    [Plugin] 2D Tools
    791 Posts 178 Posters 634.7k Views 177 Watching
      @ben ritter said:
      TIG,
      Just started to use the tools and all I can say is that they are wonderful. Thank you so much.
      One problem I'm having is getting the hatching command to work. Does not want to initialize, no dialog box, etc.
      Ben
      After hatching has been run once you should get it opening without a dialog, with the last set 'patt' reported on the VCB, right-click in empty-space to get the dialog up to change the 'patt'. Otherwise please run with ruby console open and report error messages...
        @pixero said:
        I cant see any snapping points when using the line tool. Bug?
        There aren't any ! Might add some ???
          2D text has no 'leaders' - it's easy enough to add one as a 2D polyline between the text and the required point. If you want an arrow or 'dot' then add say a text 'point' at the end ?
            Ben Ritter
            @tig said:
            @ben ritter said:
            TIG,
            Ben
            TIG,
            I click on the tool and nothing happens. The ruby console says, "Cancelled 2d Hatching". That's all it says.
            • facerF Offline
              facer
              Tig,
              Thank you for ruby, well done.
              Everything appears to work except for 2D Hatching and Text.
              I am unable to activate the 2D Hatching or Text.
              Operating system Windows 2000.
              Here is the ruby consule output for the attempts on Hatching and Text:
              Cancelled 2D Hatching.
              Error: #<NoMethodError: undefined method refresh_thumbnail' for #<Sketchup::ComponentDefinition:0x74ebee0>> C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2DtextTool.rb:126:in activate'
              C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2DtextTool.rb:343:in select_tool' C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2DtextTool.rb:343:in texttool2D'
              C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2D#loader.rb:130
              C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2D#loader.rb:130:in `call'
              • PixeroP Offline
                Pixero
                Please do.
                  A mystery ! Please give me details of SUp version, OS etc...
                  But first can you also try typing/pasting this command into the ruby console to see what happens...
                  hatchingtool2D
                  The only tile you get the "Cancelled 2d Hatching" message is if you open the dialog and then cancel the dialog, the tool is cancelled too...
                  Does this problem happen on a 'brand new' and 'empty' model and/or existing ones ?
                  With the ruby console open, if you pick on the tool from the toolbar or menu do you get the cancelled message immediately ? What does the VCB say ? What materials do you have in the Materials Browser ? Any 'PATT' ones ?
                  I shall get to the bottom of this ❓
                    Here is the ruby console output for the attempts on Hatching and Text:
                    See my recent reply to Ben Ritter who has similar problems with Hatching...
                    Can you give me a few more details about the SUp version etc...
                    I suspect you are using an earlier version of SUp that doesn't support definition.refresh_thumbnail ?
                    I'll look into it... ❓ ❗
                      SHAHEEN
                      thanks a lot TIG . u r amazin
                      " An eye for an eye only ends up making the whole world blind "
                      Gandhi
                        Here's v2.6 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                        Line inferencing and tooltips improved.
                        Circle VCB messages improved or corrected.
                        Hatching error/glitch fixed.
                        Text error with SUp v<7 fixed.
                        • EdsonE Offline
                          Edson
                          gosh! there is no limit to how much you can improve your plugins. i may have said this before, tig, but you are a great asset to this community. 👍 👍
                          http://www.mahfuz.arq.br
                            Ben Ritter
                            hatchingtool2D
                            TIG,
                            Tried v 2.6 and same happens.
                            In the ruby console, tried your suggestion:
                            hatchingtool2D
                            #Sketchup::Model:0x5047f78
                            I'm running SU 6.4.112, XP Professional Service Pack 3, brand new model, just the default texture. With ruby console open, I get the message immediately, nothing in the VCB.
                            Thanks for checking into it. Ben
                              dedmin
                              Google, stop trying to compete with TIG!!!
                                Dan
                                Tig, thanks again for your wonderful work, daily updates and your "instant" answers!
                                A suggestion : an "adjust" tool (instead of the requested "extend").
                                ArchiCAD has such a tool and I use it very often.
                                It works like that:
                                • select an entity (line, arc, poly-line, etc.)
                                • choose the "adjust" tool
                                • pick another 2D entity (line, arc, circle, poly-line, etc), or draw a line
                                • the selected 2D entity then is "adjusted" to the last one (shortened if it's longer, extended if it's shorter)
                                I don't know if it's hard to add this to your tools, but it would be very useful to me (and many others, I dare to think).
                                  Dan
                                  The 2D Fillet Tool also acts as a Trim Tool or an Extend Tool - when its value=0.
                                  By default its radius/chamfer value=0.
                                  Run the 2D Fillet Tool.
                                  Pick two Edges.
                                  Assuming they intersect...
                                  If they are long they are Trimmed
                                  If they are short they are Extended.
                                  If the Edge owns more that one Face it is not Trimmed as that would destroy the Face !
                                  It works on Lines, Polylines, Arcs etc...
                                  However, it doesn't remake Arcs to Extend them to the new intersection - just changes the last segment length...
                                  What is the difference between this and what you suggest ? I can only see it's this Arc remaking ? 💭
                                  • PixeroP Offline
                                    Pixero
                                    Wow, I really like the trim extend functionality.
                                    It's funny these tools sort of started with my request for a way for my boss (who is learning SU) to draw in 2d. 😆
                                      DIEGO-RODRIGUEZ
                                      TIG excellent, had not noticed this tool to expand.
                                      If you could achieve to work with arc that would be excellent.
                                        Dan
                                        Tig, thanks for your so fast and explicit reply!
                                        I know what fillet tool can do (and I didn't entirely read your the help file 😳 ).
                                        Truth is that I never tried to extend an arc... but I think that's a SU limitation, knowing that they are approximated by segments.
                                        But what I forgot to add to my previous post is that ArchiCAD "adjust" tool can be applied to more that one 2D entity: one can select as many lines or arcs, etc. at once and they will trim or extend all together and, if boundary line doesn't exist, one can draw an imaginary one.
                                        I hope this make sense.
                                        Actually, a set of real 2D Tools are something I was "officially" asking each time I was in the beta tester team, from @Last to Google, and yours are a major step forward.
                                          What you are asking for is an Trim/Extend like CAD where you select the Line(s) etc to Trim/Extend to and then the ones to be edited. The first set doesn't change (unless it's also in the second set !), the second set is adjusted as expected - extending/trimming to the projection of a selected line if appropriate...
                                          In CAD many users use Fillet as a Trim/Extend Tools by setting the value=0 and working on just 2 picked Edges.
                                          The separate Trim/Extend works as outlined above...
                                          I'll think about a separate Tool... ❓
                                            Here's v2.7 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760 ☀
                                            New 2D Polygon Tool added. Similar to 2D Circle BUT can specify number of Sides NNs, length of a Side NNNx OR Radius NNN etc... 2D Circle tool alignment to second-picked point corrected. Help files updated. New tool's Icons added - also CADfather's alternative set updated temporarily until he adds his own...
                                            • 39
                                            • 40
                                            • 3 / 40
