    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 296.3k Views 135 Watching
      Select an element (lines, surface)
      Open Entity Info yes ๐Ÿ˜‰
      Then when you select with Shift , Shift + Ctrl or Ctrl
      all surfaces or length lines are added , subbstracted, modified, visible and updated in the Entity info! ๐Ÿ˜„ ๐Ÿ˜’
        OK, this is a very painful duh:
        My system seemed to crash and I could not even start windows in safe mode (Mac users, don't sneer, please) so I decided to at least try to repair my system. It didn't allow me as whatever imaginable I entered, it didn't accept it as the password of the system admin.
        So I reinstalled (I have a recent backup of my documents at least). Then I realised that I didn1t even have a password and should have just hit Enter without entering any password.
        ๐Ÿ˜ณ
        So basically this is what I wasted my Sunday for. I have a deadline tomorrow. ๐Ÿ˜•
        • plot-parisP Offline
          plot-paris
          oh, that is a really bad one, Gaieus! I am not sure if I should burst with laughter ๐Ÿคฃ , feel terribly sorry for you ๐Ÿ˜ž or just blush with embarassment, because that could just as well have happened to me ๐Ÿ˜ณ
            plot-paris
            another one. after importing a messy 3Ds model and cleaning it up with Thomthoms cleanup-script (thanks again, thom), I started entering every single one of the over 1500 groups/components, to smooth their surfaces.
            then I just discovered, that you can apply the smoothing to groups/components, without entering them. so you can select all the groups at once and only have to do the proces once! (doesn't work with nested groups though)
              I recently discovered that as well!
              In regards to CleanUp - it does have a function to smooth the geometry it cleans up. If you use CleanUp Entire Model you have a field "Smooth Edges by Angle".
                plot-paris
                yet another 'Doh'
                I can put my Homer button to quite some use today ๐Ÿ˜„
                  Well, eventually it turned out that the total HD was broken so no matter what I would've done, the repair/install wouldn't have been successful. Had to buy a new HD and reinstall everything again. ๐Ÿ˜ข
                    plot-paris
                    uh, thats bad!
                    actually, I still try to deny that hard discs just die after several years of intenseive use. its not pleasant, when the truth catches up with you...
                    • broomstickB Offline
                      broomstick
                      I just discovered that the erase function hides and smoothes edges if you use it in combination with atl ctrl an shift...
                      DUH!!
                      • E Offline
                        Ecuadorian
                        Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. ๐Ÿ˜ฒ
                        -Miguel Lescano
                          ๐Ÿ‘ Tricky and speedy ๐Ÿ˜Ž
                          • Chris FullmerC Offline
                            I just discovered that you can use more than one modifier key when setting up shortcut keys. example
                            ctrl + shift + alt + Q
                            or snything along those lines. I never reazlied that... ๐Ÿ˜ณ
                              plot-paris
                              just out of interest: what function did you assign to
                              Ctrl + Shift + Alt + Q???
                                When I press that, it triggers an automatic poking of you on Facebook.
                                ๐Ÿคฃ
                                (I dare not try if there is anything assigned to it by default because I am rendering an animation) ๐Ÿ˜•
                                  It is my auto-assinate button in SU ๐Ÿ˜„
                                  I don't really have it assigned to anything. It was just an example of how complex a "shortcut" could be. I thought I was stuck to simple single modifiers. Double modifiers could greatly expand my shortcut range though!
                                  • mitcorbM Offline
                                    mitcorb
                                    Now, what would an "auto-assinate" button do, exactly?
                                    Hee Hee!
                                      I struggle...
                                        A list of shortcuts ๐Ÿ’š
                                          Triangulate a simple rectangle surface with the Sand box? ๐Ÿ˜ณ
                                          Just draw a diagonal first! ๐Ÿ˜ฎ
                                          Then apply the Sand box "Add dรฉtails" ๐Ÿ’š
                                            A cool one! ๐Ÿ˜ณ
                                            The Duhduh of the day! Never used! ๐Ÿ˜’
                                            Thx Jeff โ˜€
                                            http://forums.sketchucation.com/download/file.php?id=41868&mode=view
                                            • 34
                                            • 35
                                            • 5 / 35
