    A little Problem...
    59 Posts 15 Posters 4.0k Views 15 Watching
    • jeff hammondJ
      really? the way i see it, you can always find the the heavy one in 3 tries.. you mind showing the 1 out of 24 when it wouldn't work?
      further, using a different starting technique using 12 objects (5vs5), it's possible to find the oddball in 2 tries.. sometimes (17% chance of doing it 2)
      let's say the heavier object is #11..
      place 1,2,3,4,5 on one side and 6,7,8,9,10 on the other.. they weigh the same so that eliminates 1-10
      place #11 on one side and #12 on the other..
      11 weighs more so you've found it in 2 weighings.
        remus
        Annsi, sorry, typo. 2 is the right answer to the original question πŸ‘
        Ive got another one for you.
        http://upload.wikimedia.org/wikipedia/commons/0/07/Tower_of_Hanoi.jpeg
        (This problem is an extended case of the above problem.)
        The aim is to transfer all the discs from one pole to another without placing a larger disc on a smaller disc at any point.
        The rules for moving the discs:
        -you can only move 1 at a time,
        -a move consists of moving one disc from one pole to another without changing the position of any other discs;
        -a disc must always be placed on a larger disc or directly on the base.
        If i can move the discs at a rate of 10 a minute, how long would it take me to complete a puzzle with 64 discs?
        For additional cool points, can you prove your answer? and how does adding a 4th pillar effect the solution?
        • jeff hammondJ
          wait, you didn't mention what the finished puzzle should be.. do you mean start with the picture and move the stack to a different pole following your guidelines?
          [edit1]oh wait.. 3 poles, all 64 discs are off the poles, then build one stack on one pole?
          [edit2] ok, i think i got it now 😳.. start with a stack of 64 discs on one pole then transfer them to another pole ?
            @Jeff
            Of course yes, it's just the methodology πŸ˜‰
            In the real world you will be obliged to make all combinaisons first till find a solution and say this is the false object! πŸ˜‰
            Try it in the real world and you will see that i am right β˜€
              remus
              Thats it, the aim is to move all the discs to another pole following the rules, so for 2 discs the solution would look like this:
              • E
                Ecuadorian
                @remus said:
                -a disc must always be placed on a larger disc.
                ...or directly on the base.
                -Miguel Lescano
                  remus
                  Updated πŸ˜„
                    That is more interresting πŸ’š
                    You can win 2 millions $ for make a "little" puzzle πŸ˜„
                    But now make speedy answer : 31 12 2009 end first step of the game! ❗
                    http://idolina.free.fr/images/ludique/logo Eternity.jpg
                    • jeff hammondJ
                      can i just answer 'it's going to take forever' ?
                      that is a huge huge number that i don't really know how to write πŸ˜„
                      i did find a method to obtain the answer though
                      basically,
                      2disc = 3 moves
                      3disc = 7
                      4disc = 15
                      5disc = 31
                      6disc = 63
                      etc..
                      following that sequence, 7discs = 127 then 8 = 255
                      i'll try to get it better than that though.
                        remus
                        Good start jeff πŸ‘ Youve got what we in the business call a recursive solution i.e. you can find n+1 if you know n.
                        The general solution should be fairly easy to find from there.
                          remus
                          Your a factor of 100 out, you can make 10 moves a minute whereas i guess you took a move takes 10 minutes. Otherwise correct though πŸ‘
                          • jeff hammondJ
                            well, here's the answer i'm going to go with but this stuff is over my head.. i like the practical everyday logic puzzles much better πŸ˜„
                            184,467,440,737,095,516,150 minutes
                            [edit] hmm.. maybe that's 10 minutes too long? i guess you don't have to wait 10 minutes before making the very first move.
                            [edit2] oops agian.. i figured it as if you make one move every 10 minutes instead of 10 per minute..
                            so maybe it's more like
                            1,844,674,407,370,955,161 minutes...and 30seconds
                            • jeff hammondJ
                              right.. i update my post as you were posting yours.
                              ok, i'm gonna go eat ice cream now πŸ˜„
                                remus
                                Very sensible πŸ‘
                                • DanielD
                                  Daniel
                                  204 minutes
                                  My avatar is an anachronism.
                                    remus
                                    howd you get that?
                                      is it not the famous HanoΓ― tower? πŸ˜‰
                                      • jeff hammondJ
                                        fwiw, the way i figured it out was by physically doing the puzzle in sketchup with 2,3,4 & 5 discs then looking for a pattern..
                                        my results were
                                        3
                                        7
                                        15
                                        31
                                        which i realized was the same a 4,8,16,32,64,etc minus 1..
                                        then i had to find a big enough calculator to figure out the rest..
                                        Site not found Β· DreamHost
                                        The owner of this domain has not yet uploaded their website.
                                        (www.petting-zoo.org)
                                        i'm sure there's a way to do this using formulas but i'm more of a hands on type πŸ˜‰
                                        similar math is applied to this question:
                                        would you rather I give you $5000 right now -or- give you a penny right now, 2 pennies tomorrow, 4 pennies the next day etc.. for an entire month?
                                        • E
                                          Ecuadorian
                                          Only Bill Gates and a few other chaps have enough spare change to pay the amount you would owe me, Jeff ($10,737,418.23), so I prefer you give me the $5,000 today.
                                          EDIT: I mistook pennies for dollars and 5000 for 500, so I updated my post.
                                          -Miguel Lescano
                                            remus
                                            Pilou, it is indeed the towers of hanoi problem.
                                            In a similar vein there is the wheat and chessboard story: http://en.wikipedia.org/wiki/Wheat_and_chessboard_problem
                                            • 3 / 3
