    Fields of green - help with large landscapes
    20 Posts 7 Posters 2.7k Views 7 Watching
    • soloS Offline
      I'd say Vue 8 infinite, as it has all the bells and whistles, and you cannot upgrade from complete to infinite.
      Try the PLE version first.(free)
      • tridemT Offline
        tridem
        @ecuadorian said:
        I've heard someone created an amazing KT grass material that doesn't visibly tile. Has anyone found it?
        I'm not sure to want reveal this trick... πŸ˜†
        I usually use this method, don't remember where i read it (maybe KT or Indigo forum).
        After doing the grass surface I copy it some centimeters upon the original and give it another material. the lower one has a grass texture plus windy procedural, the upper one has a grass texture in the diffuse channel, the same texture and windy procedural in the clip mapping channel. It's not good for closest views, but for a big space helps to avoid 'tiling' effect without adding poligons.
        here's a quick example...
          tallbridgeguy
          Thanks tridem, love the grass!
          Nielsen
          http://www.tallbridgeguy.com/
            leminilab
            Here's the link to the clip mapping grass tutorial !
            http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=startdown&id=10
            Never tried this trick but Tridem's very clear demo really makes me wanna grow some grass... πŸ˜•
            • "Live every day as if it were your last and then some day you'll be right."
            • "ThomThom rules!!!"
            • tridemT Offline
              tridem
              yeah, just what i was talking about! I've also read about a technique (might be by Fletch) using a layered material with two different textures weighted with a procedural, but I never tried this 😞
              however this is indeed matter for the KT forum...
              • EdsonE Offline
                Edson
                read Google SketchUp for Site Design: A Guide to Modeling Site Plans, Terrain and Architecture, by daniel tal. it is a must for anyone who wants to produce terrains and landscapes seriously.
                http://www.mahfuz.arq.br
                  tallbridgeguy
                  Thanks Edson, I will check that book out! I appreciate the help.
                  s
                  Nielsen
                    tallbridgeguy
                    I saw this tutorial and wondered if it would work?
                    http://www.blender3darchitect.com/2009/10/modeling-terrains-with-displacement-maps-in-sketchup-and-blender-3d/
                    So, maybe a ruby that does the following. (I think the ruby called "subdivide and smooth" may do this but I don't want to spend $22 to find out...)
                    1. draw your area (landscape field)
                    2. ruby step one - random subdivide of the field plane
                    3. ruby step two - random Z height changes of the field
                    4. ruby step three - smooth the field (bumps and gullies)
                    5. use color by Z (chris fullmer plugin) to give the field different surface colors
                    6. use a png of the field to create a displacement map?
                    7. add texture to field
                    8. combine displacement map and texture in rendering software
                    Is this doable or just plain dumb?
                    thanks!
                    Nielsen
                    • soloS Offline
                      tallguy, can you share yor model? I would like to see what can be achieved with Terragen2 and Geocontrol.
                      • Chris FullmerC Offline
                        oooh, Terragen has been on my software list for years now, but what's geocontrol?
                        • soloS Offline
                          http://www.geocontrol2.com/e_index.htm
                            tallbridgeguy
                            Pete I am at work right now but I have attached a basic bridge design. (Don't laugh at the modeling, I'm new)I can attach better ones when I get home.
                            So, the bridge concept is quickly developed and then I used KT to add some trees and grass.
                            thanks!
                            Stuart
                            terrain bridge.skp
                            Nielsen
                              tallbridgeguy
                              The terrain in the bridge post above is an actual place in Calgary, Canada over the bow river. The island (st patrick) is 3-4 meters lower than the two banks. Calgary had a bridge design competition and I developed some concepts.
                              here is the site.
                              s
                              Nielsen
                                tallbridgeguy
                                I used the sandbox tools to make some quick terrain but the bumps are not showing well in KT. (I know use a bump map)
                                So I tired the "color by Z" plugin and I thought I could make a bump map of the terrain to use in KT. The color by Z gives a color to all the different faces based on height and these faces show up in KT as different colors (obviously) si I could work with each face individually. I'm not sure where I am going with this....but all I wanted was some quick landscape around the bridge.
                                Does this make sense?
                                Nielsen
