    A little Problem...
    59 Posts 15 Posters 2.2k Views 15 Watching
      πŸ˜„
      If i take you 11 oranges and one false your explanation don't work πŸ˜†
      Only with a 1/24 hasard πŸ˜†
      • jeff hammondJ Offline
        really? the way i see it, you can always find the the heavy one in 3 tries.. you mind showing the 1 out of 24 when it wouldn't work?
        further, using a different starting technique using 12 objects (5vs5), it's possible to find the oddball in 2 tries.. sometimes (17% chance of doing it 2)
        let's say the heavier object is #11..
        place 1,2,3,4,5 on one side and 6,7,8,9,10 on the other.. they weigh the same so that eliminates 1-10
        place #11 on one side and #12 on the other..
        11 weighs more so you've found it in 2 weighings.
          remus
          Annsi, sorry, typo. 2 is the right answer to the original question πŸ‘
          Ive got another one for you.
          http://upload.wikimedia.org/wikipedia/commons/0/07/Tower_of_Hanoi.jpeg
          (This problem is an extended case of the above problem.)
          The aim is to transfer all the discs from one pole to another without placing a larger disc on a smaller disc at any point.
          The rules for moving the discs:
          -you can only move 1 at a time,
          -a move consists of moving one disc from one pole to another without changing the position of any other discs;
          -a disc must always be placed on a larger disc or directly on the base.
          If i can move the discs at a rate of 10 a minute, how long would it take me to complete a puzzle with 64 discs?
          For additional cool points, can you prove your answer? and how does adding a 4th pillar effect the solution?
            wait, you didn't mention what the finished puzzle should be.. do you mean start with the picture and move the stack to a different pole following your guidelines?
            [edit1]oh wait.. 3 poles, all 64 discs are off the poles, then build one stack on one pole?
            [edit2] ok, i think i got it now 😳.. start with a stack of 64 discs on one pole then transfer them to another pole ?
              @Jeff
              Of course yes, it's just the methodology πŸ˜‰
              In the real world you will be obliged to make all combinaisons first till find a solution and say this is the false object! πŸ˜‰
              Try it in the real world and you will see that i am right β˜€
                remus
                Thats it, the aim is to move all the discs to another pole following the rules, so for 2 discs the solution would look like this:
                • E Offline
                  Ecuadorian
                  @remus said:
                  -a disc must always be placed on a larger disc.
                  ...or directly on the base.
                  -Miguel Lescano
                    remus
                    Updated πŸ˜„
                      That is more interresting πŸ’š
                      You can win 2 millions $ for make a "little" puzzle πŸ˜„
                      But now make speedy answer : 31 12 2009 end first step of the game! ❗
                      http://idolina.free.fr/images/ludique/logo Eternity.jpg
                        can i just answer 'it's going to take forever' ?
                        that is a huge huge number that i don't really know how to write πŸ˜„
                        i did find a method to obtain the answer though
                        basically,
                        2disc = 3 moves
                        3disc = 7
                        4disc = 15
                        5disc = 31
                        6disc = 63
                        etc..
                        following that sequence, 7discs = 127 then 8 = 255
                        i'll try to get it better than that though.
                          remus
                          Good start jeff πŸ‘ Youve got what we in the business call a recursive solution i.e. you can find n+1 if you know n.
                          The general solution should be fairly easy to find from there.
                            remus
                            Your a factor of 100 out, you can make 10 moves a minute whereas i guess you took a move takes 10 minutes. Otherwise correct though πŸ‘
                              well, here's the answer i'm going to go with but this stuff is over my head.. i like the practical everyday logic puzzles much better πŸ˜„
                              184,467,440,737,095,516,150 minutes
                              [edit] hmm.. maybe that's 10 minutes too long? i guess you don't have to wait 10 minutes before making the very first move.
                              [edit2] oops agian.. i figured it as if you make one move every 10 minutes instead of 10 per minute..
                              so maybe it's more like
                              1,844,674,407,370,955,161 minutes...and 30seconds
                                right.. i update my post as you were posting yours.
                                ok, i'm gonna go eat ice cream now πŸ˜„
                                  remus
                                  Very sensible πŸ‘
                                  • DanielD Offline
                                    Daniel
                                    204 minutes
                                    My avatar is an anachronism.
                                      remus
                                      howd you get that?
                                        is it not the famous HanoΓ― tower? πŸ˜‰
                                          fwiw, the way i figured it out was by physically doing the puzzle in sketchup with 2,3,4 & 5 discs then looking for a pattern..
                                          my results were
                                          3
                                          7
                                          15
                                          31
                                          which i realized was the same a 4,8,16,32,64,etc minus 1..
                                          then i had to find a big enough calculator to figure out the rest..
                                          Page not found – Welcome to the Petting Zoo
                                          (www.petting-zoo.org)
                                          i'm sure there's a way to do this using formulas but i'm more of a hands on type πŸ˜‰
                                          similar math is applied to this question:
                                          would you rather I give you $5000 right now -or- give you a penny right now, 2 pennies tomorrow, 4 pennies the next day etc.. for an entire month?
                                          • E Offline
                                            Ecuadorian
                                            Only Bill Gates and a few other chaps have enough spare change to pay the amount you would owe me, Jeff ($10,737,418.23), so I prefer you give me the $5,000 today.
                                            EDIT: I mistook pennies for dollars and 5000 for 500, so I updated my post.
                                            -Miguel Lescano
                                            • 3 / 3
