    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 170.5k Views 73 Watching
    • W Offline
      Whaat
      @remus said:
      Any tips on opening the .obj in blender 2.5? ive tried just straight file->import but i cant see anything afterwards...
      I haven't used version 2.5 yet. With my older version, I had to go the menu item 'File->Import->Wavefront OBJ' and then browse for the file.
      Depending on the scale and location of the object, it might not be immediately visible in the Blender 3D view. Is there a command in Blender to 'Fit the view to the scene'?
        Seems a new true gem β˜€
        @Remus: you have Blender 2.5? 😲
          Blender Shortcuts πŸ˜‰
          Seems it's Home
            Khai
            testing it now.. but it looks like as a sideline, you've created a good OBJ exporter.....
            ok. you've created as a sideline, a almost perfect OBJ exporter for Sketchup. (just the naming / save location)
            hot damn. UVmapping and OBJ exporting.... you should see the grin on my face!
              remus
              Pilou, you can get the latest builds (pre beta at the moment) from here: http://www.graphicall.org/builds/
              Whaat, i'll give 2.49 a try this evening and let you know how it goes.
                Khai
                ok been playing with this today and I consider it a must have already...
                • jeff hammondJ Offline
                  khai - you have to sell it man!
                  let's see some pictures of what you've come up with πŸ˜„
                    Khai
                    lol sorry
                    the bugbears I've had is UVmapping and OBJ export..and this solves both in one shot.. I'm kinda excited lol
                    • W Offline
                      Whaat
                      Yeah...let's see some pictures of what you guys can do with this! πŸ˜„
                      • StinkieS Offline
                        Stinkie
                        Thanks, Dale. Will try this with Modo.
                        • EarthMoverE Offline
                          EarthMover
                          Dale, tested with 3ds Max and it worked flawlessly on this teardrop shape using the Unwrap UVW modifier. Thanks for the plugin. It will fix a lot of headaches!!
                          One of the issues is that once a UV is imported, it does not "stick" to the geometry it was assigned to. For example if I did not like this brick and wanted to replace it with another material, the UV's become scrambled again. Also when I try to undo after importing the UV's, I get a SU crash.
                          Content Creator at Skapeup
                          • W Offline
                            Whaat
                            Great! Another app to add to the list! Thanks for testing πŸ˜„
                            Yeah, I hate that SketchUp does not keep UVs when switching materials. I'll look into that crash, too. Thanks!
                            • N Offline
                              NewOne
                              Can you write the UV data in an attribute? And using it from there... It would increase the size of the file, I think... for each face to write separate UV. But it can be a way.
                              • W Offline
                                Whaat
                                Yes, you can. I use that method in SkIndigo but I have not yet added the feature to UVTools.
                                • N Offline
                                  NewOne
                                  When using Oscar's UV mapping and tried to render with Maxwellrender I noticed that it exported a bitmap for each face and made a copy of used material for each exported bitmap. So, I had situations when I had 1000 materials just for one object πŸ˜•
                                  This is strange... I was eexpecting that the bitmap to be folded around object.
                                    @whaat said:
                                    I have NOT yet tested this plugin on a Mac but I suspect that it will work fine.
                                    nah, it doesn't even appear in the context menu.. (well, the spherical & cylindrical still do but that's it)
                                    edit-
                                    haha.. hold on a minute.. i guess i'm in the wrong place because it is in the plugins menu.. πŸ˜†
                                    [cut me some slack though..it's friday night and i'm messing around with wine & UV mapping)
                                      Khai
                                      should one drink and draw? πŸ‘Ώ
                                        ha.. sure - just don't look at the drawings in the morning and everything will be okay.
                                        the plugin works on mac just fine (tested using argile)
                                        i don't think that's the right app for me but that's beside the point..
                                          princedragoncok
                                          Thankyou Whaat for this fantastic plugin. I tried it with UVLayout. It failed to work with Sketchup 6 and had me feeling gutted that I had spent a few hours learning uvlayout for no reason. Then tried it with Sketchup 7 and it worked thankfully!
                                          Yes, the uv's will become scrambled momentarily when you change to a completely different material, but go back to the uvtools in the plugins menu and re-import your external uv settings onto the newly scrambled material and it will revert back to the pervious mapping settings you had but with the new material.
                                          So here is a quick example of the plugin in action:
                                          In su7 before:
                                          http://i346.photobucket.com/albums/p420/princedragoncok/Untitled-2.jpg
                                          With the plugin applied using uvlayout:
                                          http://i346.photobucket.com/albums/p420/princedragoncok/Untitled2-1.jpg
                                          I have run into perhaps a bug though.. while I set up the uv mapping correctly in uvlayout - I got an error message when importing into sketchup. It told me import successful but 1 face failed.. This is the result:
                                          Before:
                                          http://i346.photobucket.com/albums/p420/princedragoncok/Untitled6-1.jpg
                                          After (notice the scrambling along the center)
                                          http://i346.photobucket.com/albums/p420/princedragoncok/Untitled7-2.jpg
                                          I have one more question which isn't related to the plugin but something I have experienced myself (with my basic uvmapping skills) and is something I also noticed in Whaat's videos. When I split open my mesh to flatten it, when it reassembles the joining seam never lines up correctly... any simple suggestions to combat this?? i'm thinking there must be some sort of weld function i'm missing inside the uvprogram. Here's an illustration anyway:
                                          http://i346.photobucket.com/albums/p420/princedragoncok/Untitled4-1.jpg
                                          • W Offline
                                            Whaat
                                            Are you sure it only works in SU7? If so, that's very strange.
                                            It looks like from your image that more than one face failed. This 'bug' seems to be caused from SketchUp not 'liking' the UVs that are generated from the external application. I'm not sure how fixable it is...
                                            Seams are (by definition) discontinuities in the UV coordinates. I think the only way to avoid seams is to use spherical and cylindrical mapping. I don't have a ton of experience with UV software. There might be a weld-type function somewhere that will align the UVs along both edges of a seam.
                                            • 1 / 10
