    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 187.6k Views 73 Watching
      remus
      Any tips on opening the .obj in blender 2.5? ive tried just straight file->import but i cant see anything afterwards...
      • K
        Khai
        Works fine with UVmapper Pro πŸ˜„
        • K
          Khai
          oh MAN
          I love this already!!!!!!!!!
          • W
            Whaat
            I haven't used version 2.5 yet. With my older version, I had to go the menu item 'File->Import->Wavefront OBJ' and then browse for the file.
            Depending on the scale and location of the object, it might not be immediately visible in the Blender 3D view. Is there a command in Blender to 'Fit the view to the scene'?
              Seems a new true gem β˜€
              @Remus: you have Blender 2.5? 😲
                Blender Shortcuts πŸ˜‰
                Seems it's Home
                • K
                  Khai
                  testing it now.. but it looks like as a sideline, you've created a good OBJ exporter.....
                  ok. you've created as a sideline, a almost perfect OBJ exporter for Sketchup. (just the naming / save location)
                  hot damn. UVmapping and OBJ exporting.... you should see the grin on my face!
                    remus
                    Pilou, you can get the latest builds (pre beta at the moment) from here: http://www.graphicall.org/builds/
                    Whaat, i'll give 2.49 a try this evening and let you know how it goes.
                    • K
                      Khai
                      ok been playing with this today and I consider it a must have already...
                      • jeff hammondJ
                        khai - you have to sell it man!
                        let's see some pictures of what you've come up with πŸ˜„
                        • K
                          Khai
                          lol sorry
                          the bugbears I've had is UVmapping and OBJ export..and this solves both in one shot.. I'm kinda excited lol
                          • W
                            Whaat
                            Yeah...let's see some pictures of what you guys can do with this! πŸ˜„
                            • StinkieS
                              Stinkie
                              Thanks, Dale. Will try this with Modo.
                              • EarthMoverE
                                EarthMover
                                Dale, tested with 3ds Max and it worked flawlessly on this teardrop shape using the Unwrap UVW modifier. Thanks for the plugin. It will fix a lot of headaches!!
                                One of the issues is that once a UV is imported, it does not "stick" to the geometry it was assigned to. For example if I did not like this brick and wanted to replace it with another material, the UV's become scrambled again. Also when I try to undo after importing the UV's, I get a SU crash.
                                Content Creator at Skapeup
                                • W
                                  Whaat
                                  Great! Another app to add to the list! Thanks for testing πŸ˜„
                                  Yeah, I hate that SketchUp does not keep UVs when switching materials. I'll look into that crash, too. Thanks!
                                  • N
                                    NewOne
                                    Can you write the UV data in an attribute? And using it from there... It would increase the size of the file, I think... for each face to write separate UV. But it can be a way.
                                    • W
                                      Whaat
                                      Yes, you can. I use that method in SkIndigo but I have not yet added the feature to UVTools.
                                      • N
                                        NewOne
                                        When using Oscar's UV mapping and tried to render with Maxwellrender I noticed that it exported a bitmap for each face and made a copy of used material for each exported bitmap. So, I had situations when I had 1000 materials just for one object πŸ˜•
                                        This is strange... I was eexpecting that the bitmap to be folded around object.
                                        • jeff hammondJ
                                          @whaat said:
                                          I have NOT yet tested this plugin on a Mac but I suspect that it will work fine.
                                          nah, it doesn't even appear in the context menu.. (well, the spherical & cylindrical still do but that's it)
                                          edit-
                                          haha.. hold on a minute.. i guess i'm in the wrong place because it is in the plugins menu.. πŸ˜†
                                          [cut me some slack though..it's friday night and i'm messing around with wine & UV mapping)
                                          • K
                                            Khai
                                            should one drink and draw? πŸ‘Ώ
                                            • 1 / 10
