    A little Problem...
    59 Posts 15 Posters 4.0k Views 15 Watching
    • daleD
      dale
      OK now if you model and render the eight balls and seven rabbits, the price of the rabbits will go up,(because thats going to take a while, and time is money) and the weight of the balls will vary based on the visual weight they are allotted, now things are different! (oh render engine of your choice by the way ๐Ÿ˜„ )
        @ Jeff
        Number's 3 answer is good but explanation seems lack of precision and sybilline for external visitor ๐Ÿ˜„
        What about object number 1,2,3,4,5,6,7,8,9,10,11,12? ๐Ÿ˜ฎ
        Does is it less or more heavy or current? ๐Ÿ˜‰
        • jeff hammondJ
          @ Jeff
          haha..
          i'm definitely not the best at explaining myself.. if i tried to explain using object numbers, it would get a lot more confusing i think ๐Ÿ˜„
          but here goes an example.. let's say the heavier object is #9
          place objects 1-6 on one side then objects 7-12 on the other.. 7-12 will weigh more so that eliminates objects 1-6
          place 7,8, & 9 on one side then 10, 11, & 12 on the other.. 7-9 will weigh more so that eliminates 10-12..
          place 7 on one side and 8 on the other... they weigh the same so that means 9 is the oddball.
          [EDIT] and then as Anssi said, in real life, you know you're going to test #9 against some of the other objects so the real world answer is at least 4 if not more ๐Ÿ˜„
          • jeff hammondJ
            You can't say first 9 is heavy!
            ha
            well i did that for sake of explanation..
            regardless, i can figure out the answer in about 5 seconds but i could sit here all day long trying to explain how ๐Ÿ˜„
            it's a fault of mine..
              @ Jeff : yes but...no ๐Ÿ’š
              You must make first all combinaisons and then say for this combinaison 9 is heavy !
              So draw first all the tree !
              Here your proposition ๐Ÿ˜„
                ๐Ÿ˜„
                If i take you 11 oranges and one false your explanation don't work ๐Ÿ˜†
                Only with a 1/24 hasard ๐Ÿ˜†
                • jeff hammondJ
                  really? the way i see it, you can always find the the heavy one in 3 tries.. you mind showing the 1 out of 24 when it wouldn't work?
                  further, using a different starting technique using 12 objects (5vs5), it's possible to find the oddball in 2 tries.. sometimes (17% chance of doing it 2)
                  let's say the heavier object is #11..
                  place 1,2,3,4,5 on one side and 6,7,8,9,10 on the other.. they weigh the same so that eliminates 1-10
                  place #11 on one side and #12 on the other..
                  11 weighs more so you've found it in 2 weighings.
                    remus
                    Annsi, sorry, typo. 2 is the right answer to the original question ๐Ÿ‘
                    Ive got another one for you.
                    http://upload.wikimedia.org/wikipedia/commons/0/07/Tower_of_Hanoi.jpeg
                    (This problem is an extended case of the above problem.)
                    The aim is to transfer all the discs from one pole to another without placing a larger disc on a smaller disc at any point.
                    The rules for moving the discs:
                    -you can only move 1 at a time,
                    -a move consists of moving one disc from one pole to another without changing the position of any other discs;
                    -a disc must always be placed on a larger disc or directly on the base.
                    If i can move the discs at a rate of 10 a minute, how long would it take me to complete a puzzle with 64 discs?
                    For additional cool points, can you prove your answer? and how does adding a 4th pillar effect the solution?
                    • jeff hammondJ
                      wait, you didn't mention what the finished puzzle should be.. do you mean start with the picture and move the stack to a different pole following your guidelines?
                      [edit1]oh wait.. 3 poles, all 64 discs are off the poles, then build one stack on one pole?
                      [edit2] ok, i think i got it now ๐Ÿ˜ณ.. start with a stack of 64 discs on one pole then transfer them to another pole ?
                        @Jeff
                        Of course yes, it's just the methodology ๐Ÿ˜‰
                        In the real world you will be obliged to make all combinaisons first till find a solution and say this is the false object! ๐Ÿ˜‰
                        Try it in the real world and you will see that i am right โ˜€
                          remus
                          Thats it, the aim is to move all the discs to another pole following the rules, so for 2 discs the solution would look like this:
                          • E
                            Ecuadorian
                            @remus said:
                            -a disc must always be placed on a larger disc.
                            ...or directly on the base.
                            -Miguel Lescano
                              remus
                              Updated ๐Ÿ˜„
                                That is more interresting ๐Ÿ’š
                                You can win 2 millions $ for make a "little" puzzle ๐Ÿ˜„
                                But now make speedy answer : 31 12 2009 end first step of the game! โ—
                                http://idolina.free.fr/images/ludique/logo Eternity.jpg
                                • jeff hammondJ
                                  can i just answer 'it's going to take forever' ?
                                  that is a huge huge number that i don't really know how to write ๐Ÿ˜„
                                  i did find a method to obtain the answer though
                                  basically,
                                  2disc = 3 moves
                                  3disc = 7
                                  4disc = 15
                                  5disc = 31
                                  6disc = 63
                                  etc..
                                  following that sequence, 7discs = 127 then 8 = 255
                                  i'll try to get it better than that though.
                                    remus
                                    Good start jeff ๐Ÿ‘ Youve got what we in the business call a recursive solution i.e. you can find n+1 if you know n.
                                    The general solution should be fairly easy to find from there.
                                      remus
                                      Your a factor of 100 out, you can make 10 moves a minute whereas i guess you took a move takes 10 minutes. Otherwise correct though ๐Ÿ‘
                                      • jeff hammondJ
                                        well, here's the answer i'm going to go with but this stuff is over my head.. i like the practical everyday logic puzzles much better ๐Ÿ˜„
                                        184,467,440,737,095,516,150 minutes
                                        [edit] hmm.. maybe that's 10 minutes too long? i guess you don't have to wait 10 minutes before making the very first move.
                                        [edit2] oops agian.. i figured it as if you make one move every 10 minutes instead of 10 per minute..
                                        so maybe it's more like
                                        1,844,674,407,370,955,161 minutes...and 30seconds
                                        • jeff hammondJ
                                          right.. i update my post as you were posting yours.
                                          ok, i'm gonna go eat ice cream now ๐Ÿ˜„
                                            remus
                                            Very sensible ๐Ÿ‘
                                            • 2 / 3
