist posting this as i was playing around with glass and plastic settings in Twilight
            Know it not NPR but.....
            • EarthMoverE
              EarthMover
              Made some corrections..although it appears the dock may be tad too small now. Added a volumetric spotlight to the lighthouse as well.
              Raw Render
              B&W
              Blue NPR
              Red NPR
                dspace
                @Frederik, thanks...I'm indeed a Warhol fan! πŸ˜‰
                @rclub24...cool, I was thinking of something like this, but with snow etc... πŸ˜„
                @Earthmover, very nice fog test! πŸ˜„
                • GaieusG
                  πŸ‘
                  Nothing to add now, Adam!
                  πŸ˜‰
                  • H
                    hvanessen
                    As a newbie i want to give it a try, end this is what i have achieved.
                    Let me know if you like it or not.
                    • T
                      toxicvoxel
                      I like the idea of trying to do these as little speed painting exercises of 20-30 minutes. With a little more confidence in the brushwork I can see these being done in 10-15 minutes. - No intermediate rendering engine involved - just a Sketchup base image + Painter X
                      • michaliszissiouM
                        michaliszissiou
                        Well this is an interesting thread, keep it like this. A big 'bravo' to all of you. πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                          d12dozr
                          Nice! I like the geese πŸ‘
                          http://goo.gl/f7ooYh
                          • Al HartA
                            Al Hart
                            This is a quick example using an NprTools feature called "Soft Edges". This saves an image of the edge lines, a separate image with no edge lines, applies a pattern mask to the edge lines and blends them back into the no-edge image with 50% transparency. (This can easily be done in PhotoShop - NprTools just does it all in a single step)
                            A chipboard watermark was applied as a SketchUp style before creating and blending the images.
                            (click mage to view without scollbars)
                            Here is a blow up of the pattern mask and transparency effect at the top of the tower.
                            Al Hart
                            IRender nXt from Render Plus
                            • massimoM
                              massimo Moderator
                              A variation of the first entry: a render in a render in a render. πŸ’š
                                dylan
                                That's fantastic massimo, that makes me smile πŸ˜„
                                http://dmdarchitecture.co.uk/
                                • massimoM
                                  massimo Moderator
                                  Glad you like it Dylan. β˜€
                                    sepo
                                    I thought I would try as well.
                                    http://i965.photobucket.com/albums/ae136/sepo100/lighthouse30copy.jpg
                                    http://i965.photobucket.com/albums/ae136/sepo100/lighthouse20Acopy.jpg
                                    http://i965.photobucket.com/albums/ae136/sepo100/lighthouse50copy.jpg
                                      siehthree
                                      Here is my attempt to contribute!
                                      Thanks to all for your inspirations!
                                      Rendered with Podium...
                                      • P
                                        PKast
                                        Wow, what a wonderful thread to find after being away for some days.
                                        Thanks everyone for the creative kick in the pants.
                                        This was a lot of fun and engaging to read.
                                        Here is my take.
                                        Best,
                                        Peter K.
                                        • 5 / 6
