    [Plugin] Simple Catenary Curve
    34 Posts 14 Posters 43.4k Views 14 Watching
      remus
      Doubled checked on wikipedia and it seems it is a parabola. Part of the conic sections if you fancy investigating further.
        kwistenbiebel
        Hi remus, that's a wonderful idea.(Didn't know the term Catenary though).
        By the way, could multiple Catenary curves define a tensile structure?
          remus
          You probably could, but i dont think it would be physically accurate. Catenary curves only describe lines with no forces (other than gravity) acting along their length.
          I know that in simple cases like a suspension bridge the curve is a parabola, but i dont know if this would still be true for more complicated tensile structures.
            I believe you, Remus, truely. 😉
              remus
              I just though other people might be interested (although i realise maths geeks are probably in short supply around here 😛 )
                I'm no math geek - but that cursed curve had me stumped when I wanted to make a chain/rope plugins.
                I've still not looked at the code, but can it be used to specify two 3D points and the total length of the curve?
                  remus
                  2 3d points is fairly easy as long as the 2 points are level, if not you have to start messing around with numerical solutions and it all gets rather messy.
                  Its similarly difficult to specify a length if i remember correctly.
                    Yea, that's what I tried. Different heights.
                    And also specifying length. Only solution to the length I could find was a method that did loop of approximation until it came within a given tolerance...
                    • fredo6F Offline
                      Remus,
                      I am glad you show the way to Users to get their ownautomation via Ruby. Obviously, Sketchup needs to be complemneted by some generic Rubies that does geometrical operations that SU does not do in native.
                      But Ruby is also a very convenient way for individual users to speed up their workflow with some adhoc, simple programming. It's a little bit like Excel macros. They are meant for users to help with a few lines of code. But of course, some specialists could also write complete applications with thousands of lines of VB Scripts for Excel and share them to a community of users.
                      Your program is 10 lines of code and does the work of creating a catenary curve. For the purpose of what it does for an individual user, it is very concise and elegantly written. Ruby is not very complex for simple things and you demonstrate it in your script.
                      Now, yes, for writing a general plugin drawing any catenary curve in 3D between 2 points, with options, live feeback and postedition, the script would have to go one level beyond, and may not be an easy task for an occasional programmer (but do not worry, there is also a strong community of script writers!).
                      So, I can only send you my support for showing what Ruby can do with a few lines of code, to automate repetitive tasks or make simple calculations.
                        tomot
                        count me in the math geek column!
                        great little program, Ive been using it to learn more about Ruby.
                        =begin
                        Simple Catenary Curve script
                        Author; Remus Knowles
                        =end
                        module RTK
                        def self.simple_cat_curve
                        ents = Sketchup.active_model.active_entities
                        pts = []
                        # add or delete interval to be evaluated
                        intervals = [-3,-2.75,-2.5,-2.25,-2,-1.75,-1.5,-1.25,-1,-0.75,-0.5,-0.25,0,0.25,0.5,0.75,1,1.25,1.5,1.75,2,2.25,2.5,2.75,3]
                        intervals.each{|e|
                        # main math formula, try x = (Math.sinh(e)), or (Math.sin(e))
                        x = (Math.cosh(e))
                        # pts.push([e,20,x]) entering 20 moves the curve  along green axis  20 units
                        # pts.push([e,x,0])  draws the curve in plan view
                        # pts.push([x,0,e,]) draws the curve in elevation view
                        pts.push([x,10,e])
                        pts.push([x,0,e,])
                        pts.push([x,-10,e])
                        cat_curve = ents.add_curve(pts)
                        cat_curve_grp = ents.add_group(cat_curve)
                        end#method
                        end#module
                        UI.menu("Draw").add_item("Simple Catenary Curve") {RTK.simple_cat_curve}
                        my attached code documents some of the things I have tried
                        my plugins
                        tomot
                          remus
                          Fred, thanks, it means a lot coming from someone of your experience.
                          Tomot, good effort on the mods, best way to start learning ruby in my opinion.
                            CADAddict
                            Hey REmus,
                            no need to be a Math Geek to find a use to it.
                            Anytime someone needs to model lets say the electric highvoltage cables supported by high voltage towers, this comes to a use.
                            Also for a more architecture realted topic, most of the Vaults designed by Antoni Gaudí's(the catalan architect author of the Sagrada familia in Barcelona)were actually inverted catenary curves, so anyone trying to model his buildings igh also find a use to it!
                            Thanks a lot!
                            http://www.cad-addict.com/
                            • mitcorbM Offline
                              mitcorb
                              Hey, CADAddict:
                              Glad you mentioned Antonio Gaudi's Familia Sagrada, because that is the first thing I thought of when someone questioned the usefulness of catenary curves, besides suspended cables in equilibrium.
                              mitcorb
                              • simon le bonS Offline
                                simon le bon
                                Remus's Catenary suspension bridge
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray018th.jpg
                                taken in: Copy Array Along Path tool...have a look.
                                (Catenary Curve for the general shape of the bridge. The ropes are handmade using Bezier Spline with only one intermediate point driven in order to simulate the weight of the rope.
                                A remark to Remus: Your Catenary Curve is made with only 16 segments. It's probably too few in many cases. It would be better to add the choice of this number( 😉 )
                                @jclements said:
                                Hey Remus:
                                Next step is "chain maker" or "rope maker"..😄
                                The first tool exists right now with courtesy of Chris Fullmer :[Plugin] Component Stringer
                                😉 simon
                                  I think Remus is talking about a tool to simulate rope or chains - which is not what Chris' tool is doing.
                                    remus
                                    I'll have a look at it 👍
                                      simon le bon
                                      Hi thomthom,
                                      You are rigth! I had probably been taken by the hurry of enjoyment. Chris's "Component Stringer" is a very cool tool, but intending to do a different job.
                                      We can make a chain with it but it very uneasy and far from perfection!
                                      @tig said:
                                      Make half chain link (U) and use this tool then edit that chain and copy/hand the U geometry into an O loop of say 2.2 the original length, now you have your links; us 'make unique' on one of the links, edit it and rotate its contents 90 degrees. Select every other link and replace with this rotated one... a chain... done.
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer005th.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer006th.jpg
                                      In such case, it will be better to do this way:
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_CopyArray013th.jpg
                                      And for making a rope, I'm sure we can do a good job with our same Chris Fullmer's Shape Bender.
                                      *simon
                                        remus
                                        Try this, it's untested so give us a shout if it's broken.
                                        simple_cat_curve.rb
                                          simon le bon
                                          Hi Remus, 😉
                                          Something is wrong for me. "Simple Catenary Curve" opens and asks the number of segments (cool), but after validation, nothing happens..
                                          *s
                                            remus
                                            Sorry, it was a silly bug as i was distracted while writing it last night. Hopefully this version should work.
                                            simple_cat_curve.rb
