    Depressing Start!
    22 Posts 12 Posters 4.7k Views 12 Watching
    • V Offline
      verikon
      Have new Vista Ultimate machine, no mods.
      Installed SketchUp 7.
      Tried to start.
      Received following message:
      Problem Event Name: APPCRASH
      Application Name: SketchUp.exe
      Application Version: 7.0.10247.0
      Application Timestamp: 499de0d8
      Fault Module Name: Secur32.dll
      Fault Module Version: 6.0.6001.18215
      Fault Module Timestamp: 499533b0
      Exception Code: c0000005
      Exception Offset: 000021b3
      OS Version: 6.0.6001.2.1.0.256.1
      Locale ID: 1033
      Additional Information 1: fd00
      Additional Information 2: ea6f5fe8924aaa756324d57f87834160
      Additional Information 3: fd00
      Additional Information 4: ea6f5fe8924aaa756324d57f87834160
      Sketchup installed and run as administrator.
      Tried dragging existing SKP file over executable icon in SketchUp folder under Google programs, same result.
      What do I do?
      Many thanks!
        Well, as Andrew said, the Google SU Team is after your problem. Even "new" members of them have registered here to look into it, you can't expect more at the moment. I'm pretty sure they will let us (you) know if they find a solution, no need to start a new topic with the same issue.
        (I'm merging the two topics...)
          bobjfs
          I wanted to advise I am also having the same problem.
          My OS is: Microsoft Windows VistaT Home Premium - Win 32_ Operating System, Win 32_Computer System, CSDVersion Service Pack 1
          The problem event name reported as:
          OS Version: 6.0.6001.2.1.0.768.3
          Locale ID: 1033
          Additional Information 1: cb1e
          Additional Information 2: 79ac73f13bd1513b55fdc07e54106a3a
          Additional Information 3: 5191
          Additional Information 4: 291e1652affcc1b6558509d2dd528192
          At first, I erroneously installed Sketchup Pro 7. I uninstalled it and then attempted to install Sketchup 7, the non-pro version. Could this be the issue? If so, we may need a resolution at the registry level to remove all evidence of Sketchup Pro 7.
            Installing SU Pro first shouldn't have any affect on errors like this. In fact, you shouldn't even have uninstalled it first but even that shouldn't be a problem.
            I can imagine that software developers do not like to remove all evidence of a program that has ever been installed otherwise you could simply re-install the pro versions after each other thus gaining back the full functioning trial version every time you reinstall it.
            This error message is indeed a problem however has nothing to do with the pro vs free versions and installing them on top of each other.
              artupato
              Is sketchup 7 strict about 32bit or 64bit operating systems? I think some applications does not run on 64bit OS on windows vista. So, some applications are made to run on 64bit OS.
              hehe
              • Chris FullmerC Offline
                @thomthom said:
                SU have problems on 64bit systems.
                I'm not sure if that was a typo, or what you reamlly meant to say....
                I run SU on Vista 64 with absolutely no issues. Thom and Remus and others are running in on Windows7 64bit and have posted elsewhere that it is works great on their systems.
                  hehe
                  32bit applications will run on 64bit OS. However, 32bit drivers will not install, so any applciation that rely on 32bit drivers only will not function.
                  SU have no problems on 64bit systems.
                    That was my head going too fast for my fingers. I corrected the post.
                    • AndrewSA Offline
                      AndrewS
                      All,
                      We are looking into this problem, but unfortunately, none of our QA or development engineers has never seen this problem themselves, so we can't use our debugging tools to track it down.
                      When I spoke with one of our tech support people a couple of weeks ago, she had an idea that it is related to UAC (user account control in Vista), but nothing concrete. She theorized that disabling UAC might fix the problem, but of course, we cannot be responsible for your decision to do that, so proceed only at your own risk. If you want to try it, Google for instructions with a query such as "vista disable uac". If you do this, please let us know the results. If it works, you may also try re-enabling uac after the first time you run to see if it behaves any differently afterward.
                      I just sent word about this problem to a second tech support rep and hopefully he'll have some ideas as well.
                      I'd like to reiterate that SketchUp 7 Free and Pro should both work on XP (32-bit or 64-bit) and all editions of Vista (32-bit and 64-bit).
                      For those of you who are interested in more technical details, keep reading. Otherwise, ignore the rest.
                      Although the error message is cryptic, it is clear that whatever problem is occurring terminates inside the Windows system library Secur32.dll, which is a built-in module that assists with Windows security. As everyone is aware, Vista has far more security devices than XP, so it's likely that the added Vista security items are the source of the problem (no one has reported this problem on XP).
                      Essentially, whenever SketchUp (or any other program, for that matter) needs Windows to do something on its behalf, it makes a "call" into one of many system libraries that are built into Windows. It is by using these system libraries that programs get access to things like manipulating the registry or files on disk, determining the time of day, or finding out who is currently logged on, among thousands of other things. Evidently, in the course of trying to start SketchUp, a call is being made to a function that lives in Secur32.dll and that call is failing. The failure is probably due to a prerequisite not being met (an attribute being mis-configured before making the call, or something of that nature), or the function being given bogus data (probably because it isn't properly configured beforehand).
                      In order from least to most likely, the failure can be due to a bug in the library itself (Microsoft's fault); due to a bug in SketchUp (out fault); or due to a problem in a third-party module such as a graphics card driver, in the event that SketchUp calls the driver and the driver calls Secur32.dll (third party's fault). In any case, the inability of Secur32.dll to take the requested action causes Windows to forcefully terminate SketchUp.
                      We've briefly looked at the startup code that we know makes calls into Secur32.dll and we are unable to locate any problems with it. Since we cannot duplicate it however, we can't use our more robust tools to try to diagnose the source of the error in real time. Although it's possible the problem is in our code, I currently believe it is related to a bug in a third-party program such as a graphics driver (or, much less likely, a problem in Secur32.dll itself).
                      I was just about to submit this message, but the tech support person I mentioned earlier has just written back asking me to provide the following link, which shows a discussion about this very issue. Perhaps that will shed some light on the situation. http://groups.google.com/group/sketchupissues/browse_thread/thread/c99ddb127a18a933
                      Note that the link above provides several other links to folks complaining of this problem. In their cases, it appears to be isolated to HP hardware.
                      Please read the links, decide if you want to try the uac workaround, and then ultimately respond and let me know if any of the additional material sheds light on your situation(s).
                      Andrew S.
                      SketchUp Release Engineer
                        commander
                        Hi everyone, i had the same problem, with google sketchup 7, free version, i downloaded one week ago, (7.0.11018) i had the APPCRASH problem, with the same secure32.dll i dont understand that type of information, i didnt knew how to solved that. But what i know is that one week ago, i formatted mi cpu, and before that, i had GU installed, and i was working perfectly with it, even thought my computer wasnt in good conditions, so thats why i formatted it. But then i download the GU7, and it doesnt work, i try to download a NET framework, and that isnt the problem, what i thought, is that before i formatted, i hasnt have the NORTON INTERNET SECURITY CENTER, but after the format, it comes by default, so i erase it, and bingo! my sketchup is working fine... Norton always make thins so complicated.!
                        [imgfile:///C:/Users/Familia%20Pacheco/Desktop/Dibujo.jpgimg]
                        I want add the pic where it appears the norton, in the add/remove programs, but i dont know how to do it. so you can see the norton that i had! or maybe isnt neccesary! you are smarter guys...
                        hope this norton things can solve the problem for all you...
                        • 2 / 2
