    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 348.6k Views 71 Watching
    • mitcorbM Offline
      mitcorb
      @xrok1:
      for your excellent bowl and spork and "foon" model, did you use specific dimensions and scale? Or was this a free form experiment and the model elements proportioned by eye?
      I am preparing to use Extrude by Rails with dimensional or scale control and was wondering about this.
      Thanks, mitcorb
      • X Offline
        xrok1
        it was freeform 😆 but i can't see any reason it couldn't be dimensioned accurately if you wish to.
        • majidM Offline
          majid
          WOW TIG !!!! this is great!! thank you...you are killing me slowly 😉 you ruby programmers are changing SU to a verrry different app. !!!thank you mate again
            @utiler said:
            TIG, probably a silly question, but what is the difference from this plugin and extrudebyedges?
            http://forums.sketchucation.com/viewtopic.php?f=180&t=20065&st=0&sk=t&sd=a&hilit=extrude+edges
            Is is simple that this script allows for more random meshes?
            ExtrudeEdgesByEdges takes two groups - edges in them need not be continuous - and makes a mesh - it extrudes each edge in one set in the direction of the edges in the other - there is no 'followme' etc...
            ExtrudeEdgesByRails is similar BUT it only works on curves. It takes a selected profile and makes a mesh from it along two selected rails [or with the forthcoming version one rail picked twice - making it similar in that usage to EEbyEdges]. The main difference is that at each pair of 'nodes' [vertices] in the two rails the profile is placed and rotated and then scaled to fit between the rails, giving a smoothly curving mesh surface: also the number of 'nodes' in each rail is equalized if the number of vertices in the two rails is uneven - now making the 'lofting' of two unequally segmented rails possible...
            • mitcorbM Offline
              mitcorb
              TIG:
              What are the possibilities of being able to orbit and inspect the initial results of the extrusion on rails while going through the checklist so that decisions can be made in the workflow? Does this make sense?
                @mitcorb said:
                TIG:
                It's something that's not so easy to do... but I'll look at it - I currently have a version with most of the bugs ironed out - it'll be published soonest...
                • mitcorbM Offline
                  mitcorb
                  Thanks, TIG:
                  You are a master.
                  I am currently experimenting and learning this excellent tool.
                    Cyberdactyl
                    Very nice Tig.
                    Works great in SU7. However, doesn't work SU6, at least for me.
                      Here is v1.1 http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                      It is now much more stable, with [most] glitches fixed with ordered points and bugsplats.
                      You can now also double-click on one rail and used it as both rails.
                      Rails that start / end at a common vertex are now allowed.
                      Mismatched segment numbers in the two rails are well accommodated - as are looped profiles and rails.
                      Debabelizer language translation are now added to menus and dialogs etc, with ExtrudeEdgesbyRailsEN-US.lingvo and ES/FR versions in the TIGtools folder.
                      Feedback please...
                      I've also updated the examples SKP here... http://forums.sketchucation.com/viewtopic.php?p=201457#p201457
                        Here's an example SKP - updated for v1.1... ExtrudeEdgesByRailsExamples.skp
                        • jeff hammondJ Offline
                          just out of curiosity, i drew the same shapes using the same dimensions in SU with EdgesByRails then i did another in Rhino using Sweep 2rails.. i then brought the SU surface/mesh into rhino and overlayed the two.. here's what it looks like.
                          (Sketchup = red... rhino =blue)
                          click pic for larger
                          the render mesh in rhino was set at a density of 100 making it about as close to the true nurbs surface that you can view on a computer.. all the vertices from SU edges by rails are right there where i'd hope they'd be.
                          so yeah, use this plugin with confidence 😄
                            ...and put Rhino in the garbage trash can 💚
                              [haha frenchy]
                              just in case that picture is confusing, here are the two surfaces separately..
                              (rhino- blue... SU- red)
                              click pic for bigger
                              (sorry about the nasty quality of the pictures.. had to use screenshots because the output options in Rhino OS X (beta) aren't fully implemented yet.. i don't think my screenshots like red too much)
                              ... and a render of the SU version after some joint_push_pull..
                              • X Offline
                                xrok1
                                nice. thanks for implementing the single rail option. i will delete edges by edges plugin soon but...
                                red is edges by rails result, blue is edges by edges result?? i think blue wins my vote on how things should work.
                                  as far as i can tell, both methods give the exact same results (3 tests and while one of the surfaces ended up in a strange location, it still matched the other)
                                  if you're talking about the triangulation then:
                                  with edgesBYedges, one of the options after running the script is 'triangulate faces?'
                                  with edgesBYrails, the second option that pops up is 'erase coplaner edges?'.. choose yes and the triangulation lines will go away (as long as they aren't necessary for the surfacing but since the geometry is the same with the two scripts for 1rail1edge, they'll end up identical if you choose yes to erase the coplanar edges)
                                  that said, maybe there's something i haven't tried that will make the two 1edge1rail methods produce different results..
                                    fwiw, coplanar means 'on the same plane'.. basically, draw a square then draw some lines on its surface or intersecting the edges.. those lines are coplanar and you can freely erase them without making the surface disappear.
                                    • X Offline
                                      xrok1
                                      thats what i'm refering to. EbE seems to be where i'd expect EbR seems to be on the wrong side of the rail. there probably is no right or wrong side it just isn't what i expected. maybe you could add a dialog for the one rail method that asks if you want to mirror result.
                                      PS, now that i asked for another dialog 😆 i feel i should say the dialog are annoying and i think a single window with checkboxes would be much nicer. 😉
                                        This is built with raw UI interface - no web-dialogs so no check-boxes - yet...
                                          kostas_designer
                                          Wow!
                                          Great improvement! I was missing the 1.1 version and i could'n figure out why it was acting like that!
                                          Now it rocks!
                                          Thanks again, Tig
                                            bocomofo
                                            I cant even imagine how this works...I can only presume that it is withcraft.
                                            Regardless of that I think it is totally amazing...now just to find a practical use for it in the rather 'boxy' Architecture I'm used to producing!!!
                                            Wonderful effort TIG!
                                            • 19
                                            • 20
                                            • 6 / 20
