    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 315.0k Views 135 Watching
    • broomstickB Offline
      broomstick
      my duh moment:
      when you rotate something, and you touch the rotation tool that appears on screen, the rotation will snap on the simbols of the rotation tool.
      If you change the rotation snaps, the rotation tool changes consequently.
      very, very duh
        Gruff
        More of an Ahh! than a Duh!
        1. Discovered that ALT-Push/Pull will move a loose planar face in the face normal
        I find I need to create duplicate parallel faces offset from the body a lot.
        1. To do this I use CTRL-Push/Pull to make a copy extrude.
          Rotate the model view 90 degrees to the face normal
          then use a right to left select window to select the extruded side faces,
          then press the Delete key.
        I'm left with a face normal to and inline with the original at a distance.
        Resistance is .... Character Forming. Grin
        • E Offline
          Ecuadorian
          Thank you! I had been foolishly using the "move" tool for that. 👍
          -Miguel Lescano
          • plot-parisP Offline
            plot-paris
            wow, cool. didn't know about that eihter. but what I would even more like to see is a push/pull like this:
            • E Offline
              Ecuadorian
              +1. That would be my #1 wish for SU8.
              -Miguel Lescano
                Not really and exactly the same and a push pull but the Plug Protrude make this at each click 😉
                Of course you can change Height and Taper at any moment 😄
                • halroachH Offline
                  halroach
                  @solo said:
                  Now that you mention that, I have an embarrasing one for you, my kid who was 11 at the time of me teaching him the ins and outs of SU when one day I was teaching him how to map textures to a sphere and I asked him to get an image of the earth to map from our server texture folder, he opened up the folder on the second monitor and dragged it onto the sphere, I exclaimed 'What on earth are you doing" and before I could complete my setence with the all to fimiliar 'you dumbass' the texture was mapped onto the sphere, sure it was not UV mapped correctly but I had not known that was possible. Being a wise-ass he replied "like every karate movie, the studend with enough practice becomes the master"
                  I had to create another cartoon character that day to show him who's boss.
                  Huh?
                  When I drag images into a model, they come in as pictures, which I can place and explode if I want them to be used as textures. Do they automatically come in as textures for you?!?!?
                  FlexTools - Super Quick Windows, Doors, Slats...
                    Gruff
                    [attachment=0:2sngi41l]<!-- ia0 -->strange_pushpull.jpg<!-- ia0 -->[/attachment:2sngi41l]
                    Similar to that I'd like to see some way of locking the move tool do the same thing to an edge of a face. Allow the face to only stretch normal to the side of the line. Say you had a square face 6"x8"
                    Grab on one of the 8" lines and pull out making it 12" x 8".
                    Basically I need the face to larger than the original facet.
                      plot-paris
                      another one, only outside SketchUp...
                      did you ever try to explode a folder somewhere to copy it's content to the next higher folder?
                      I have a shortcut applied to exploding in SkechUp. and I hit it repeatedly, wondering, why the folder was still there.
                      actually, that would be a great thing to implement in an operating system: selecting a folder and exploding it, being left with the files within all selected. or the other way around, grouping things (select several files and hit the 'group shortcut' to put them into a new folder...
                        kwistenbiebel
                        Yeah 😄
                        SketchupOS 1.0 !
                          MartinRinehart
                          @arail1 said:
                          My Spacebar doesn't deselect - disappointed.
                          There are glitches, here. On a PC for example, Move tool selected, press spacebar. You are still looking at a Move cursor, but the least mouse movement corrects the cursor.
                            Gruff
                            One more Duh!
                            When viewing a model in XRay mode.
                            If you hold down shift whilst using the 2D drawing tools the new 2D geometry is forced onto the nearest face (closest to your eye.). Even snap points to (Behind) geometry is projected to the nearest face.
                            The sort of meets my needs for construction planes that I am comfortable using in other solid modelers.
                            The only painful part of it is that you have to continuously hold down the shift key. It would be nice if Caps lock toggled the feature.
                              plot-paris
                              true, some sort of permanently locking a movement direction would be awesome at times (appart from locking it to the three main axes via the arrow keys)...
                                GoldenFrog
                                My DUH moment was when i realised there was an arc tool. Needles to say, that was my first day using SU. Hehe...My other one was when i learned about the follow me tool. Great DUH there! But, I've greatly improved since then ☀
                                Remember, great minds think alike, and fools never differ.
                                • X Offline
                                  xrok1
                                  Wish granted! 🤣
                                  my duh moment just happened, i forgot to attached the jpg to this post the first time. 🤣
                                    Gruff
                                    <!-- ia0 -->Capture.JPG<!-- ia0 -->[/attachment:1ouv5aid]
                                    I do not see that dialog anywhere in my 7.1 std SketchUp.
                                    Is that a Pro feature?
                                    • E Offline
                                      Ecuadorian
                                      You set up that in Windows, not in SketchUp, in "Accesibility" options in the Control Panel of XP. But I'm not sure about its usefulness in SU.
                                      -Miguel Lescano
                                        Wanted to now all plugs by Tig ☀
                                        Just today thinking to use the search Advanced engine 😳
                                        [PLUGIN] + TIG + Title ONLY + Ruby Discussion 👍
                                        = 3 pages of true gem ! Something like 75 brains storming 😮 😉
                                        Of course you can make that for any other Ruby Gurus: TBD, Fredo6, Chris Fullmer, Didier Bur, Jim Foltz, Thomthom, Matt666, Whaat, Wikii, Gohch, CPhillips, Kyrill2008, Morisdov, AdamB, Todd Burch, Rick Wilson... sorry for the forgotten 😳
                                        I must find an another tricky method for find all Gurus 😉
                                        (and will be added at the list as soon as) ❗
                                        • X Offline
                                          xrok1
                                          you can lock the shift key for inferencing, which is what Gruff wished for 😛
                                          • jeff hammondJ Offline
                                            good one!
                                            i didn't know that
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 34 / 35
