    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 241.6k Views 108 Watching
    • FletchF
      Fletch
      awesome, Tomasz, you should have posted a link to it here. 😉
      Is it updated herenow? Or on KT's downloads page?
      Fletch
      • mariochaM
        mariocha
        @solo said:
        Without using layers, can this program do this?
        Hum.. something like that?
        http://www.youtube.com/watch?v=7nuAAXbRz2o
        BTW : a good example of why it would be great to be able to set the delay between scenes to zéro.
        Updt: Using the Smooth Animation plugin solved it. 👍
        %(#008000)[Mario C.
        • T
          tomasz
          The most up to date version is on my website and in the KT Forum. The one in downloads section is slightly older 😄
          Tomasz
            morisdov
            Since this plugin still has a significant demand i have added an interface to easyly clear position settings.
            version 1.05 beta of Proper Animation can be downloaded on the following link
            http://morisdov.googlepages.com/proper_animation.1.05.beta.zip
            Its beta so if you find problems reply with screenshots
            • E
              Ecuadorian
              Thank you, Morisdov! 😄
              -Miguel Lescano
                Cool new version, must be tested 😄
                  morisdov
                  more features for version 1.05 beta of Proper Animation
                  • E
                    Ecuadorian
                    Wow, thank you, Morisdov, nice to see you back. 😄
                    -Miguel Lescano
                    • mariochaM
                      mariocha
                      Good news Guys ! Another plugin also renders Proper Animations. LightUp 1.7. 😄
                      [attachment=0:3dnyqt2f]<!-- ia0 -->Bowtoyou.mov<!-- ia0 -->[/attachment:3dnyqt2f]
                      Impressive Morisdov !
                      Bowtoyou.mov
                      %(#008000)[Mario C.
                      • MALAISEM
                        MALAISE
                        Good improvements, Morisdov 😄
                        Also nice to see you back on the Forum
                        Question : how to display the window "boxes attributes"??
                        MALAISE
                        • mariochaM
                          mariocha
                          To display; Menu Plugins
                          dernier item au bas. 😛
                          %(#008000)[Mario C.
                            din_wiesel
                            Hello
                            Proper Animation is such a cool and easy PluIn to animate things in Sketchup.
                            But I got a problem with my objects.
                            I have a package with numbers of wood piece. In the first position it should lie on the ground.
                            In the second position is a 90 degree rotation of the first position.
                            But the objects get their own life, you will see it in the video.
                            The objects in this animation are Components and Groups
                            See the video
                            Has anyone a solution for this problem.
                            • mariochaM
                              mariocha
                              I has a similar problem. It was due to not having put the axes of the components at the right spot. Groups are also hard to control, I find, cause they do not have axes that can be set at a specific spot at will. So I make every object to be animated a component and set the axes to the pivot point of the desired rotation.
                              %(#008000)[Mario C.
                              • K
                                KXI System
                                Thank you, I have found a great deal of uses for this plugin, and glitches... 😆
                                Actually, Sometimes the things I animate when I play then, they disappear! Is this a glitch?
                                Getting the perfect sig is hard...
                                Google it!
                                • mariochaM
                                  mariocha
                                  Well, this happens when I forget to close group/component before play or switchin
                                  Well, this happens when I forget to close group/component before play or switching scene.
                                  %(#008000)[Mario C.
                                  • K
                                    KXI System
                                    But all my groups are closed, but the easy way for me to fix this is to turn on shadows. But then when I play it the shadows don't move along!
                                    Help! Help! And Help! 😮 😮 😮 😮 😮 👊
                                    Google it!
                                    • mariochaM
                                      mariocha
                                      Is it the shadow thing I talk about in my post on page 7 ?
                                      %(#008000)[Mario C.
                                      • K
                                        KarinaGM
                                        Mariocha
                                        how do you set the axes to the desired position?
                                        **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                                        -Benjamín Franklin.**
                                        • K
                                          KXI System
                                          Found a strange glitch when I was trying to animate labica model, here you see:
                                          Glitch.skp
                                          Google it!
                                          • K
                                            KXI System
                                            Hey-hey, an update!
                                            Google it!
