    [Plugin] Simple Catenary Curve
    34 Posts 14 Posters 43.8k Views 14 Watching
      remus
      Fred, thanks, it means a lot coming from someone of your experience.
      Tomot, good effort on the mods, best way to start learning ruby in my opinion.
        CADAddict
        Hey REmus,
        no need to be a Math Geek to find a use to it.
        Anytime someone needs to model lets say the electric highvoltage cables supported by high voltage towers, this comes to a use.
        Also for a more architecture realted topic, most of the Vaults designed by Antoni Gaudí's(the catalan architect author of the Sagrada familia in Barcelona)were actually inverted catenary curves, so anyone trying to model his buildings igh also find a use to it!
        Thanks a lot!
        http://www.cad-addict.com/
        • mitcorbM Offline
          mitcorb
          Hey, CADAddict:
          Glad you mentioned Antonio Gaudi's Familia Sagrada, because that is the first thing I thought of when someone questioned the usefulness of catenary curves, besides suspended cables in equilibrium.
          mitcorb
          • simon le bonS Offline
            simon le bon
            Remus's Catenary suspension bridge
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray018th.jpg
            taken in: Copy Array Along Path tool...have a look.
            (Catenary Curve for the general shape of the bridge. The ropes are handmade using Bezier Spline with only one intermediate point driven in order to simulate the weight of the rope.
            A remark to Remus: Your Catenary Curve is made with only 16 segments. It's probably too few in many cases. It would be better to add the choice of this number( 😉 )
            @jclements said:
            Hey Remus:
            Next step is "chain maker" or "rope maker"..😄
            The first tool exists right now with courtesy of Chris Fullmer :[Plugin] Component Stringer
            😉 simon
              I think Remus is talking about a tool to simulate rope or chains - which is not what Chris' tool is doing.
                remus
                I'll have a look at it 👍
                  simon le bon
                  Hi thomthom,
                  You are rigth! I had probably been taken by the hurry of enjoyment. Chris's "Component Stringer" is a very cool tool, but intending to do a different job.
                  We can make a chain with it but it very uneasy and far from perfection!
                  @tig said:
                  Make half chain link (U) and use this tool then edit that chain and copy/hand the U geometry into an O loop of say 2.2 the original length, now you have your links; us 'make unique' on one of the links, edit it and rotate its contents 90 degrees. Select every other link and replace with this rotated one... a chain... done.
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer005th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer006th.jpg
                  In such case, it will be better to do this way:
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_CopyArray013th.jpg
                  And for making a rope, I'm sure we can do a good job with our same Chris Fullmer's Shape Bender.
                  *simon
                    remus
                    Try this, it's untested so give us a shout if it's broken.
                    simple_cat_curve.rb
                      simon le bon
                      Hi Remus, 😉
                      Something is wrong for me. "Simple Catenary Curve" opens and asks the number of segments (cool), but after validation, nothing happens..
                      *s
                        remus
                        Sorry, it was a silly bug as i was distracted while writing it last night. Hopefully this version should work.
                        simple_cat_curve.rb
                          simon le bon
                          Sorry Remus,
                          Something is still wrong!
                          The Catenary curve is drawn so small that I can't zoom on it.
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CatenaryCurve001.jpg
                          I have reloaded your first one to experiment FredoScale Strech tool to figure out something like my suspension bridge's ropes.
                          seems not bad. I have no mathematic element to say if that remains a Catenary Curve.
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CatenaryCurve002th.jpg
                          *simon
                            remus
                            No worries, i'll have a look at it this evening and see if i can get it back in working order again.
                            • atelierpaarA Offline
                              atelierpaar
                              Hi REmus,
                              I just tryed your Tool "Simple Catenary Curve"
                              After the Dialog-box it seems that no Element was drawn.
                              where is the curve? 😮
                              Uli
                                d12dozr
                                Uli, its always drawn at the origin...you may need to zoom in close.
                                http://goo.gl/f7ooYh
                                • McGyverM Offline
                                  McGyver
                                  Thank you for this plugin and also thank you for adding the explanation of what it is for and the Wikpedia link.
                                  Visit My ShareCG Freebie Gallery
                                  • 2 / 2
