    [Plugin] ExtrudelineTool Update
    72 Posts 28 Posters 89.0k Views 28 Watching
      where is the newly package script?
      I believe that Didier has forgotten to post it! πŸ˜‰
        See here for my new tool... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
          What has happened to Didier? He ok?
          • CadFatherC Offline
            CadFather
            hope so..it's been a while..
              Rivo
              Thanks a lot, it is just what I looking for. This tool can be updated? Sad it have no own button and can't select edges which will be extruded. Anyway this tool makes me happy=)
              Sorry for my lame English =)
                An Extrude [Rails,Edges,Lathe etc] toolbar is in progress...
                  Does the Extrude Edges select the new set of edges ready to be extruded again?
                    ExtudeEdgesByRails does leave the original three picked curves still selected, but if you run the tool again they are deselected and you must re-pick the profile and the rail(s)...
                    Why the question ? ❓
                    I think you are confusing my tool with Didier's ExtrudeLine tool, which now does what you asked, based on some code I clobbered together...
                      The question is because this is the thread for Didier's tool, and it doesn't select the new edges created. At least not the one in this thread. Is there an update elsewhere?
                      • plot-parisP Offline
                        plot-paris
                        πŸ˜„ funny. took me some time to read the title of this thread too...
                        but indeed. for me it doesn't select the new edges either... πŸ˜•
                          This got a bit side tracked with my tool... 😳
                          Didier's Extrude Line Tool is within his Projection Toolset... look for that http://forums.sketchucation.com/viewtopic.php?f=180&t=20140&p=171585&hilit=projection#p171585
                            Ah. I completely missed that plugin.
                              bandararith
                              how can i use this plug in??? i got the file extrudelinetool.rb, but i dont know where to pun it??? copy it to google sketchup file in drive(c:) or something. i so poor for this, please leave me the answer!!!
                                Hi bandararith,
                                Simply copy the file here:
                                C:\Program Files\Google\Google SketchUp 8\Plugins
                                • utilerU Offline
                                  utiler
                                  Hi Didier, love this plug-in!
                                  Just wondering if it's worth an option to hide geometry on curves and also an option o make a group or component?
                                  Cheers, A
                                  Just Curious...
                                  • designerbursaD Offline
                                    designerbursa
                                    arc problems 😞
                                      monmonred
                                      a sketchup 2014 update for this pleeeeease! πŸ˜„ thanks in advance!
                                      +Greatness may be measured on how much we have lost for the betterment of mankind+
                                        As I have said in some other threads for to Didier's 'packed' plugins...
                                        Edit the plugin's .rb file using Notepad.
                                        At the end of the code it says:
                                        .unpack("m")**.to_s**
                                        change the end part to read
                                        .unpack("m")**[0]**
                                        Save and restart SketchUp...
                                        It should now work fine in any SketchUp version.
                                          Didier has agreed that I might update some of his Plugins in the PluginStore.
                                          Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=extrudelinetool-Modified-TIG This is v2014/2015 compatible.
                                            Pherim
                                            Sketchup 2015 64bit sometimes freezes when I use this.
                                            • 2 / 4
