    SU8 - WISHLIST
    203 Posts 61 Posters 76.5k Views 61 Watching
      tfdesign
      My wish-list would be as follows;
      1. Better management of layers!
      When a group or component is highlighted, the layer it's on really should highlight in the layers window. How many times do I start a new group on the wrong layer? Also iron out the bug (is it a bug or just me?) that prevents some entities not moving to the new selected layers, even though they have been selected to do so!
      1. A proper chamfer/ fillet tool (with a push/pull style controller- ala SpaceClaim), rather than that goddamn awful ruby script, which always goes the opposite direction to what you want it to!! 😡
      2. New Ruby scripts to be dropped into Ruby Console window, and SU places them automatically (rather than tearing one's hair out trying to figure out why they don't work).
      3. SketchUp for Linux (so the next computer I buy, is a (cheaper than a new Mac), PC, running a free operating system!)
      I'd be happy just for these for now 😄
        remus
        Are you using this plugin for filleting/chamfering http://forums.sketchucation.com/viewtopic.php?f=180&t=20485 ?
        There were a few dodgy ones before this but i've found this one to do everything i need.
          tfdesign
          Thanks Remus. I'll give it a spin. I was having so many problems with getting certain plugins to work, that I had decided not to use them, but I will give this a try, because it is such a useful function to have. 😄
          Tom
            The 2D Toolset includes a fillet/chamfer tools that works in 3D too...
              tfdesign
              Oh cool! Thanks TIG 😄
              I'll have to have another go. I'm going to have to try out SU Animate as well during the next week, because I've got to do a 3D SketchUp 'walk-through' in front of an audience, Sunday week. I'm a tad apprehensive as this is the first time I've had to do this (apart from at university- and even then, they were stills in Powerpoint).
                sketchymac
                -Built in Sketchy Physics
                -The ability to pick a Color from an existing colored Surface on Mac like you can do on PC.
                • jeff hammondJ Offline
                  dunno about your first wish but the second one works on mac.. two options:
                  one, use the magnifying glass icon to sample any color anywhere on your screen (sample a single pixel if you choose).. it's like this for all mac apps that use the standard color picker.
                  also, while the brush tool is selected, push ⌘ and an eyedropper will replace the paint bucket.. use that to sample any color or texture within the SU window.
                  [edit] and a little clarification as to why you might sample a color with the magnifying glass vs the eydropper (besides the fact that you can go outside the SU window with the mag.glass).. with the mag.glass, you will be sampling a color exactly as it appears at the moment.. (depending on the orientation of the SU model and the shading, your green may appear dark green etc..). with the brush tool/eyedropper, you'll be sampling the base color regardless of the SU shading.
                  • ken28875K Offline
                    ken28875
                    Rotation gizmo - It would be nice to be able to rotate each object using a gizmo (or whatever it is called) like in other programs such as Maya or Max. It would be faster and more efficient than the current rotation method where we need a plane/surface. Having a bounding box similar to the scale function in Sketchup for rotation would help. Thanks.
                    Follow Your Dreams.
                      Hi Ken,
                      I do not know any other 3D application (this of course, doesn1t mean there aren't any) whose Rotate tool would be as intuitive and easy to use as in SketchUp.
                      Just hold your left mouse button after you first clicked and drag it around to establish the axis of rotation (there is no need for different planes and such).
                      Then release, grab the model anywhere and Rotate. Every gizmo I have used so far is so much clumsier than this.
                      • mitcorbM Offline
                        mitcorb
                        Having a gizmo for SU would be yet another dimension of manipulation, such as the gizmo's that Blender uses. The effectiveness of Blender's gizmo is that it is not preempted by increments of distance or nearest inference point while moving along x, y, or z, scaling in x, y, or z or while rotating. These abilities are also seen in 3dVia's demo. But-- it's all a matter of what you are used to.
                          tfdesign
                          Full Screen Mode. (Without scene buttons in the way at the top too).
                          With the ability to split off the full screen to another monitor (if your PC supports that). This would be great for presentations (as I found out yesterday!).
                          Another handy feature would to be able to instruct SU, which way the camera swings when moving from scene to scene, because at the moment it predicts, and this can be rather vomit inducing- if you're not using a lot of transitory scenes.
                          • ken28875K Offline
                            ken28875
                            Thanks, Gaieus. I guess I just have to practice and get used to it, and hope that a gizmo for rotation will be available in the future.
                            Follow Your Dreams.
                              mpowell1234567890
                              The ability it import 3D Game levels for the free version of Sketchup 8.
                              • plot-parisP Offline
                                plot-paris
                                @gaieus said:
                                I do not know any other 3D application (...) whose Rotate tool would be as intuitive and easy to use as in SketchUp.
                                I totally agree with Gaieus. the approach SketchUp is taking to rotate, move or copy objects is one of the reasons why it is so incredibly fast to model with that application.
                                although I would appreciate the option to show/hide a transformation gizmo at the origin of groups/components. at the moment you can change the axes of a component (not of a group though). and you can see the axes - and therefore the origin of the component - when editing it. if you move groups/components around however, you don't know where the origin is.
                                in that case it could be helpful to have a transformation gizmo showing up at the groups/components origin and do all transformations (move, rotate, scale) around this point...
                                but let me emphasise, that this would only be a nice addition to current tools. for most things however I find the tools to be fantastic as they are...
                                • ken28875K Offline
                                  ken28875
                                  Selecting vertices and merging them. Right now Sketchup allows us to select only one vertex. I would love to be able to select as many as needed to move, rotate, or merge. For example, if two vertices are 10 m apart, selecting them and clicking on the merging tool will merge them at the middle point (5m); or slecting many vetices and merging them to a point/center of the group.
                                  Follow Your Dreams.
                                    plot-paris
                                    thats a good idea - merging vertices.
                                    I would also like more control over selection options and inferencing. being able to select vertices, edges, faces only would make certain tasks easier.
                                    also having an option to only select visible elements (at the moment if I draw a selection frame, everything will be selected, even if its hidden behind other geometry...).
                                    and being able to switch off coordinate axes inferencing would be great.
                                    and - I think it was mentioned earlier and I didn't really understand the idea behind it 😳 - having a modifier key to lock movement/drawing to a certain plane (similar to the arrow keys locking to a certain axis already). I would implement it like that: if you press the key - no matter if you are in the middle of an operation, like drawing a line - you get a gizmo (not much unlike the rotating wheel). you then click-drag to define the orientation (exactly like with the rotating tool). now the locked plane is shown with a dotted, light grey grid and you can proceed with the operation you were executing...
                                      LayOut can do full screen presentation and you can even set which monitor it should do it (surely you need the pro version for LayOut)
                                      Hi Jakob, have you tried to make the Component axes visible in the Model info > Components dialog? You could even assign a toggle on/off shortcut.
                                      How about the "Point Merger Tool" by BTM?
                                        plot-paris
                                        cool, thanks Gaieus. didn't know about that option...
                                        • ken28875K Offline
                                          ken28875
                                          How about the "Point Merger Tool" by BTM?[/quote]
                                          Hi Gaieus,
                                          Yes, that's the idea. But it is still very hard to control what to merge. I wish I can select which points to merge. I guess the merger will work better only when Sketchup allows us to select vertices.
                                          Thanks for the link, though.
                                          Follow Your Dreams.
                                          • ken28875K Offline
                                            ken28875
                                            UV Texture - I don't know if anyone has mentioned about UV yet. But that would be awesome to be able to UV texture the model the way Maya or Max does.
                                            Follow Your Dreams.
                                            • 11
                                            • 8 / 11
