    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 296.4k Views 135 Watching
    • Chris FullmerC Offline
      I just found one for me tonight. I change the model axis pretty often when I work. But I never noticed that you can activate the axis tool (or change axis inside of a component tool) and click twice somewhere and it will move the axis to that point without changing its orientation. Normally I would have clicked once, then lined up the the axes and click and line up and click. So a double click (not too fast though!) is much faster for moving the axis.
        Select an element (lines, surface)
        Open Entity Info yes ๐Ÿ˜‰
        Then when you select with Shift , Shift + Ctrl or Ctrl
        all surfaces or length lines are added , subbstracted, modified, visible and updated in the Entity info! ๐Ÿ˜„ ๐Ÿ˜’
          OK, this is a very painful duh:
          My system seemed to crash and I could not even start windows in safe mode (Mac users, don't sneer, please) so I decided to at least try to repair my system. It didn't allow me as whatever imaginable I entered, it didn't accept it as the password of the system admin.
          So I reinstalled (I have a recent backup of my documents at least). Then I realised that I didn1t even have a password and should have just hit Enter without entering any password.
          ๐Ÿ˜ณ
          So basically this is what I wasted my Sunday for. I have a deadline tomorrow. ๐Ÿ˜•
          • plot-parisP Offline
            plot-paris
            oh, that is a really bad one, Gaieus! I am not sure if I should burst with laughter ๐Ÿคฃ , feel terribly sorry for you ๐Ÿ˜ž or just blush with embarassment, because that could just as well have happened to me ๐Ÿ˜ณ
              plot-paris
              another one. after importing a messy 3Ds model and cleaning it up with Thomthoms cleanup-script (thanks again, thom), I started entering every single one of the over 1500 groups/components, to smooth their surfaces.
              then I just discovered, that you can apply the smoothing to groups/components, without entering them. so you can select all the groups at once and only have to do the proces once! (doesn't work with nested groups though)
                I recently discovered that as well!
                In regards to CleanUp - it does have a function to smooth the geometry it cleans up. If you use CleanUp Entire Model you have a field "Smooth Edges by Angle".
                  plot-paris
                  yet another 'Doh'
                  I can put my Homer button to quite some use today ๐Ÿ˜„
                    Well, eventually it turned out that the total HD was broken so no matter what I would've done, the repair/install wouldn't have been successful. Had to buy a new HD and reinstall everything again. ๐Ÿ˜ข
                      plot-paris
                      uh, thats bad!
                      actually, I still try to deny that hard discs just die after several years of intenseive use. its not pleasant, when the truth catches up with you...
                      • broomstickB Offline
                        broomstick
                        I just discovered that the erase function hides and smoothes edges if you use it in combination with atl ctrl an shift...
                        DUH!!
                        • E Offline
                          Ecuadorian
                          Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. ๐Ÿ˜ฒ
                          -Miguel Lescano
                            ๐Ÿ‘ Tricky and speedy ๐Ÿ˜Ž
                              I just discovered that you can use more than one modifier key when setting up shortcut keys. example
                              ctrl + shift + alt + Q
                              or snything along those lines. I never reazlied that... ๐Ÿ˜ณ
                                plot-paris
                                just out of interest: what function did you assign to
                                Ctrl + Shift + Alt + Q???
                                  When I press that, it triggers an automatic poking of you on Facebook.
                                  ๐Ÿคฃ
                                  (I dare not try if there is anything assigned to it by default because I am rendering an animation) ๐Ÿ˜•
                                    It is my auto-assinate button in SU ๐Ÿ˜„
                                    I don't really have it assigned to anything. It was just an example of how complex a "shortcut" could be. I thought I was stuck to simple single modifiers. Double modifiers could greatly expand my shortcut range though!
                                    • mitcorbM Offline
                                      mitcorb
                                      Now, what would an "auto-assinate" button do, exactly?
                                      Hee Hee!
                                        I struggle...
                                          A list of shortcuts ๐Ÿ’š
                                            Triangulate a simple rectangle surface with the Sand box? ๐Ÿ˜ณ
                                            Just draw a diagonal first! ๐Ÿ˜ฎ
                                            Then apply the Sand box "Add dรฉtails" ๐Ÿ’š
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 31 / 35
