    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 206.1k Views 108 Watching
    • majidM Offline
      majid
      woww ..it is really great development Fletch ,thanx again
      • FletchF Offline
        Fletch
        Another SketchyPhysics animation, of a TANK driving over a bumpy surface, but turned out great...
        http://twilightrender.com/phpBB3/viewtopic.php?p=2363#p2363
        again, it will render Proper Animation as well... if I find time, I will do an example... but am swamped at the moment. 😕
        Fletch
          bulbucila
          Thank you!, amazing plugin. Can it export the animations into an avi file?
          • E Offline
            Ecuadorian
            Render plug-ins usually don't export a video file, but a JPG sequence. I use VideoMach to convert that sequence to video, but Fletch posted a tip on how to do the same thing using only freeware:
            http://twilightrender.com/phpBB3/viewtopic.php?f=12&t=455
            -Miguel Lescano
              markozeta
              @dave r said:
              I saw a post in the SketchUp forum about making a paper airplane animation. I was curious and thought I'd play with it. In the attached model, I've got two components. The triangular one is supposed to fold up. As it does, though, it moves away from the other component. When I rotated it, I rotated along the edge common to both. Is there a way to make the component "hinge" on the edge?
              [attachment=1:wt057bzy]<!-- ia1 -->Folding Paper.skp<!-- ia1 -->[/attachment:wt057bzy]
              This seems to be an issue with the transformation.interpolate - interpolate only works by interpolating the movements, but rotations of multiple axis are not linear functions - and therefore cannot be interpolated.
              Instead, to obtain the full information about the object, information about a second point must be known.
              Imagine rotating a ball counterclockwise 90 degrees about the x axis and then 90 degrees CCW about the y axis, v. rotating a ball 90 degrees CCW about the y axis and then 90 degrees CCW about the x axis. It's not the same! The point (0,1,0) would be moved to (1,0,0) in the first instance, and it would be at (0,0,1) in the second instance!
              With a little bit of effort, I think I can fix this (yay for paying attention in my dynamics course!) assuming the author does not mind? It would just take a bit of direct manipulation on the transformation matrix. (and a better understanding from myself of Ruby, it seems I can read ruby but can never write it).
              BSME - Cal Poly Pomona
              Sketchup Pipe Maniac
                Jim
                In addition to proper animation, there is another animation plugin called mover here:
                http://forums.sketchucation.com/viewtopic.php?f=180&t=17459
                Both plugins handle position and rotation of Groups/Instances just fine. But they start to act funny when using Instances.
                I would like to be able to use either plugin to animate 2 Instances; one of which has been scaled -1.
                  tomot
                  I appreciate all the hard work that's being done and has been done since SU4. but to date we still cant even come close to doing this. http://www.youtube.com/watch?v=RB91Sm-kGJ8 I wonder how much longer it will be for Google to include proper Component Animation Techniques in SU?
                  [my plugins](http://thingsvirtual.blogspot.ca/)
                  tomot
                    tomasz
                    @tekelwriter said:
                    I am preparing a compilation of few proposed by users modifications to the SU2KT. It includes option to export 'proper_animation' for rendering in the Kerkythea.
                    I look forward to it. 😄
                    Done.
                    Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                    • FletchF Offline
                      Fletch
                      awesome, Tomasz, you should have posted a link to it here. 😉
                      Is it updated herenow? Or on KT's downloads page?
                      Fletch
                      • mariochaM Offline
                        mariocha
                        @solo said:
                        Without using layers, can this program do this?
                        Hum.. something like that?
                        http://www.youtube.com/watch?v=7nuAAXbRz2o
                        BTW : a good example of why it would be great to be able to set the delay between scenes to zéro.
                        Updt: Using the Smooth Animation plugin solved it. 👍
                        %(#008000)[Mario C.
                          tomasz
                          The most up to date version is on my website and in the KT Forum. The one in downloads section is slightly older 😄
                          Tomasz
                            morisdov
                            Since this plugin still has a significant demand i have added an interface to easyly clear position settings.
                            version 1.05 beta of Proper Animation can be downloaded on the following link
                            http://morisdov.googlepages.com/proper_animation.1.05.beta.zip
                            Its beta so if you find problems reply with screenshots
                            • E Offline
                              Ecuadorian
                              Thank you, Morisdov! 😄
                              -Miguel Lescano
                                Cool new version, must be tested 😄
                                  morisdov
                                  more features for version 1.05 beta of Proper Animation
                                  • E Offline
                                    Ecuadorian
                                    Wow, thank you, Morisdov, nice to see you back. 😄
                                    -Miguel Lescano
                                    • mariochaM Offline
                                      mariocha
                                      Good news Guys ! Another plugin also renders Proper Animations. LightUp 1.7. 😄
                                      [attachment=0:3dnyqt2f]<!-- ia0 -->Bowtoyou.mov<!-- ia0 -->[/attachment:3dnyqt2f]
                                      Impressive Morisdov !
                                      Bowtoyou.mov
                                      %(#008000)[Mario C.
                                      • MALAISEM Offline
                                        MALAISE
                                        Good improvements, Morisdov 😄
                                        Also nice to see you back on the Forum
                                        Question : how to display the window "boxes attributes"??
                                        MALAISE
                                        • mariochaM Offline
                                          mariocha
                                          To display; Menu Plugins
                                          dernier item au bas. 😛
                                          %(#008000)[Mario C.
                                            din_wiesel
                                            Hello
                                            Proper Animation is such a cool and easy PluIn to animate things in Sketchup.
                                            But I got a problem with my objects.
                                            I have a package with numbers of wood piece. In the first position it should lie on the ground.
                                            In the second position is a 90 degree rotation of the first position.
                                            But the objects get their own life, you will see it in the video.
                                            The objects in this animation are Components and Groups
                                            See the video
                                            Has anyone a solution for this problem.
                                            • 12
                                            • 13
                                            • 6 / 13
