    VRay for SketchUp- To use Normal Maps
    renderpluginsextensions
    10 Posts 9 Posters 10.3k Views 9 Watching
    • L
      lexqui
      Hi.
      Does anybody know if it's possible to use Normal maps in VRay for SketchUp? It's easy to donwload materials that come with a Normal Map, but VRayForSketchUp doesn't have a specific slot for this type of image. As it's a variation of the bump map, will it work if it's applied in the Bump Slot? Did anybody tried this?
        RustyShack
        Give it a try and you'll see it works.
        • N
          nomeradona
          yes it works..
          • L
            lexqui
            Well, so that's great. I'll try it in a few models.
              VfSU doesn't make use of Normal maps. You can load it into the bump map slot - but it won't treat it as a proper normal map.
              • T
                tomot
                does the new version of Vray now include normal maps, in order to produce results similar to the attached pic?
                my plugins
                tomot
                • dkendigD
                  dkendig
                  Unfortunately, we were not trying to add more complexity to the rewrite of our plugin, so normal map support was not added.
                  Devin Kendig
                  Developer
                  • G
                    g.moggel
                    does this work already? i've got some mapping methods that say
                    bump
                    normal map (Tangent space)
                    normal map (Object space)
                    normal map (Camera space)
                    normal map (World space)
                    bump map (Local space)
                    Explicit normals
                    WHAT DOES IT MEEEEAAAN?
                    β˜€ Double Rainbow...
                    • V
                      valerostudio
                      Normal maps are now in the current version of VR4SU. It's been in there since 1.6 I beleive.
                      There is a little bit of info here about some the object spaces.
                      Site not found Β· DreamHost
                      The owner of this domain has not yet uploaded their website.
                      (www.3dkingdoms.com)
                      • P
                        pipinek
                        Greetings,
                        Is there any possibility to add bum, normal map (edit difuse) to vrmesh materials in SU?
                        I have got some vrmesh component in SU and I would like to add some visual value to them.
                        Thank you in advance.
                        PS
                        Or should I adjust all material setting to a component before converting it into vrmesh?
