    [REQ] triangulation ruby
    19 Posts 9 Posters 3.5k Views 9 Watching
    • soloS Offline
      I have no idea how easy this is to make, but I'd really appreciate if anyone could take a stab at creating a ruby that can triangulate all rectangular polygons to triangles.
      If possible to have a few different triangulation options, see image.
      http://img163.imageshack.us/img163/1611/triangulate.jpg
      If possible can it triangulate with say 1,2,3 iriterations as well as 3 different patterns?
      The reason I'd like this is for a new 'organic' modeling method I have brewing.
      thanks for consideration.
      • Chris FullmerC Offline
        Could you guarantee that all quads are truly quads in your process? ie, not actually triangles with an inner edge smoothed so it just looks like a quad?
        If this really only needed to be developed for quads, then yes, it should be quite do-able I think.
          remus
          i think TIGs written such a plugin already, called something like triangulate.rb im sure a quick search will throw up some results. It wouldnt do your different methods of triangulation but its a start.
            My triangulateQuadFaces.rb already triangulates quad faces successfully but always from vertex[0] to vertex[2].
            It's here http://forums.sketchucation.com/viewtopic.php?p=201025#p201025
            You seem to want a subdivide option on top of that?
            My [and CJP's and TT's!] triangulateFaces.rb triangulates any face successfully but is 'messy', just like auto-fold ! http://forums.sketchucation.com/viewtopic.php?p=175613#p175613
            • soloS Offline
              TIG, you are correct, I want to use it with the SDS plugin, the current triangulation does not work well on all shapes, so if I had more ways to triangulate before subdivision the better and smoother results I can accomplish.
              • soloS Offline
                TIG, I downloaded both the ruby's and they work great for triangulating quads, and they seem to triangulate differently from each other (I did a test with a box), however they only split the quad, so they can only do 1 iriteration. Now id another ruby can be added to split a triangle into two, that would be awesome.
                Or... one ruby with an options panel, thus incorporating all triangulation/splitting ruby's into one.
                  The 'basic quad' version always divides a four-sided face from its vertex[0] to its vertex[2] wherever they are.
                  The 'general' version triangulates quads and upwards, but this uses the API mesh methods to divide the faces - this seems to take a face and divides it up from the first vertex it finds - which might be nearest the camera ? Therefore the results can differ...
                  They have a built in check and ignore any three-sided faces as they are already triangulated.
                  You could run [a yet to be invented script] 'subdivideAndTrianglulateQuadFaces()'...
                  Which subdivides each quad-face into a triangle [AND beyond], which is overlaid so that you have your 3/4/5th option for the subdivision: however, your 6th version needs to be done to the quad first as it becomes 4 quads then subdivided [its sibling is type-4]...
                  It's quite possible - any other ideas before I sleep on it ? 😐
                  • soloS Offline
                    Yea, that sounds awesome.
                    If it can group after triangulation that would be very handy when you need to SDS just parts of a model/mesh.
                      DIEGO-RODRIGUEZ
                      other opcion is subdivideSelected.rb (in English) of wikii.
                      has two options.
                      • division triangular
                      • division rectangular
                      http://img138.imageshack.us/img138/8563/subdivideselected.gif
                        Solo
                        So, if your Mandarin is up to it, then it might already exist ?
                        • soloS Offline
                          ooooh! 😲
                          Anyone able to translate that ruby? is it free? how can I get an English version?
                          • jeff hammondJ Offline
                            hey Pete,
                            wikii is a member here and i think that tool is included in SUtools?
                            http://forums.sketchucation.com/viewtopic.php?f=180&t=14480
                            the download link is missing now though.. maybe PM him?
                            [edit] oops, fixed link.
                              DIEGO-RODRIGUEZ
                              the plugin is free and simple of traslate
                              http://forums.sketchucation.com/viewtopic.php?f=323&t=24207
                                tallbridgeguy
                                Could somebody post a link to the ruby? It looks like a plugin I could use as well.
                                thanks!
                                s
                                Nielsen
                                http://www.tallbridgeguy.com/
                                  Here's a tweaked version of it, I've given it a Plugins submenu 'Subdivide Selected' with the two options of 'At Vertices' and 'At Mid-Points'.
                                  I also made a few minor adjustments and moved the midpoints def inside of the main def wrapper to avoid clashes with others...
                                  Seems to work fine.
                                  Hope wikii doesn't mind...
                                    DIEGO-RODRIGUEZ
                                    exelente tig. thank you very much.
                                    Maybe, Jim can add this option to plug protrudes, NO?
                                    • EarthMoverE Offline
                                      EarthMover
                                      Thanks TIG. Plugin works great for me. Curious to see Pete's new SDS method.
                                      Content Creator at Skapeup
                                      • soloS Offline
                                        Thanks a bunch TIG, this should do the trick.
                                        Adam, I am planning to use this division with Sculpt tools and SDS. Sculpt tools works great for moving vertices on pre-divided meshes, I feel like I have more control over what to expect from the subdivision now.
                                          Moved the thread to the Developer's forum. We have reorganized so that the Plugin section is only a list of plugins you can download and use. πŸ€“
