    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 271.7k Views 135 Watching
      Align
      @thomthom said:
      A more recent Duh I had:
      Being able to select only a few edges from a face and offset them instead of the whole face.
      how do you do this?
        Select the edges and and activate offset...
        • EscapeArtistE Offline
          EscapeArtist
          @plot-paris said:
          wow, cool. didn't know about that eihter. but what I would even more like to see is a push/pull like this:
          [attachment=0:37plearv]<!-- ia0 -->strange_pushpull.jpg<!-- ia0 -->[/attachment:37plearv]
          It exists! Here: http://forums.sketchucation.com/viewtopic.php?f=180&t=23341
          • E Offline
            Ecuadorian
            I was working in a "mysterious" file that did not allow me to pushpull anything, and I was about to post the mysterious file here. After checking, "Snap to length" was set to a very high value. Duh!
            -Miguel Lescano
            • Chris FullmerC Offline
              I just found one for me tonight. I change the model axis pretty often when I work. But I never noticed that you can activate the axis tool (or change axis inside of a component tool) and click twice somewhere and it will move the axis to that point without changing its orientation. Normally I would have clicked once, then lined up the the axes and click and line up and click. So a double click (not too fast though!) is much faster for moving the axis.
                Select an element (lines, surface)
                Open Entity Info yes πŸ˜‰
                Then when you select with Shift , Shift + Ctrl or Ctrl
                all surfaces or length lines are added , subbstracted, modified, visible and updated in the Entity info! πŸ˜„ πŸ˜’
                  OK, this is a very painful duh:
                  My system seemed to crash and I could not even start windows in safe mode (Mac users, don't sneer, please) so I decided to at least try to repair my system. It didn't allow me as whatever imaginable I entered, it didn't accept it as the password of the system admin.
                  So I reinstalled (I have a recent backup of my documents at least). Then I realised that I didn1t even have a password and should have just hit Enter without entering any password.
                  So basically this is what I wasted my Sunday for. I have a deadline tomorrow. πŸ˜•
                  • plot-parisP Offline
                    plot-paris
                    oh, that is a really bad one, Gaieus! I am not sure if I should burst with laughter 🀣 , feel terribly sorry for you 😞 or just blush with embarassment, because that could just as well have happened to me 😳
                      plot-paris
                      another one. after importing a messy 3Ds model and cleaning it up with Thomthoms cleanup-script (thanks again, thom), I started entering every single one of the over 1500 groups/components, to smooth their surfaces.
                      then I just discovered, that you can apply the smoothing to groups/components, without entering them. so you can select all the groups at once and only have to do the proces once! (doesn't work with nested groups though)
                        I recently discovered that as well!
                        In regards to CleanUp - it does have a function to smooth the geometry it cleans up. If you use CleanUp Entire Model you have a field "Smooth Edges by Angle".
                          plot-paris
                          yet another 'Doh'
                          I can put my Homer button to quite some use today πŸ˜„
                            Well, eventually it turned out that the total HD was broken so no matter what I would've done, the repair/install wouldn't have been successful. Had to buy a new HD and reinstall everything again. 😒
                              plot-paris
                              uh, thats bad!
                              actually, I still try to deny that hard discs just die after several years of intenseive use. its not pleasant, when the truth catches up with you...
                              • broomstickB Offline
                                broomstick
                                I just discovered that the erase function hides and smoothes edges if you use it in combination with atl ctrl an shift...
                                DUH!!
                                • E Offline
                                  Ecuadorian
                                  Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. 😲
                                  -Miguel Lescano
                                    πŸ‘ Tricky and speedy 😎
                                      I just discovered that you can use more than one modifier key when setting up shortcut keys. example
                                      ctrl + shift + alt + Q
                                      or snything along those lines. I never reazlied that... 😳
                                        plot-paris
                                        just out of interest: what function did you assign to
                                        Ctrl + Shift + Alt + Q???
                                          When I press that, it triggers an automatic poking of you on Facebook.
                                          (I dare not try if there is anything assigned to it by default because I am rendering an animation) πŸ˜•
                                            It is my auto-assinate button in SU πŸ˜„
                                            I don't really have it assigned to anything. It was just an example of how complex a "shortcut" could be. I thought I was stuck to simple single modifiers. Double modifiers could greatly expand my shortcut range though!
                                            • 34
                                            • 35
                                            • 3 / 35
