    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 206.1k Views 108 Watching
      tomot
      I appreciate all the hard work that's being done and has been done since SU4. but to date we still cant even come close to doing this. http://www.youtube.com/watch?v=RB91Sm-kGJ8 I wonder how much longer it will be for Google to include proper Component Animation Techniques in SU?
      [my plugins](http://thingsvirtual.blogspot.ca/)
      tomot
        tomasz
        @tekelwriter said:
        I am preparing a compilation of few proposed by users modifications to the SU2KT. It includes option to export 'proper_animation' for rendering in the Kerkythea.
        I look forward to it. 😄
        Done.
        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        • FletchF Offline
          Fletch
          awesome, Tomasz, you should have posted a link to it here. 😉
          Is it updated herenow? Or on KT's downloads page?
          Fletch
          • mariochaM Offline
            mariocha
            @solo said:
            Without using layers, can this program do this?
            Hum.. something like that?
            http://www.youtube.com/watch?v=7nuAAXbRz2o
            BTW : a good example of why it would be great to be able to set the delay between scenes to zéro.
            Updt: Using the Smooth Animation plugin solved it. 👍
            %(#008000)[Mario C.
              tomasz
              The most up to date version is on my website and in the KT Forum. The one in downloads section is slightly older 😄
              Tomasz
                morisdov
                Since this plugin still has a significant demand i have added an interface to easyly clear position settings.
                version 1.05 beta of Proper Animation can be downloaded on the following link
                http://morisdov.googlepages.com/proper_animation.1.05.beta.zip
                Its beta so if you find problems reply with screenshots
                • E Offline
                  Ecuadorian
                  Thank you, Morisdov! 😄
                  -Miguel Lescano
                    Cool new version, must be tested 😄
                      morisdov
                      more features for version 1.05 beta of Proper Animation
                      • E Offline
                        Ecuadorian
                        Wow, thank you, Morisdov, nice to see you back. 😄
                        -Miguel Lescano
                        • mariochaM Offline
                          mariocha
                          Good news Guys ! Another plugin also renders Proper Animations. LightUp 1.7. 😄
                          [attachment=0:3dnyqt2f]<!-- ia0 -->Bowtoyou.mov<!-- ia0 -->[/attachment:3dnyqt2f]
                          Impressive Morisdov !
                          Bowtoyou.mov
                          %(#008000)[Mario C.
                          • MALAISEM Offline
                            MALAISE
                            Good improvements, Morisdov 😄
                            Also nice to see you back on the Forum
                            Question : how to display the window "boxes attributes"??
                            MALAISE
                            • mariochaM Offline
                              mariocha
                              To display; Menu Plugins
                              dernier item au bas. 😛
                              %(#008000)[Mario C.
                                din_wiesel
                                Hello
                                Proper Animation is such a cool and easy PluIn to animate things in Sketchup.
                                But I got a problem with my objects.
                                I have a package with numbers of wood piece. In the first position it should lie on the ground.
                                In the second position is a 90 degree rotation of the first position.
                                But the objects get their own life, you will see it in the video.
                                The objects in this animation are Components and Groups
                                See the video
                                Has anyone a solution for this problem.
                                • mariochaM Offline
                                  mariocha
                                  I has a similar problem. It was due to not having put the axes of the components at the right spot. Groups are also hard to control, I find, cause they do not have axes that can be set at a specific spot at will. So I make every object to be animated a component and set the axes to the pivot point of the desired rotation.
                                  %(#008000)[Mario C.
                                    KXI System
                                    Thank you, I have found a great deal of uses for this plugin, and glitches... 😆
                                    Actually, Sometimes the things I animate when I play then, they disappear! Is this a glitch?
                                    Getting the perfect sig is hard...
                                    Google it!
                                    • mariochaM Offline
                                      mariocha
                                      Well, this happens when I forget to close group/component before play or switchin
                                      Well, this happens when I forget to close group/component before play or switching scene.
                                      %(#008000)[Mario C.
                                        KXI System
                                        But all my groups are closed, but the easy way for me to fix this is to turn on shadows. But then when I play it the shadows don't move along!
                                        Help! Help! And Help! 😮 😮 😮 😮 😮 👊
                                        Google it!
                                        • mariochaM Offline
                                          mariocha
                                          Is it the shadow thing I talk about in my post on page 7 ?
                                          %(#008000)[Mario C.
                                            KarinaGM
                                            Mariocha
                                            how do you set the axes to the desired position?
                                            **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                                            -Benjamín Franklin.**
                                            • 12
                                            • 13
                                            • 6 / 13
