    A little Problem...
    59 Posts 15 Posters 4.0k Views 15 Watching
      @ Jeff
      Number's 3 answer is good but explanation seems lack of precision and sybilline for external visitor ๐Ÿ˜„
      What about object number 1,2,3,4,5,6,7,8,9,10,11,12? ๐Ÿ˜ฎ
      Does is it less or more heavy or current? ๐Ÿ˜‰
      • jeff hammondJ
        @ Jeff
        haha..
        i'm definitely not the best at explaining myself.. if i tried to explain using object numbers, it would get a lot more confusing i think ๐Ÿ˜„
        but here goes an example.. let's say the heavier object is #9
        place objects 1-6 on one side then objects 7-12 on the other.. 7-12 will weigh more so that eliminates objects 1-6
        place 7,8, & 9 on one side then 10, 11, & 12 on the other.. 7-9 will weigh more so that eliminates 10-12..
        place 7 on one side and 8 on the other... they weigh the same so that means 9 is the oddball.
        [EDIT] and then as Anssi said, in real life, you know you're going to test #9 against some of the other objects so the real world answer is at least 4 if not more ๐Ÿ˜„
        • jeff hammondJ
          You can't say first 9 is heavy!
          ha
          well i did that for sake of explanation..
          regardless, i can figure out the answer in about 5 seconds but i could sit here all day long trying to explain how ๐Ÿ˜„
          it's a fault of mine..
            @ Jeff : yes but...no ๐Ÿ’š
            You must make first all combinaisons and then say for this combinaison 9 is heavy !
            So draw first all the tree !
            Here your proposition ๐Ÿ˜„
              ๐Ÿ˜„
              If i take you 11 oranges and one false your explanation don't work ๐Ÿ˜†
              Only with a 1/24 hasard ๐Ÿ˜†
              • jeff hammondJ
                really? the way i see it, you can always find the the heavy one in 3 tries.. you mind showing the 1 out of 24 when it wouldn't work?
                further, using a different starting technique using 12 objects (5vs5), it's possible to find the oddball in 2 tries.. sometimes (17% chance of doing it 2)
                let's say the heavier object is #11..
                place 1,2,3,4,5 on one side and 6,7,8,9,10 on the other.. they weigh the same so that eliminates 1-10
                place #11 on one side and #12 on the other..
                11 weighs more so you've found it in 2 weighings.
                  remus
                  Annsi, sorry, typo. 2 is the right answer to the original question ๐Ÿ‘
                  Ive got another one for you.
                  http://upload.wikimedia.org/wikipedia/commons/0/07/Tower_of_Hanoi.jpeg
                  (This problem is an extended case of the above problem.)
                  The aim is to transfer all the discs from one pole to another without placing a larger disc on a smaller disc at any point.
                  The rules for moving the discs:
                  -you can only move 1 at a time,
                  -a move consists of moving one disc from one pole to another without changing the position of any other discs;
                  -a disc must always be placed on a larger disc or directly on the base.
                  If i can move the discs at a rate of 10 a minute, how long would it take me to complete a puzzle with 64 discs?
                  For additional cool points, can you prove your answer? and how does adding a 4th pillar effect the solution?
                  • jeff hammondJ
                    wait, you didn't mention what the finished puzzle should be.. do you mean start with the picture and move the stack to a different pole following your guidelines?
                    [edit1]oh wait.. 3 poles, all 64 discs are off the poles, then build one stack on one pole?
                    [edit2] ok, i think i got it now ๐Ÿ˜ณ.. start with a stack of 64 discs on one pole then transfer them to another pole ?
                      @Jeff
                      Of course yes, it's just the methodology ๐Ÿ˜‰
                      In the real world you will be obliged to make all combinaisons first till find a solution and say this is the false object! ๐Ÿ˜‰
                      Try it in the real world and you will see that i am right โ˜€
                        remus
                        Thats it, the aim is to move all the discs to another pole following the rules, so for 2 discs the solution would look like this:
                        • E
                          Ecuadorian
                          @remus said:
                          -a disc must always be placed on a larger disc.
                          ...or directly on the base.
                          -Miguel Lescano
                            remus
                            Updated ๐Ÿ˜„
                              That is more interresting ๐Ÿ’š
                              You can win 2 millions $ for make a "little" puzzle ๐Ÿ˜„
                              But now make speedy answer : 31 12 2009 end first step of the game! โ—
                              http://idolina.free.fr/images/ludique/logo Eternity.jpg
                              • jeff hammondJ
                                can i just answer 'it's going to take forever' ?
                                that is a huge huge number that i don't really know how to write ๐Ÿ˜„
                                i did find a method to obtain the answer though
                                basically,
                                2disc = 3 moves
                                3disc = 7
                                4disc = 15
                                5disc = 31
                                6disc = 63
                                etc..
                                following that sequence, 7discs = 127 then 8 = 255
                                i'll try to get it better than that though.
                                  remus
                                  Good start jeff ๐Ÿ‘ Youve got what we in the business call a recursive solution i.e. you can find n+1 if you know n.
                                  The general solution should be fairly easy to find from there.
                                    remus
                                    Your a factor of 100 out, you can make 10 moves a minute whereas i guess you took a move takes 10 minutes. Otherwise correct though ๐Ÿ‘
                                    • jeff hammondJ
                                      well, here's the answer i'm going to go with but this stuff is over my head.. i like the practical everyday logic puzzles much better ๐Ÿ˜„
                                      184,467,440,737,095,516,150 minutes
                                      [edit] hmm.. maybe that's 10 minutes too long? i guess you don't have to wait 10 minutes before making the very first move.
                                      [edit2] oops agian.. i figured it as if you make one move every 10 minutes instead of 10 per minute..
                                      so maybe it's more like
                                      1,844,674,407,370,955,161 minutes...and 30seconds
                                      • jeff hammondJ
                                        right.. i update my post as you were posting yours.
                                        ok, i'm gonna go eat ice cream now ๐Ÿ˜„
                                          remus
                                          Very sensible ๐Ÿ‘
                                          • DanielD
                                            Daniel
                                            204 minutes
                                            My avatar is an anachronism.
                                            • 3 / 3
