    [Plugin] SliceModeler v1.3 released!
    93 Posts 37 Posters 118.3k Views 37 Watching
      dcoop58
      @xrok1 said:
      @dcoop58 said:
      Anybody using SliceModeler v1.4?
      Check out:
      Attention Required! | Cloudflare
      (www.public-art-international.com)
      SliceModeler 1.4 with downloads and tutorial......
      It's Technical...............
        dcoop58
        Hi everyone!
        Has anyone had issues with random sections not being completed on complex models? I have tried with some success to cut a complex shape with slicemodeler, and I get sections that have the perimeter defined, but the thickness and assembly slots are left out.
        Here is a screen cap of what I am talking about:
          princedragoncok
          @dcoop58 said:
          Hi everyone!
          I have been using slicer modeller almost on a daily basis for the last two months and yes it simply happens all the time - especially with complex models. The calculations just seem to be buggy. I am very tempted to hear what 1.4 is like - i really should have just paid for it by now..
          A quick tip for your case however is that the intersections are crossing over at specifically difficult areas. (like at the junction of the side of the window you have made) - If you alter your spacing so that the intersections fall at simpler junctions then you should be ok.
            rru96
            Hello there. I have a question about SliceModeler. I am fairly new to SU and SliceModeler and have yet to find a way to do this. What I am looking to do is export a slice to an image so I can print and make small scale models.
            I have an object designed. It is sliced into 10 slices on the X and the Y. These slices are 1.5' x 3' on average. I am looking to print each slice up on cardstock or a similar medium to actually get to hold a scaled model of the final to save on costs. Each slice needing to be selected, then sent to the printer so I can then cutout using a cheaper material before going into 'full production' so to speak.
            If anyone could help me out I would be greatly appreciated.
            I have done a search on the forums and the net but just cant seem to find anything.
              dcoop58
              After you have created the slices, they are grouped by axis. You can select the group and then right-click and "explode" the group to get individual sections. By using standard camera views, and placing the camera in "parallel projection" you can get a straight on view of your slices. You can then export a 2D graphic of each slice into a .jpg or other format that can then be printed. My concern for you is that your slices are big "1.5' x 3' on average", as you state. I hope you have a big plotter or you will be taping smaller pieces together. If you have Adobe Illustrator, this process is much easier. You can import the group and use AI to scale the slice forms down to fit on standard printer paper.
              I hope this helps.
                dcoop58
                @princedragoncok said:
                @dcoop58 said:
                Hi everyone!
                Thanks for the tip. BTW, I am using SM V1.4 with the results you see above. I thing the main thing is that it is faster than V1.3 and fixes some bugs.
                  rru96
                  Thanks for the response. That is what I was doing. Top down view zoomed in. It worked okay. It just took time to scoot to each piece to print. I just was looking for a simplar way. I was able to get it doing the same method you stated, just time consuming.
                  Now if only I could find a CNC shop!
                  • X Offline
                    xrok1
                    TIG, have you considered updating your script to work like the commercial one so this guy will have a hard time selling it?
                    it pisses me off everytime i see this!
                    P.S check this out http://www.ideablob.com/ideas/4237-Sliceform-models-rock-
                    • takesh hT Offline
                      takesh h
                      Well I don't want to play the police here when TIG himself doesn't, but...
                      I was doing some research prior to writing a post about TIG's Slicer in Visual Index of Ruby Scripts, and then I naturally came to realize the existence of this script.
                      One thing really bothered me about this script is not the fact that asteronimo is trying to make money out of it (ok, he is not selling the script, but he is asking donations for his tweaks I understand), but the fact he erased TIG's copyright from the script and replaced with his own name.
                      Don't really know what his intentions are, but I just have to let you guys know something very fishy is taking place here.
                        'SliceModeler' isn't the same as my 'Slicer'. It is heavily based on it, but it makes 'slots' too etc to assemble the model. I even helped him recode parts of it so that it'd work !
                        Whilst it would be nice have my original input recognised we can't do much about it... I certainly don't want to kick up a fuss. However, if some of you want to write to the author and suggest a little more 'politeness' in his header then please do so... If I 'borrow' code I try and add something like (c) TIG... Parts of the code based on XXXX by YYYY.
                        • takesh hT Offline
                          takesh h
                          I PMed him. Let's see how he reacts to it, if he ever reads my PM though...
                          "You can download the latest version of the script from your Account page when your payment has been received."by asteronimo
                          Oops, I was wrong. He IS selling the script.
                          • N Offline
                            nankyo
                            AMAZING!! I look so long for automatic plug like this one... Until now i do it manual...
                            I have a suggestion- to add option to make only one axis process, I mean - to be able to complete the plugin without 'cancel' it in the middle so the result will be like that below.. (I did it with multi push-pull, But I had to explode it and it wasn't flatten....)
                            Anyway, great job.
                            You are amazing, guys!! 😎
                              anu
                              Hi, Where can I download SketchUp SliceModeler v1.4? Ad how to use this plugin with sketchup .I am new to sketchup and if you could mail me the detailed steps ,it would be so helpful.
                              thanks in advance,
                              annu.
                                anu
                                thanks in advance,
                                annu.
                                  It's in this thread - first page is a good start... 😉
                                  • E Offline
                                    Ed-
                                    Can someone help to find the 1.4 version?
                                    This link:
                                    (ideablob.com)
                                    where download the script for free is gone.
                                    Thanks in advance.
                                      This link:
                                      (ideablob.com)
                                      Thanks in advance.
                                      ❓ You can download it free from this site. But I've never heard of v1.4.
                                        The 'free' v1.3 is here, in the first post in this thread. However, v1.4 is only available here http://www.public-art-international.com/catalog/product_info.php/products_id/200/language/en [which is also linked on that page] - where you are 'encouraged' to make a donation...
                                        • X Offline
                                          xrok1
                                          "encouraged"? you can't download without a donation! 😡
                                          unless someone has a copy of 1.4 they'd like to post here? 👿
                                            Well, if it is "sold" for a compulsory donation there, please, do NOT upload a "pirated" version here. Everyone has the right to sell a plugin and define where it can be downloaded from.
                                            • 3 / 5
