    Rendering Workshop - Studio - still life
    72 Posts 17 Posters 26.5k Views 17 Watching
    • Al HartA
      Al Hart
      @dermotcoll said:
      Here is my first effort - I down loaded the studio set up but hadn't a clue what to do withit so this is a materials application only - any tips on this HDRi thingy and studio set up anyone i.e a step by step , blow by blow how to do it workflow - and please, for the love of God (allah etc, etc....) keep it in a language that an irishman can understand!!!!! 😕 😕 😕
      What rendering engine would you like help with?
      Al Hart
      IRender nXt from Render Plus
        Twilight Medium+ with no studio
        Twilight Medium+ with studio
        Thanks Al & Solo for the best Workshop yet
        • dermotcollD
          dermotcoll
          Hi Al
          These rendering discussions are going way over my head at the minute - where do I need to start - photography, lighting, I dont know!!!- I have bought Twilight and the trial version of podium. I also have purchased Piranesi but I dont think it is suitable for PR renderings.
          I would like someone to tell me of a good source of info in print or online where I can go and understand what is required to produce good images. You guys are amazing but to be honest I cringe when asking some of these questions and it puts me off participating in the forum quite a bit. Please give me some references to material where I can go off and get the basics of lighting, etc understood before I come back to bother you guys.
          When you burn your arse - you gotta sit on the blisters!!
          • soloS
            Dermot
            For the above mentioned exercises you firstly need to use a renderer that is capable of achieving these results.
            Twilight is capable of using image based lighting as well as shadow controls, unfortunately Podium does not have anyway of using image based lighting nor can you turn shadows off and on with omni's, which IMO disqualifies it for studio type renders.
            Do you have a copy of the Twilight manual? if you do go through it and see the sky probe and spherical sky explanations first, that will give you a guide as to how to apply HDRI's.
            • dermotcollD
              dermotcoll
              Cheers Solo
              As you can see from my earlier post I tried the still life using twilight with preset Medium +. I have watched the Twilight tutorials and have gone through the manual and I understand that you apply materials and that you adjust the properties of those materials to get different reflections, shine etc.
              What I do not get is the terminology and how things work. I downloaded the studio set up you kindly posted into the still life model and it took me 10 - 15 mins to finds the bloody plate because the studio was so big!!! Are you getting some idea of how far down the food chain I am here!! 😳 😳
              When HDRi comes into it - how do I put that into the mix - how do I place that into the model to give of light - do I apply it as a texture to a face that I create in the model?
              These are the really dumb ass questions I need to ask??
              • soloS
                I forgot about that, yeah the studio is large, purposely also, see how small the place setting is in my version.
                • Al HartA
                  Al Hart
                  @dermotcoll said:
                  Cheers Solo
                  Don't be put off. These are the questions the Workshop was designed for.
                  We want to let you see what others are doing. And we want to help you learn to do it yourself.
                  You might back up a bit, and start with Solo's first example.
                  1. Add the reflection properties needed to your model.
                    (Most renderers can grab colors, textures and transparency directly from SketchUp. But you need to add reflective properties yourself - since there are no reflective settings in SketchUp.
                  2. Then try solo's suggestions of shining 3 lights at the place setting.
                  http://forums.sketchucation.com/download/file.php?id=36556&t=1
                  Don't worry about much else yet. If you are just starting out, you want to see how various things work - not just try for the best rendering right away. You can achieve some very good studio effects with this model and three lights.
                  Al Hart
                  • GaieusG
                    Hi Dermot,
                    You just save your hdri (or any spherical or hemispherical) images into a convenient folder (not to "far" from your SU projects for easier browsing).
                    Now open the Twilight light editor (left of the material sampler button) and change the physical sky under the last tab (sun/sky) > and the top left pulldown menu is background / sky type. Now set the background image type and then below, browse to the folder you keep these images and select the one you want to use.
                    Edit - also notice that I disabled the sun so that only the image would light the scene. This can be both good or bad - depending on what you want.
                    • soloS
                      Attached is a .hdri for you to test, it's the same one I used for the Buddha on previous page.
                      Unzip and put in a place you will find (best make a folder for all your future .hdri's)
                      Then in the Twilight light editor set up like below.
                      1. select sky probe
                      2. navigate to the hdri
                      3. uncheck the sun and shadows
                      Now do a test render and from there you can play with the rotation, textures, etc.
                      edit... beaten by Csaba.
                      HDRI
                      • dermotcollD
                        dermotcoll
                        Thanks guys
                        Did that and I didnt see the hdri image anywhere in the model - should I have seen it and if so why didnt I?
                        I just did a quick render and there is something showing behind the studio set up - I take it I should have deleted the studio setup if Im using HDRi?
                        • soloS
                          The studio is there to block the HDR image and only allow the reflections and illumination of the HDRI, you should be able to see the reflections on any shiny surface now.
                          • dermotcollD
                            dermotcoll
                            Hi SOlo
                            If the studio is there to BLOCKthe HDRi image - how can reflections and iluminations from the HDRi actually effect / affect the model. I am cooking an image in Twilight on Medium now and when its is finished I will post it - if you could point out what you mean on it I would appreciate it. Slainte.
                            edit - what a d**khead - I deleted the studio on this one so I am seeing the HDRi image now all around the still life model. I will cook another when its finished and compare and contrast!!
                            • GaieusG
                              Ah yes, the studio is only needed to
                              1. have something "underneath" (otherwise you won't have shadosw cast anywhere) and
                              2. to have something that - by reflecting the light coming from anywhere - gives a nice, global illumination to the scene.
                              • GaieusG
                                That's not fair, Chris. If I had been told that I can have too apples, maybe I'de've joined, too!
                                • dermotcollD
                                  dermotcoll
                                  Just to make me feel better Chris!! 👊 - you go and get more apples and a drink - I hope thats vodka in that glass cos I'm ready for it right about now!!!!
                                  • K
                                    kwistenbiebel
                                    Thanks for the improved model Solo. 👍
                                    A 'render tip of the week' could be: no good renders without good models.
                                    Here's my entry:
                                    Skindigo:
                                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/still-life.jpg
                                    • dermotcollD
                                      dermotcoll
                                      Okay - here is the second one with the studio back in - let me have it!!
                                      Edit - just spotted the dark shadow to the bottom left of the placemat - there are not lights except for the HDRi image so I was wondering what was causing this?
                                      • GaieusG
                                        Why is that black stain in the lower left corner of the napkin?
                                        Otherwise, as you can see, when there is only the image background is giving light, there are no shadows at all. Yes, I suggested before to disable sunlight but maybe a little bit (just for some subtle shadows) is not bad. You can turn it down to 1-2 from the default 5. Like here (obviously I have polished the apple too much a bit but my mom told me to always carefully wash fruits before eating - also, the glass should not cast that crazy shadow)
                                          Hi Dermot,
                                          Have you set the place mat with a reflective surface?
                                          I feel your pain on the 'Learning to Render' front. It's breaking my liathroidi 😉
                                          • dermotcollD
                                            dermotcoll
                                            Cheers Gaieus
                                            I havent a clue what that dark patch is - I thought it might be something to do with the still life sitting on the sudio set up but the 1st image doesnt have the studio and yet it is still there.
                                            I am moving out of the dark already on this subject already thanks to you guys (pardon the pun) I must go away and practice with some simple modwls now just to see how they are affected by lights, positioning etc.
                                            Thanks again
                                            • 2 / 4
