    [Plugin] 2D Tools
    791 Posts 178 Posters 770.7k Views 177 Watching
    • PixeroP
      Pixero
      I cant see any snapping points when using the line tool. Bug?
        markozeta
        @earthmover said:
        One other request would be the ability to have leader text that doesn't change size when your scroll in and out. Perhaps there is a setting to change this that I don't know about??? Perhaps an improved leader text tool for 2D tools would be in order.
        Set your text size to be a value in inches, rather than point size.
        Window > Model Info > Text > Font Size.
        Set it for a value in inches and it will be constant. In points it will move zoom with the zoom.
        BSME - Cal Poly Pomona
        Sketchup Pipe Maniac
        • B
          Ben Ritter
          TIG,
          Just started to use the tools and all I can say is that they are wonderful. Thank you so much.
          One problem I'm having is getting the hatching command to work. Does not want to initialize, no dialog box, etc.
          Ben
            @ben ritter said:
            TIG,
            Ben
            After hatching has been run once you should get it opening without a dialog, with the last set 'patt' reported on the VCB, right-click in empty-space to get the dialog up to change the 'patt'. Otherwise please run with ruby console open and report error messages...
              There aren't any ! Might add some ???
                2D text has no 'leaders' - it's easy enough to add one as a 2D polyline between the text and the required point. If you want an arrow or 'dot' then add say a text 'point' at the end ?
                • B
                  Ben Ritter
                  @tig said:
                  @ben ritter said:
                  TIG,
                  Ben
                  TIG,
                  I click on the tool and nothing happens. The ruby console says, "Cancelled 2d Hatching". That's all it says.
                  • facerF
                    facer
                    Tig,
                    Thank you for ruby, well done.
                    Everything appears to work except for 2D Hatching and Text.
                    I am unable to activate the 2D Hatching or Text.
                    Operating system Windows 2000.
                    Here is the ruby consule output for the attempts on Hatching and Text:
                    Cancelled 2D Hatching.
                    Error: #<NoMethodError: undefined method refresh_thumbnail' for #<Sketchup::ComponentDefinition:0x74ebee0>> C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2DtextTool.rb:126:in activate'
                    C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2DtextTool.rb:343:in select_tool' C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2DtextTool.rb:343:in texttool2D'
                    C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2D#loader.rb:130
                    C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2D#loader.rb:130:in `call'
                    • PixeroP
                      Pixero
                      Please do.
                        A mystery ! Please give me details of SUp version, OS etc...
                        But first can you also try typing/pasting this command into the ruby console to see what happens...
                        hatchingtool2D
                        The only tile you get the "Cancelled 2d Hatching" message is if you open the dialog and then cancel the dialog, the tool is cancelled too...
                        Does this problem happen on a 'brand new' and 'empty' model and/or existing ones ?
                        With the ruby console open, if you pick on the tool from the toolbar or menu do you get the cancelled message immediately ? What does the VCB say ? What materials do you have in the Materials Browser ? Any 'PATT' ones ?
                        I shall get to the bottom of this ❓
                          Here is the ruby console output for the attempts on Hatching and Text:
                          See my recent reply to Ben Ritter who has similar problems with Hatching...
                          Can you give me a few more details about the SUp version etc...
                          I suspect you are using an earlier version of SUp that doesn't support definition.refresh_thumbnail ?
                          I'll look into it... ❓ ❗
                            SHAHEEN
                            thanks a lot TIG . u r amazin
                            " An eye for an eye only ends up making the whole world blind "
                            Gandhi
                              Here's v2.6 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                              Line inferencing and tooltips improved.
                              Circle VCB messages improved or corrected.
                              Hatching error/glitch fixed.
                              Text error with SUp v<7 fixed.
                              • EdsonE
                                Edson
                                gosh! there is no limit to how much you can improve your plugins. i may have said this before, tig, but you are a great asset to this community. πŸ‘ πŸ‘
                                http://www.mahfuz.arq.br
                                • B
                                  Ben Ritter
                                  hatchingtool2D
                                  TIG,
                                  Tried v 2.6 and same happens.
                                  In the ruby console, tried your suggestion:
                                  hatchingtool2D
                                  #Sketchup::Model:0x5047f78
                                  I'm running SU 6.4.112, XP Professional Service Pack 3, brand new model, just the default texture. With ruby console open, I get the message immediately, nothing in the VCB.
                                  Thanks for checking into it. Ben
                                    dedmin
                                    Google, stop trying to compete with TIG!!!
                                      Dan
                                      Tig, thanks again for your wonderful work, daily updates and your "instant" answers!
                                      A suggestion : an "adjust" tool (instead of the requested "extend").
                                      ArchiCAD has such a tool and I use it very often.
                                      It works like that:
                                      • select an entity (line, arc, poly-line, etc.)
                                      • choose the "adjust" tool
                                      • pick another 2D entity (line, arc, circle, poly-line, etc), or draw a line
                                      • the selected 2D entity then is "adjusted" to the last one (shortened if it's longer, extended if it's shorter)
                                      I don't know if it's hard to add this to your tools, but it would be very useful to me (and many others, I dare to think).
                                        Dan
                                        The 2D Fillet Tool also acts as a Trim Tool or an Extend Tool - when its value=0.
                                        By default its radius/chamfer value=0.
                                        Run the 2D Fillet Tool.
                                        Pick two Edges.
                                        Assuming they intersect...
                                        If they are long they are Trimmed
                                        If they are short they are Extended.
                                        If the Edge owns more that one Face it is not Trimmed as that would destroy the Face !
                                        It works on Lines, Polylines, Arcs etc...
                                        However, it doesn't remake Arcs to Extend them to the new intersection - just changes the last segment length...
                                        What is the difference between this and what you suggest ? I can only see it's this Arc remaking ? πŸ’­
                                        • PixeroP
                                          Pixero
                                          Wow, I really like the trim extend functionality.
                                          It's funny these tools sort of started with my request for a way for my boss (who is learning SU) to draw in 2d. πŸ˜†
                                            DIEGO-RODRIGUEZ
                                            TIG excellent, had not noticed this tool to expand.
                                            If you could achieve to work with arc that would be excellent.
                                            • 39
                                            • 40
                                            • 3 / 40
