🔌 Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
[Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
638 Posts 203 Posters 1.6m Views 202 Watching
  • E Offline
    EarthMover
    I've had a chance to really play with the refreshed version....WOW!! You have really thought of everything! I find myself using these drawing tools for so much more than just on a curved surface. They are great to use on coplanar surfaces as well!
    Between Joint Push Pull, Round Edges, Tools on Surface and Bezier Tools, you've single handedly propelled SU into a league of it's own. You make other apps feel down right tedious. THANK YOU AGAIN!!
    Content Creator at Skapeup
    • F Offline
      I just installed the update and I don't even have the option to choose an icon set in the Default Parameters. I am on a PC with XP.
      The options for alternate icons (and icons shown in the toolbar) are in the Default Parameter of ToolsOnSurface, not of LibFredo6.
      Also, do not forget to install LibFredo6 3.4
        boofredlay
        And I think this is the second time I asked you about this, sorry 😳
        It is working fine.
        I did have LibFredo 3.4 installed when I removed the older directories. I restarted SU and the toolbar went away. However, somehow (assuredly due to operator error) when I remove it now and restart SU everything is fine.
        Sorry for the bother and thanks again for the plugin.
          Daniel S
          Fredo... Is not working the explicit selection for the offset on surface? (Select first Edges and Faces in the model, then start the tool).
          Most of the things are possible with the implicit selection but now that I want to offset some edges it becomes impossible.
          Daniel S
          • F Offline
            Daniel,
            Thanks for signaling this bug (which was introduced with 1.5a).
            I made a fix and updated the main post with version 1.5d. It also includes the Spanish translation by Gaonirico.
              Daniel S
              Great!!! Thank you for the updated version!!!
              Daniel S
              • F Offline
                New maintenance release 1.5e.
                I fixed bugs in 1.5d on the generation of Circles and Polygons when no face.
                I also restablish the post-edition functionality which mysteriously disappeared in v1.5 (or maybe in earlier versions).
                see main post for the new zip file
                http://forums.sketchucation.com/viewtopic.php?f=180&t=11212#p76625
                  Daniel S
                  Today I saw something strange...
                  try to make a triangle with initial point in the construction point...
                  polygononsurf.skp
                  Daniel S
                  • F Offline
                    Daniel,
                    You are an incredible tester. There was 1 chance out 10 million that this situation occurs!! I mean a triangle with 8 sides!
                    I published a fix in version 1.5f
                    See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=11212&p=76625#p76625
                      arklandesign
                      With all the great reviews of this ruby script I couldn't wait to try this one out... tried and tried to download this into my plugins and sadly all I'm get is an error saying..
                      Error Loading File ZLoader__OnSurface.rb
                      No such file to load -- LibFredo6.rb
                      Ive tried to wade through this thread but am confused .....The version I tried was 1.5c and then i tried 1.5e.... still not working
                      Can anyone point me in the right direction... what is the secret to getting this to work...???
                        remus
                        Have you installed libfred06? http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                        ToS needs it to work, i think.
                          arklandesign
                          Thank you Remus for the prompt reply...
                          So, just to make sure i need to install the following
                          b]LibFredo6_ES.zip[/b]
                          (3.33 KB) Downloaded 116 times
                          Right ???
                          Ill try that.... Fingers crossed :O)
                          whoooh.... there is more to this than meets the eye.... Ok, i'll try to do this... but don't be surprised if I return with some questions...
                          Thanks again Remus :O)
                            remus
                            Yep, that should do it, and I think the extra complication is worth it for fredo's plugins.
                            • W Offline
                              watkins
                              Dear Fredo6,
                              I note that when using your Tools on Surface plugin one has a toolbar which is permanently displayed and then an 'on screen' toolbar that appears when one selects a tool from the permanently displayed toolbar. Is this how it is supposed to work? If so, would it not be better to have a single permanently visible icon, perhaps labelled TOS, which when clicked brought up the 'on screen' toolbar?
                              Kind regards,
                              Bob
                              • F Offline
                                @watkins said:
                                Dear Fredo6,
                                Bob,
                                In TOS 1.5, I introduced a Generic Icon (the first one in the toolbar) that keep memory of last TOS tool launched.
                                If you go to the Default Setting dialog box of ToolsOnSurface, you can hide all other icons and keep this one.
                                PS: you may want to keep one or two other icons for the functions you need frequently.
                                • W Offline
                                  watkins
                                  Dear Fredo6,
                                  Many thanks for the explanation, and a most excellent plugin.
                                  Thank you again for your generosity.
                                  Kind regards,
                                  Bob
                                  • F Offline
                                    Documentation in Frenchnow available, thanks to Jean-Francoand Christophe Plassais.
                                    See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=11212#p76625
                                    • plot-parisP Offline
                                      plot-paris
                                      hi Fredo,
                                      in the last couple of releases Daniel S' fancy icons are not implemented anymore. but only the old ones... do you know why that is?
                                      [Edit] ops.. never mind, just found them in the installation folder 😳
                                      thanks again for the great plugin []
                                        kilgo
                                        Is it possible to use this tool to put text on a surface. Flat text that follows the curvature of a sphere or rolling hills in all directions?
                                          I think not BUT my 2D Tools - 2D Text will place 2D Text onto any face with the appropriate snapping option - it's not limited to '2D'... You could always place the text on to a high spot on the terrain and use the Sandbox Drape Tool to make the outline of it onto the terrain's surface ? Color it to suit...
                                          • 11
                                          • 12
                                          • 13
                                          • 14
                                          • 31
                                          • 32
                                          • 12 / 32
