    Fields of green - help with large landscapes
    20 Posts 7 Posters 2.7k Views 7 Watching
    • tridemT
      tridem
      @leminilab said:
      Here's the link to the clip mapping grass tutorial !
      http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=startdown&id=10
      yeah, just what i was talking about! I've also read about a technique (might be by Fletch) using a layered material with two different textures weighted with a procedural, but I never tried this 😞
      however this is indeed matter for the KT forum...
      • EdsonE
        Edson
        read Google SketchUp for Site Design: A Guide to Modeling Site Plans, Terrain and Architecture, by daniel tal. it is a must for anyone who wants to produce terrains and landscapes seriously.
        http://www.mahfuz.arq.br
        • T
          tallbridgeguy
          Thanks Edson, I will check that book out! I appreciate the help.
          s
          Nielsen
          http://www.tallbridgeguy.com/
          • T
            tallbridgeguy
            I saw this tutorial and wondered if it would work?
            http://www.blender3darchitect.com/2009/10/modeling-terrains-with-displacement-maps-in-sketchup-and-blender-3d/
            So, maybe a ruby that does the following. (I think the ruby called "subdivide and smooth" may do this but I don't want to spend $22 to find out...)
            1. draw your area (landscape field)
            2. ruby step one - random subdivide of the field plane
            3. ruby step two - random Z height changes of the field
            4. ruby step three - smooth the field (bumps and gullies)
            5. use color by Z (chris fullmer plugin) to give the field different surface colors
            6. use a png of the field to create a displacement map?
            7. add texture to field
            8. combine displacement map and texture in rendering software
            Is this doable or just plain dumb?
            thanks!
            Nielsen
            • soloS
              tallguy, can you share yor model? I would like to see what can be achieved with Terragen2 and Geocontrol.
              • Chris FullmerC
                oooh, Terragen has been on my software list for years now, but what's geocontrol?
                • soloS
                  http://www.geocontrol2.com/e_index.htm
                  • T
                    tallbridgeguy
                    Pete I am at work right now but I have attached a basic bridge design. (Don't laugh at the modeling, I'm new)I can attach better ones when I get home.
                    So, the bridge concept is quickly developed and then I used KT to add some trees and grass.
                    thanks!
                    Stuart
                    terrain bridge.skp
                    Nielsen
                    • T
                      tallbridgeguy
                      The terrain in the bridge post above is an actual place in Calgary, Canada over the bow river. The island (st patrick) is 3-4 meters lower than the two banks. Calgary had a bridge design competition and I developed some concepts.
                      here is the site.
                      s
                      Nielsen
                      • T
                        tallbridgeguy
                        I used the sandbox tools to make some quick terrain but the bumps are not showing well in KT. (I know use a bump map)
                        So I tired the "color by Z" plugin and I thought I could make a bump map of the terrain to use in KT. The color by Z gives a color to all the different faces based on height and these faces show up in KT as different colors (obviously) si I could work with each face individually. I'm not sure where I am going with this....but all I wanted was some quick landscape around the bridge.
                        Does this make sense?
                        Nielsen
